Related Tags
Morka
Lille
Forum Posts: 203
Thanks Received: 75
106
2012/02/21 - 20:19
What's new 2012.02.21 for Arnova MorkaMod:
Updated in SDK 2.1.3 ( rk29_gingerbread_v2.10.03 )
Fixed camera in video mode (but not recording problem of encoding library)
Addition of hardware acceleration 1024p
Zipalign all files
Restoration of the theme of this style ics sdk 2.1.3
All application are installed google update
Better stability than the old version
In preparation for the and AR10G2
For the 7G2 and 10g2 not yet resolved the status bar for full screen
Button Savior install to fix this issue Thanx Pulster for the tip.
I will answer all the questions later and thank you for the bug report
Arnova 8G2 SDK2.1.3
I forgot to put the youtube application
youtube.apk
Arnova 7G2 SDK2.1.3
Anova 10G2 SDK2.1.3.Test5
lohtse
Forum Posts: 157
107
2012/02/21 - 20:38
has YouTube been fixed on the 8G2???
alex
Forum Posts: 252
108
2012/02/21 - 23:57
Morka i know you have alot on you plate but would you be kindenough to make a 9g mod for the pretty people according to finless when he created a rom for this device the process is exactly the same
Morka
Lille
Forum Posts: 203
Thanks Received: 75
109
2012/02/22 - 01:59
here is the test for a 9G2
If you can give me a report if possible
and as the 7G2 and 10G2 problem with the status bar in full screens
Arnova.9G2.UI.3.SDK.2.1.3.RK29XX.test1.img
propprop
Forum Posts: 77
110
2012/02/22 - 06:04
Test image 5 freezes at boot animation
Tested twice and waited over fifteen minutes for tablet to boot with no luck.
This is for 10g2
Morka
Lille
Forum Posts: 203
Thanks Received: 75
111
2012/02/22 - 07:29
This is for 10g2
thank you for your test
Small error in my fix boot Arnova 10 G2 SDK 2.1.3.Test5
propprop
Forum Posts: 77
112
2012/02/22 - 13:20
just flashed fixed test5.img for arnova 10 g2
the same thing
It has flashed
rebooted into revcovery
pressed "confirm"
ARNOVA boot screen ok
Boot animation - still freezes - left for over 20 minutes and still frozen at android boot animation
I know you are working hard on this, so thank you very much, your work is very much appreciated.
I dont know how many test versions I can test as I am worried about my reset button not being built very well.
Iglo
Forum Posts: 45
113
2012/02/22 - 15:52
the same thing
It has flashed
pressed "confirm"
Same here. A10G2.
Keep up the work !!! 🙂
laserman123
114
2012/02/22 - 17:31
Hi Morka,
Looking forward to testing later.
Would it be possible to De-odex the rom too?
propprop
Forum Posts: 77
115
2012/02/22 - 18:40
Is it impossible to replace
system/media/bootanimation.zip
I would like to - but user permissions do not allow even though I have granted 'es explorer' superuser permissions
Is there another way?
Thanks Received: 3177
116
2012/02/22 - 18:44
You can't, it resides on a read only file system (CRAMFS). You need to unpack the firmware, modifiy and repack. The problem is probably not the animation itself, but system issue that blocks the boot process. I'll try to have a look when I am done with my other firmware modifications.
Regarding your reset button (post #112), if you press it gently, it should last long. Mine did get hundred if not thousand pushes since few months and it's still OK, just try to push it lightly.
Reisen Inaba
Forum Posts: 22
117
2012/02/22 - 18:46
Nice work on the update~ Going to try it now, thanks!
Morka
Lille
Forum Posts: 203
Thanks Received: 75
118
2012/02/22 - 18:53
I should mention that this firmware allows any modification by the intermediary of an application
test with Absolute system root tools or other But some files are not editable
@laserman123
Since the SDK 2.0
Tested by me an increase in duration for batery
file to rename it will not install Phone.apk, Provision.apk, and TelephonyProvider.apk VpnServices.apk which use 20% of the batery
propprop
Forum Posts: 77
119
2012/02/22 - 18:54
ok thanks for info
120
2012/02/22 - 19:17
Morka, as it was reported, test 5 does not boot, it's stuck on the boot image.
I'm getting the following looping in logcat:
I/Netd ( 92): Netd 2.0 starting
E/WiFiHW18( 92): Can't open /sys/class/rkwifi/chip
47 Guest(s)
Devices in use: Desktop (45), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
