2012/01/06
danielsvaba said
like i said, i installed this rom, and it looks nice but i have see some bugs
1. no sound control
2. youtube not working
3. in market i open picture in some apps , and there is not BACK button
i pised off
thanks a lot, and @MORKA please fix this
you RULE
I think you're hurting updated the rom you install the kernel.img of 8G2
parcour the discution there have a picture to see how you selected the correct kernel.img of AN7G2
system.img for AN10G2 test3 Remove youtube and restoration of original properties
2012/01/08
Morka said
1. no sound control
i pised off
you RULE
i select the corect one , Arnova7G2 karnel.img
2012/01/06
@danielsvaba
I will create an image update.img
it is sending to court look here name file Arnova7G2_Rockchip_Batch_Tool_v1.4.zip
Morka said
I seek to understand this error youtube i too have never seen this before
In the original rockchipSDK it is not add youtube (I will delete it)
installed the firmware on the 10G2 on 8G2 works perfectly
think I'll make a unique firmware for 3 tablets@Reisen Inaba
looks into the launcher option or long press home (for recent activiter)
@Morka hi. Launcher options? I'll check. It just when the apps are open I have no access to the status bar so I can't use the back, home, switch window or options buttons. And I can't check notifications either. If I want to close a program I have to power off. AN7G2
2012/02/09
Morka said
@danielsvaba
Noob question but do I have to flash the original first then this update or can I go straight to this
2012/01/06
Use another launcher because it is builded firmware for tablet with all the buttons
on market search ics launcher he used the options for the status bar
@Mrcapo
these the same change to update it with Rockchip Batch Tool
next update
performance improvement +10
zipalign files for faster startup of aplication system
creation of firmware for each tablet
7G2 for blocking the status bar for full screen mode without tablet function buttons idea of Reisen Inaba
2011/11/19
MorkaMod latest info
MorkaMod for Arnova 10 G2 (test firmware) Arnova10G2.UI.3.SDK.2.1.RK29XX.test2.zip
I tried the 10G2, no luck, wouldn't even boot after flashing. I've loaded lots of roms for rk2918, from many manufacturers, most reboot but fail on screen, lots of rom's I've used were from 1024x768 tablets, ICS has run, many allow communication through usb & adb shell, just no user interface otherwise running. Not this one, nothing ... Back to v1.4.
2012/01/06
ttz642t said
MorkaMod for Arnova 10 G2 (test firmware) Arnova10G2.UI.3.SDK.2.1.RK29XX.test2.zip I tried the 10G2, no luck, wouldn't even boot after flashing. I've loaded lots of roms for rk2918, from many manufacturers, most reboot but fail on screen, lots of rom's I've used were from 1024x768 tablets, ICS has run, many allow communication through usb & adb shell, just no user interface otherwise running. Not this one, nothing ... Back to v1.4.
Update the system image test3
Morka,
I have repackaged MorkaMod for Arnova 10 G2 with test3 system image, the download links in the first post and Blog have been updated too.
So far MorkaMod 10G2 is good, appart from the Youtube error still there. (Youtube from Android Market).
I agree that keeping /system in cramfs is best to avoid user mistakes in modifying system files/directories, our we can have it in ext3 or ext4 mounted as read only...
Cheers,
PS: I have moved this topic to the generic Arnova G2 thread.
2012/02/03
On the Arnova 8G2, this firmware is quite usable, but still require some testing to be confirmed stable.
Always check the first post for latest firmware for your device, we'll try to keep it up to date.
Try to flash the firmware image with Rockchip Flash tool:
going into flash mode is Reset + Volume up.
2012/01/06
Morka,
Cheers,
bizare that youtube cause this problem on the original firmware it does not have this problem
The problem comes from the lib libsurfaceflinger.so
@lohtse
update_Arnova8G2.UI.3.Final.img update witch Rockchip Batch Tool
Arnova.UI.3.SDK.2.1.RK29XX.final.zip
@A8G2
START Rockchip Batch Tool use a needle is press the small reset hole for 3 sec
search the forum how to update with Rockchip Batch Tool
2012/02/18
Managed to do it; Sat watching device manger on my PC while holding Reset + Volume up, and behold and unknown device appeared, yet no sound? Hm, It didn't even try to install drivers either.
Anyway, installed the drivers, ran the flashing tool, and it is now running like a dream on my 8G2, No issues of anykind so far apart from the Youtube app not being able to connect, but I see that is a common issue.
Also, the Andromedia app force crashes on opening.
59 Guest(s)
Devices in use: Desktop (56), Phone (3)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
