Related Tags
Pulster
76
2012/02/18 - 20:26
For those with the 7 G2 and losing the soft buttons on certain apps I currently use  Button Savior from the marketplace to overcome this.  Gives you access to soft buttons on the side of the screen upon the pressing of a discrete icon (short or long touch is configurable).
Only issue I found at the minute is YouTube not working.
On plus side I am now able to install Tweakdeck on the the 7 G2 and I couldnt do this on the other CFW I was using 🙂
Good work and look forward to future developments.
erikthekippa
77
2012/02/19 - 10:45
Hi in arnova 10 g2 the first installation is up to 10 minutes , the boot logo is just stripes , after 20 minutes it not started i rset it and after the reset it start cca 5 minutes , after the recocery utility appears i touch reboot system , crashed boot logo again and the tablet is started but the unlock screen is not responding about 5 minutes . After it respond i can use the tablet i manage apps etc etc. I installed apps are working with Kasty's rom and not working any of it. If some program can started is very slowly the stock rom faster more faster. Everything crashed. I charging about 10 hours and the battery is just 30 %. After the little empire game is not started just black screen i havent got back button i need to reset the tablet and after a few reset it not start anymore. I reflash it in this morning . I already wait 15 minutes and dont start just black screen but sometimes the unlock screen is pop up . The camera is working but dont have back button so i cant close it . After a few sec the camera force closeing. Manymany apps force closeing. Sorry for my bad english.Cry
snakekiller
Forum Posts: 25
78
2012/02/19 - 14:50
Tested v3 on 10g2
Error on pic gallery
When is de final?
Reisen Inaba
Forum Posts: 22
79
2012/02/19 - 15:52
@pulstar I'll check that app out thank-you.
Just a few other things I've found on the AN7G2:
Can't dismount external storage like USB sticks and cameras. Not that I've checked anyway.
And there is no touchscreen calibration. It may be go launcher but the home screen seems out a bit on accuracy
Not really important though. Please keep up with the good work!
Iglo
Forum Posts: 45
80
2012/02/19 - 16:06
Hi everyone.
I'm using a 10G2. I'd like to install this ROM, but there are few things preventing me to do so.
It's still using this crappy cramfs... I'd like ext3 or ext4 instead of this.
It's not fully rooted... Sad, but half root will be enough.
Other things I'd like to see :
- an OC daemon,
- a CWM recovery.
Anyway, that's a good job.
Question : is this ROM made from scratch or is it kasty-based ?
propprop
Forum Posts: 77
81
2012/02/19 - 16:22
right back and trying test3 on 10 G2 capacative 8gb - keep up the good work - I don't know why people are asking when is the final - that just sounds annoying
snakekiller
Forum Posts: 25
82
2012/02/19 - 16:44
Iglo said
Hi everyone.
- an OC daemon,
- a CWM recovery.
Ext 4 , fully root, then i think i switch from finless 1.4 too this oneWink
propprop
Forum Posts: 77
83
2012/02/19 - 17:05
Got the updated system image working for the 10 G2 8gb capacitive so far running well -
downloaded test3
extracted to folder "Arnova10G2.UI.3.SDK.2.1.RK29XX.test3"
downloaded http://www.4shared.com/file/f6AOIgPx/system_10G2.html and renamed to "system.img"
and REPLACED old system.img in "Arnova10G2.UI.3.SDK.2.1.RK29XX.test3/Image" folder
Ran "RK29update.exe" from "Arnova10G2.UI.3.SDK.2.1.RK29XX.test3" folder
2. Entered recovery mode on the tablet http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
than once Arnova G2 is found click "run"
after a several minutes the tablet boots into recovery
press "confirm" leave tablet for 5 minutes and it should boot into the new fancy rom
not had time to play with it as i just wanted to try the image as soon as i got in from being away however i need to nurse my hangover so will come back later once i have messed around on it
bug 1 - the boot image is bad
bug 2 maybe? the gap between the clock and settings pop up is not normal _ i am not sure
Morka
Lille
Forum Posts: 203
Thanks Received: 75
84
2012/02/19 - 20:48
Test 4 for Anova10G2
I make small precision tests because I did not AN10G2 and AN7G2
What's new restoration was the original sdk Rockchip and modification of all the appliction system for a resolution: 1024 x 600
addition of hardware acceleration 1024p for video
performance improvement (AntutuBenhmark score : 2594 on my arnova8G2)
update witch Rockchip Batch Tool Arnova10G2.UI.3.SDK.2.1.RK29XX.test4.img
Testing youtube application for 10G2
youtube.apk
@propprop
new boot image resolution 1024 x 764
bug 2 fixe
@erikthekippa
Tests to block the status bar for full screen not sure it works
@Iglo
ext3 or ext4 offers no performance gain has the ability to modiffier of file system on this forum there have any tutorial
I'll look after you finish with 10G2
OC daemon and CWM recovery.
Image Enlarger
 Image Enlarger
Mrcapo
85
2012/02/19 - 21:41
Button Savior!! Awesome tip. Just installed and can't believe I ever lived without it. Thanx Pulster for the tip.
propprop
Forum Posts: 77
86
2012/02/19 - 22:22
updated witch Rockchip Batch Tool 1.4
Arnova10G2.UI.3.SDK.2.1.RK29XX.test4.img however via "UPGRADE" button it installs and reboots but then freezes/stuck at "ARNOVA" screen pre-boot image the "ARNOVA" is also not central but further to the left this remained at this screen for nearly 5 minutes - where it has just turned black - stuck on plain blank black page screen here.
Please advise
Morka
Lille
Forum Posts: 203
Thanks Received: 75
87
2012/02/19 - 22:33
Please advise
sorry I propprop half bad kernel.img I see the new fix on rapidshare
News fix
http://www.4shared.com/file/lw-KHluN/update_Arnova10G2UI3test4.html
mirror
https://rapidshare.com/files/2605832871/update_Arnova10G2.UI.3.test4.img
snakekiller
Forum Posts: 25
88
2012/02/19 - 22:35
Please advise
First erase idb and click then on run .
That workked for me
Morka
Lille
Forum Posts: 203
Thanks Received: 75
89
2012/02/19 - 23:09
Give me some details on the installation, the malfunction, the pop up alert, application youtube ect .....
propprop
Forum Posts: 77
90
2012/02/19 - 23:24
upgraded - with fixed image - boots fine - with "ARNOVA" central - and new boot image shows nicely - just booting into rom now and will get back to you with any issues I may find although it is late so may have to wait till tomorrow - Once again of course your work is very much appreciated and enjoyed
48 Guest(s)
Devices in use: Desktop (44), Phone (4)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
