2012/01/06
I'm working on improvements
- Camera image mirrored fixed
- Adding a virtual memory (512 MB is not enough for android 4.1.1) For more information http://en.wikipedia.org/wiki/ZRam
- Concern noise from speakers after standby, still not resolved
returns errors in dmesg log file(http://www.arctablet.com/blog/wp-content/forum-file-uploads/f636y623/2012/12/dmesg.txt) has a corresponding source of chrome (chrome of library is located in the lib folder) I do not know if these lib chrome could cause this problem
edit:
Source code with reference to error dmesg log
I continued for V1.3
bukaneri
2012/09/27
2012/01/06
lolloarnova said
No news about 10 G2 user?????
Morka you think possible a porting of your Morkamod JB on it?
Thenk's!!!!
post me your file dmesg log for hardware configuration
Edit:
Other information about my comment
The chrome library does not have causing this problem
I am looking for a solution (But my tests carried out on the version 1.3, the noise is gone, but displays this error dmesg log)
2012/09/27
2012/01/06
Sorry there are no kernel compatible with your hardware
http://forum.xda-developers.com/showpost.php?p=29649602&postcount=4
Arnova 10 G2: 10,1", 1024*600 (16:9), capacitive touch 2p, coasia-TS, BCM43X9 WLAN gpio, MMA7660 Sensor, RT5631 Audio, OV7675 fcam, HYM8563 clock
2012/09/27
2012/11/25
@Morka
Nice work, also adding zram is a good idea.
Another thing I noticed, because of the constantly running speakers, the tablet now takes twice as long to fully charge. From 0 to 100%, when the light changes to indicate the tablet is fully charged, normally it took around 6,5 hours, now it takes around 13 hours for the light to change.
Also next time I connect it to my PC, I try to get a logcat/dmesg for the other problem, when I try to mount it as mass device and it just doesn't do it.
By the way on which device are you testing? Mine is an Arnova 8 G2 Capacitive 8GB EU/US
EDIT: dmesg doesn't show something weird when trying to mount as mass device, but logat shows some errors:
12-16 16:25:59.149 I/PackageManager(Â 239): Updating external media status from unmounted to unmounted
12-16 16:26:00.169 I/Vold   (  71): /mnt/secure/staging/.android_secure sucessfully unmounted
12-16 16:26:00.169 I/Vold   (  71): /mnt/secure/asec sucessfully unmounted
12-16 16:26:00.189 I/Vold   (  71): /mnt/secure/staging sucessfully unmounted
12-16 16:26:00.189 I/Vold   (  71): /mnt/sdcard unmounted sucessfully
12-16 16:26:00.209 E/VoldConnector(Â 239): NDC Command {29 volume unmount /mnt/sdcard force} took too long (1059ms)
12-16 16:26:00.209 I/Vold   (  71): EXTERNAL_STORAGE is /mnt/sdcard
12-16 16:26:00.209 I/Vold   (  71): share flash
12-16 16:26:00.209 E/Vold   (  71): Unable to open ums lunfile (No such file or directory)
12-16 16:26:00.229 E/MountService(Â 239): Failed to share/unshare
12-16 16:26:00.229 E/MountService(Â 239): com.android.server.NativeDaemonConnector$NativeDaemonFailureException: command '30 volume share /mnt/sdcard ums' failed with '406 30 volume operation failed (No such file or directory)'
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:345)
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.NativeDaemonConnector.executeForList(NativeDaemonConnector.java:282)
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:248)
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.MountService.doShareUnshareVolume(MountService.java:599)
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.MountService.access$200(MountService.java:98)
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.MountService$UmsEnableCallBack.handleFinished(MountService.java:345)
12-16 16:26:00.229 E/MountService(Â 239): at com.android.server.MountService$MountServiceHandler.handleMessage(MountService.java:455)
12-16 16:26:00.229 E/MountService(Â 239): at android.os.Handler.dispatchMessage(Handler.java:99)
12-16 16:26:00.229 E/MountService(Â 239): at android.os.Looper.loop(Looper.java:137)
12-16 16:26:00.229 E/MountService(Â 239): at android.os.HandlerThread.run(HandlerThread.java:60)
12-16 16:26:23.369 I/InputAttributes(Â 371): InputType.TYPE_NULL is specified
12-16 16:26:23.379 W/SettingsValues(Â 371): Cannot load auto correction threshold setting. currentAutoCorrectionSetting: 0, autoCorrectionThresholdValues: [, 0.185, 0.067, 0]
12-16 16:26:27.099 W/SocketClient(Â Â 72): write error (Broken pipe)
12-16 16:26:44.399 E/LatinIME(Â 371): Backspace when we don't know the selection position
12-16 16:27:40.809 W/ActivityManager(Â 239): Duplicate finish request for ActivityRecord{416f38d8 jackpal.androidterm/.Term}
2012/01/06
kaylord said
Hello, I have Arnova 7G2, I can help you find the kernel support to install Jelly Bean, I could pass the link please. Thank you, sorry for my English
use Kernel 3.0.8 for 7G2
@F636y623
version 1.3 on any correction on the mounting problem, there still have bugs
MorkaMod JB V1.3 With video playback of 1024p and game
Other game screenshot
Downlord MorkaMod JB V1.3
2012/01/06
Note very interesting
Here is the note on Rockchip audio wm8900
http://wenku.baidu.com/view/eeb239ebf8c75fbfc77db2b1.html
and RK29 USB Application Note_V1.1 for mass storage
2012/12/26
Hello Morka
I tried your mod on my teblette Archos97carbon (arnova 9G3), here is my feedback:
-this rom is very fluid, almost everything works.
Here the only problems I found:
USB Host does not fontionne
big problem-management battery (100% -0% ~ 20mins) after one charge-discharge cycle complete.
-almost nothing is compatible with my device on the blind play (crash after modification buid.prop)
But the work is excellent, thank you for this RomÂ
_____________________________
Bonjour Morka (voisin Lillois)
J'ai essayé ton mod sur ma teblette Archos97carbon (arnova 9G3), voici mes retours :
-cette rom est trés fluide, presque tout fonctionne.
voici les seuls problèmes que j'ai constaté :
-USB Host ne fontionne pas
-gros problème de gestion batterie (100%-0% ~20mins) aprés un cycle de charge-décharge complet.
-presque rien n'est compatible avec mon périphérique sur le play store (crash aprés modification du buid.prop mais la, c'est ma faute)
Mais le travail est excellent, merci pour cette RomÂ
The following users say thank you to schnappi59 for this useful post:
MorkaMost Users Ever Online: 749
126 Guest(s)
Devices in use: Desktop (79), Phone (45), Tablet (2)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
