[MorkaMod JB ][Android 4.1.1 Jelly Bean][All G2 and G3]
Related Tags
Morka
Lille
Forum Posts: 203
Thanks Received: 75
This post is pinned 1
2012/11/23 - 22:42
MorkaMod with Jelly Bean  v1.3
What's new 2012.12.28 :
- Camera image mirrored fixed
- Adding a virtual memory (512 MB is not enough for android 4.1.1) For more information http://en.wikipedia.org/wiki/ZRam
- Noise from speakers after standby, but was reduced with a modified file audio_policy.conf
http://www.arctablet.com/blog/forum/arnova-g2-general-discussions/morkamod-jb-android-4-1-1-jelly-beanall-g2-and-g3/#p15127
What's new 2012.11.23 :
Fixe : At startup/reboot does not run the tablet, treated USB/charger connection (or not disconnect it) ;)
Fixe : External SD
Fixe : Adb
Add : Android system recovery 4.1 (recovery.img) fixe internal and external sd (no format after install)
Add : News boot.img
For system app
Add : Android 4.2 Gapps and extras (Launcher2,LatinImeGoogle ect..)
I'm happy
Battery indicator shows the real  level
Download :
Compatible with the kernel (  Linux version 3.0.8+ )
Downlord 8G2 ,8G2i kernel--------------------
For 8G2 ,8G2i 4Go and 8Go copy kernel.img file ,folder /rockdev/Image
http://www.arctablet.com/users/forum/8G2_8G2I_4Go_8Go_kernel.zip
Downlord others kernel -----------------------------------------
For others model to copy kernel.img file from your backup folder /rockdev/Image
Search your model
The problems are the wifi drivers and sensor
To solve this problem with a file explorer copy folders (system/etc/firmware and system/lib/hw/sensors.rk29board.so) in your SD card install MorkaModJB
After install open root explorer, copy the drivers in your SD card in the system folder
Downlord MorkaMod JB-----------------------------------------
MorkaMod JB V1.3
http://www.arctablet.com/users/forum/MorkaModJBv1.3_all_G2_G3_Final.zip
MorkaMod JB V1.2Final
http://www.arctablet.com/users/forum/MorkaModJBv1.2_all_G2_G3_Final.zip
INSTALL
– Decompress with zip
– Boot tab into flash mode
– Run RK-Flashtool as admin: EraseIDB, tick Loader, Run
– With Android system recovery 4.1 – wipe data/factory reset (for which we install the version 1 skip this step keeps your backup wifi, application etc)
– Reboot
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
globula_neagra, admin, Sowa, anapaolo, Oma7144, neuro71, prudivus, metalhysteria, garsianu37, Jfcabalier, Pomme, estribiyo, Yessin, poseidon9000, setevoltas, stazor
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/11/24 - 04:04
What's new 2013.01.07 :
First, thank you all for error reporting
USB Host error with the file vold.fstab
fix
Line to modify
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_otg/usb1
With
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb /devices/platform/usb20_otg/usb1
For google play store
An error caused by me ,code written in the file init.rc
# Set operator numeric Market Fix
setprop gsm.sim.operator.numeric 31026
setprop gsm.sim.operator.alpha T-Mobile
setprop gsm.sim.operator.iso-country us
setprop gsm.operator.numeric 31026
setprop gsm.operator.alpha "T-Mobile"
fix
edit the file build.prop add to end of line
gsm.sim.operator.numeric=310260
gsm.operator.numeric=310260
gsm.sim.operator.iso-country=us
gsm.operator.iso-country=us
gsm.sim.operator.alpha=T-Mobile
gsm.operator.alpha=T-Mobile
Fix error message "if i open the galerie i can see folders in the background and i get an error message No Memory – No external Memory available"
edit the file vold.fstab
Line to modify
dev_mount sdcard /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9
With
dev_mount sdcard /storage/sdcard0 auto /devices/virtual/mtd/mtd9/mtdblock9
For volume buttons
Easy install,If there are errors uninstall
Download :
http://www.arctablet.com/users/forum/SystemUI_volume.apk
Image Enlarger
Sorry for causing care about this version, I'm working on the next version
1: The problem with the internal memory
2: make compatible the screens 7 "
After all modified
Step 1:
Go into Settings - Applications - Manage Applications - Market - Clear CACHE - Force Stop
Step 2:
Press back once - Google Services Framework - Clear DATA - Force Stop
Step 3:
Reboot your device
Step 4:
Open the market again and enjoy. You now have a fuller Android Market.
- MorkaMod JB V1.3
On this version, the improvement is managing memory with zram some screenshot with games that does not slow
MorkaModJBV1-1.pngImage EnlargerMorkaModJBV1-2.pngImage EnlargerMorkaModJBV1-3.pngImage EnlargerMorkaModJBV1-4.pngImage EnlargerMorkaModJBV1-5.pngImage EnlargerMorkaModJBV1-6.pngImage EnlargerMorkaModJBV1-7.pngImage EnlargerMorkaModJBV1-8.pngImage Enlarger
MorkaModJBV1-9.pngImage Enlarger
MorkaMod JB V1.3 With video playback of 1024p and game ;)
MorkaModJBV1.pngImage Enlarger
What's new 2012.11.30 :
Fixe - popping noise of the speaker, after the tablet screen disables and locks it self
to copy the folder system/app
http://www.arctablet.com/users/forum/Bluetooth.apk
Test AntutuBench
Image Enlarger
What's new 2012.11.28 :
Tests of battery life:
14h16 without recharging the battery (includes standby)
Image Enlarger
35% of the battery
Image Enlarger
In this test I play, watch video and online TV
Image Enlarger
What's new 2012.11.27 :
Fix Graphical glitches Launcher 4.2 (more fluid is faster)  ;)
Easy install, If there are errors uninstall
Download :
http://www.arctablet.com/users/forum/Launcher2.apk
New feature in MorkaModJB Jelly Bean graphical launcher was add PhabletUI:
How to enable Phablet mode on tablet ?
http://www.arctablet.com/users/forum/PhabletUI_MorkaModJB.txt
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
What's new 2012.11.25 :
Testing new status bar with the volume that is not the key
easy install,If there are errors uninstall
Download :
Image Enlarger
Download Mp4 video HD (1928x1080) with tubemate.apk
play with PIP video player really fluid does not slow
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Sowa, zak.martin, poseidon9000
Shed
Forum Posts: 11
2012/11/25 - 19:11
Admin
This seems like a big step forward, if it works on the 10G2.Has this been tested? Will it be added to Arctools?
Thanks Received: 3170
2012/11/25 - 19:15
This doesn't work on the Arnova 10 G2, as this tablet's kernel is not yet compatible with ICS (or later).
I've started to work on that a few months ago, but it's not usable yet. I'll try to work on that again in the future, but can't give any date.
grumpy
Lancing UK
2012/11/25 - 19:32
Great news, a terrific leap forward.    As Shed asked, does it work on 10 G2?
The installation looks a bit complex though!
All the hard work is much appreciated, thanks.
kevin_callosa
2012/11/25 - 20:52
I don't understand this step:
Search your model
where is this folder?
pd: I have a 7g2i with ics, this rom should run on my tablet?
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/11/26 - 00:21
Search your model
Download :
Image Enlarger
mixmaxmux
Agation.52
2012/11/26 - 11:24
How to get rid of the Phone-UI??? On my device does not have the buttons back, home and menu (((
PPI = 120 in build.prop
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2012/11/26 - 11:36
This Rom is compatible with 10G2 ???
Thank's!
2012/11/26 - 11:38
It's not compatible with Arnova 10 G2.
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2012/11/26 - 11:45
Arnova 10G2 is forget from GOD.....
I don't buy never Arnova product again.....
Is the unique G2 model not upgradable.... fuck.....
I'm hope in a future ICS on our tablet....
Thank's all for help and hard work!
kevin_callosa
2012/11/26 - 17:51
Search your model
Download :
Image Enlarger
No boot...
I don´t know.. Embarassed
F636y623
Forum Posts: 15
Thanks Received: 5
2012/11/27 - 00:25
Awesome work!Laugh
Just put it on my AN8G2 and it outperforms every Gingerbread ROM I used before.
2 minor things I noticed:
1. The launcher sometimes shows some graphical glitches when moving apps icons around.
2. There is a popping noise of the speaker, around 5 seconds after the tablet screen disables and locks it self, or if I lock it, and some seconds after the first pop comes another pop noise. Sounds when touching or locking are disabled.
Also compared to Gingerbread, everything looks, more tiny. Does that depend on the PPI/DPI = 120 setting?
If yes, what was the AN8G2's original setting, so that I can make it a bit bigger?
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/11/27 - 20:06
F636y623 said
Awesome work!Laugh
1. Yes GL code was added in the new api 17, not known in the API 16
2. I think this new version of android,to save the energy of the battery there should be a break for electric speakers
Gingerbread using 160 dpi,Ics using 120dpi and Jelly Bean is different from all previous android, it has been reviewed and clean
eg new feature graphical launcher was add phabletUI:
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
If 120 dpi is for me a good compatibility with my old applications
Edit : Fix Launcher 4.2 (more fluid is faster) ;)
Download :
@kevin_callosa
Search the forum how to flash my tablet RK2918
because I think you forget to add a kernel.img in the image folder
F636y623
Forum Posts: 15
Thanks Received: 5
2012/11/28 - 13:27
Gotta try that fixed Launcher2Laugh
Found out that this popping noise of the speakers on my AN8G2 not only occurs after lock of the system, but kinda regularly during standby, around every 30 minutes. Tried to check logact if maybe something is shown there and it always shows these lines:
E/Lights ( 239): write_int failed to open sys/class/leds/rk29_key_led/brightness
W/bluedroid( 239): open(/sys/class/rfkill/rfkill0/type) failed: No such file or directory (2)
W/BluetoothService( 239): Bluetooth is power down, reset
I/bluedroid( 239): Stopping bluetoothd deamon
E/bluedroid( 239): Failed to create bluetooth hci socket: Address family not supported by protocol (97)
The following users say thank you to F636y623 for this useful post:
Morka
Currently Online: fantom0308
102 Guest(s)
Devices in use: Desktop (88), Phone (14), Tablet (1)
fantom0308
Morris028
robertgdfdgdfss
wtf
jdani20001027
thinkappleeight
