Related Tags
propprop
Forum Posts: 77
91
2012/02/19 - 23:26
shall I install the youtube.apk?
Morka
Lille
Forum Posts: 203
Thanks Received: 75
92
2012/02/19 - 23:30
if it does not bother me to know if the problem is solved with this application thank you for doing these tests
propprop
Forum Posts: 77
93
2012/02/19 - 23:40
installed the apk you provided previously
but I get this message
(!) there was a problem with the network [400]
I did not do any flash 11 or any other updates?
laserman123
94
2012/02/19 - 23:49
Hi Morka,
Fantastic work you are doing here!
I keep getting force close on:
Camera
Gallery
Google Maps(after update)
Hope you will be able to look into when you have time.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
95
2012/02/19 - 23:50
not the same error problem of lib GStreamer
http://gstreamer.freedesktop.org/wiki/GstreamerAndroid_InstallInstructions
@laserman123
What tablet are you?
start restarts if it happens again
A8G2
96
2012/02/20 - 00:19
Any update for youtube on the Arnova 8 G2?
Been running for a few days know, only problem I have noticed is that apps keep disappearing after restart, check on the Market and they are then uninstalled, seems like a strange error to me.
laserman123
97
2012/02/20 - 00:28
@laserman123
Sorry, forgot to add in my post. I have the 10 G2.
I tried restarts but still same issues.
propprop
Forum Posts: 77
98
2012/02/20 - 12:11
Still very good work and enjoyable it is very usable but
No audio - ipayer/system sounds/videoplayer
Can not close images of apps in the market to exit (ie no access to back button) - reboot needed
similar with some apps eg. piano (trick is going into settings of that app and the back button appears then pressing it back - fast two or three times)
Force Close on opening front camera
Force Close on opening back camera
Force Close on opening gallery
Was there a reason why you went back to the old browser? which flash is best? latest?
also not sure what the 2nd icon is (next to wi-fi) or how to remove/fix it. It came on when I was playing with some network/wifi setting but I reverted all settings back and this remained.
lohtse
Forum Posts: 157
99
2012/02/20 - 12:26
could I have a bit of feed back from 8G2 Users as would like to know what issues etc there may be before flashing....
Reisen Inaba
Forum Posts: 22
100
2012/02/20 - 12:59
@propprop As pulstar mentioned, Button Savior will help when using apps that force full screen! It's worked great for me so far and pretty much solves that problem
Also I'm using Dolphin HD browser instead of the default browser. There seems to be a slight issue with the app space though. Sometimes the system thinks it is full when only 330MB of the 1GB has been used, and unfortunately the issue where if a program is on the internal flash rather than the dedicated app space is still common, that being the tablet can't find it even though it is installed. A problem I realise is probably not solvable yet.
Other than that I am happy with how this rom is turning out~ And don't see myself going back to 2.3 unless they do their CWM....which leaves me with this question, in the recovery menu, I can use the Install update via SD option to update the Recovery menu~ Does anyone know of a touch enable CWM image?
Regards~ Reisen
erikthekippa
101
2012/02/20 - 16:29
Morka said
Test 4 for Anova10G2
I make small precision tests because I did not AN10G2 and AN7G2
What's new restoration was the original sdk Rockchip and modification of all the appliction system for a resolution: 1024 x 600
addition of hardware acceleration 1024p for video
performance improvement (AntutuBenhmark score : 2594 on my arnova8G2)
update witch Rockchip Batch Tool Arnova10G2.UI.3.SDK.2.1.RK29XX.test4.img
Testing youtube application for 10G2
youtube.apk
@propprop
new boot image resolution 1024 x 764
bug 2 fixe
@erikthekippa
Tests to block the status bar for full screen not sure it works
@Iglo
ext3 or ext4 offers no performance gain has the ability to modiffier of file system on this forum there have any tutorial
I'll look after you finish with 10G2
OC daemon and CWM recovery.
Ok thank u very much but how can i apply this update? With recovery update sd or rk androidtool? Ok i think with recoery 😀 because the rktool not working with it
Iglo
Forum Posts: 45
102
2012/02/20 - 17:39
@Morka I know about ext4 vs Cramfs, but I like to move some apps into /system/app which is impossible with cramfs...
I don't know the way to convert cramfs to ext3/4 I don't even know if it's possible once the system is installed.
EDIT : If you could release an ext4 version, that would be very nice.
What about full root ?
propprop
Forum Posts: 77
103
2012/02/20 - 19:51
even though your test 4 image for 10G2 is probably more powerfull sytem I believe that your test 3 with updated system.img was more usable ie audio working, newer browser, new clock etc.
I know you are working real hard for us all, so all good
Iglo
Forum Posts: 45
104
2012/02/20 - 20:16
Just installed test4 and I notice that there is no sound... Known issue ?
laserman123
105
2012/02/21 - 00:19
Hi Morka,
Are you working on any updates for 10 G2?
38 Guest(s)
Devices in use: Desktop (36), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
