Related Tags
Iglo
Forum Posts: 45
121
2012/02/22 - 19:24
Sould the sound issue be fixed in A10G2 test 5 ?
This is for me the most important issue now.
panita
122
2012/02/22 - 19:27
Sorry if I missed it in the posts, but is there any kernel ability to over/under clock the CPU with governors?
The stock and rooted Roms for 7 G2 are stuck on on 1Ghz all on the time even with the screen off/standby so wasting battery life.
Iglo
Forum Posts: 45
123
2012/02/22 - 19:30
I already asked for an OC daemon a few posts ago...
I was wondering if the kernel sources were available somewhere...
Thanks Received: 3177
124
2012/02/22 - 19:34
So far the stock kernel does not use governor mode for the CPU.
Fenice57 already did some work in building a CM7 firmware, not sure about current status and if we'll get the chance of getting better handling of the CPU freq.
http://www.arctablet.com/blog/forum/arnova-7-g2/rom-arnova-7g2-full-root-market-3g-ntfs-support-bluetooth-openvpn-cifs/page-4/
laserman123
125
2012/02/22 - 20:16
Hi Morka,
Stuck at boot screen for me too. I'm sure you will figure it out.
Will wait for next test.
Thank you.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
126
2012/02/22 - 21:43
Morka, as it was reported, test 5 does not boot, it's stuck on the boot image.
I'm getting the following looping in logcat:
I/Netd ( 92): Netd 2.0 starting
E/WiFiHW18( 92): Can't open /sys/class/rkwifi/chip
Thank you for this report
I think it could solve the problem youtube If this problem is solved I will post a final version
http://www.4shared.com/file/eDth4Cg9/Arnova10G2UI3SDK213RK29XXtest5.html
Problem finding all the versions on the home button and the search button does not function
127
2012/02/22 - 22:21
Morka, it's still stuck on bootscreen.
It gives
"I/Netd ( 97): Netd 1.0 starting
I/Netd ( 103): Netd 1.0 starting" in loop.
Attached the full logcat of a 5 mins run...
Let me know if you need anything.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
128
2012/02/22 - 23:43
It gives
I worked on this error to be compatible with this new SDK
http://www.arctablet.com/blog/forum/arnova-g2-general-discussions/morkamod-android-3-honeycomb-look-on-arnova-7g2-8g2-9g2-and-10g2-support-topic/page-4/#p5072
4shared folder
Name file : Arnova.10G2.UI.3.SDK.2.1.3.test5.fix.wifi.img
http://www.4shared.com/folder/w1sPQuAi/_online.html
Beta test1 for Arnova 9G2
propprop
Forum Posts: 77
129
2012/02/23 - 00:21
Flashed
booted into recovery
pressed "Confirm"
rebooted to ARNOVA
then PAST bootanimation -
into ROM
gonna have a good play. Thanks
laserman123
130
2012/02/23 - 00:50
(10G2)
Booting up fully for me too.
Camera and gallery still force close though. I will try other camera apps.
Most things seem to be working ok. Nice work Morka!!
Morka
Lille
Forum Posts: 203
Thanks Received: 75
131
2012/02/23 - 01:52
@propprop and @laserman123
Is Youtube Application does it work?
If you could do a test on every problem mentioned prev
That I understood who had the problem with this tablet
final vesion will be as close thank you all
Iglo
Forum Posts: 45
132
2012/02/23 - 08:06
To all who installed this. Is the sound issue fixed ?
propprop
Forum Posts: 77
133
2012/02/23 - 08:19
Fixed : Sound Issue fixed
Fixed : You tube application
bugs: Force close on Camera open
bugs: Force close on Gallery open
bugs?? I reinstalled my applications via titanium backup but after reboot they appear to disapear - I am now reinstalling fresh from market to see if this is the issue.
Mrcapo
134
2012/02/23 - 08:36
Really Really sorry for the noob question but I have only ever flashed with RK29update. With the latest update (7G2) which image do I change for the updated one?
Iglo
Forum Posts: 45
135
2012/02/23 - 08:39
I noticed some translations bugs into French.
There is also one thing that is disturbing me, the mobile network bars (close to wifi and battery icons) ! 🙁
Morka, can you give us the md5 sum of your uploaded files, just for checking if it downloaded correctly ?
53 Guest(s)
Devices in use: Desktop (47), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
