Related Tags
op23963
691
2012/05/15 - 08:00
Hi All,
I used the 1.15 version on my Arnova 7b G2 Cap and everything looks and works fine except I don't have any sound ...
Is there a fix for that ??? Laugh
Thanks !!!
jane
692
2012/05/16 - 21:06
Hi all. Not an Arnova owner yet but almost about to buy a 9 G2 as a I really like the 4:3 screen layout.
In the firmware release post Morka says that the release includes "Adding a module (openvpn, iptables ect ..)". Does this mean that iptables is supported in this firmware and therefore it should be possible to run a firewall app (e.g. Droidwall) to manipulate these tables. Or is the required kernel support still missing?!!
This lack of firewall capability is the one thing that puts me off purchasing any Arnova tablet and it would make my day to know that this work on the G2s.
So, is there anyone using this firmware release who has been able to install Droidwall and configure it without getting an iptables missing error message?
Many thanks,
Jane
Droidwall - https://play.google.com/store/apps/details?id=com.googlecode.droidwall.free&hl=en
Thanks Received: 3171
693
2012/05/16 - 21:15
Hello Jane,
Unfortunately, the Arnova G2 are known of missing iptables feature. There has been quite a few discussions about that already:
http://www.arctablet.com/blog/forum/?search=1&forum=all&value=iptables&type=1&include=3
Bottom line: there is iptables support on some models (I'm not sure it's the case for all), but none of them have the necessary netfilter support in the kernel. I have not seen a successfully implementation for that on Arnova G2. The kernel sources not being released by the manufacturer surely does not help Confused
There's a new (unofficial) Android 4.0 ICS firmware for the 9G2 now available, I'll check if things have changed...
jane
694
2012/05/16 - 22:04
Ok, thanks for the prompt reply admin.
Would be interested to know if anything's changed in the ICS firmware (won't hold my breath though!).
What's with the lack of netfilter support in the kernels of so many Android devices? It does seem to impact the budget tablets particularly but there can't be any cost issues for the manufacturers over this. Strange.
Thanks again,
Jane
guillamos
695
2012/05/17 - 16:35
How can i keep the home/back button on the screen while playing games? I didn't found any options for this.
It's pretty much stupid that i need to reboot the device to quit a game.
I'm using 1.15 on my 10G2.
Blackyx007
Forum Posts: 19
696
2012/05/17 - 18:01
Just install button savior from the market 🙂
the only problem with this firmware is that you don't have root access
Masterzxz
697
2012/05/20 - 19:21
I installed version 1.15 on my 7b G2 tablet and now the sound isnt working.
Can somebody help me out?
698
2012/05/20 - 20:11
Other users reported the same problem on their 7b G2, it does not seem there is a fix at the moment.
You'll need to flash back the stock firmware or a custom firmware with Google Play.
Masterzxz
699
2012/05/20 - 20:12
Any ideas where i can get the stock firmware or another custom firmware with Google Play?
700
2012/05/20 - 20:30
Official Arnova G2 firmwares are all listed here:
http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
Custom firmware, you can use that one: http://www.arctablet.com/kitchen/firmwares/admin-20120520-202002-firmware.zip that I just built from our firmware kitchen.
murigny64
Forum Posts: 48
701
2012/05/20 - 21:02
Report for arnova 7b G2 capa:
Test 1.16:
- MX videoplayer won't work (fc)
- Slower than 1.14
I'll go back to 1.14:
- MX videoplayer work fine with all video types
- For chainfire 3D (not enough space on system), i delete some apps on system/app and then, i can install GL drivers with chainfire and it work fine.
1.15 is not a good way (cramfs)
Samsung Galaxy Note 10.1 2014 - 5.1.1
Haier Pad971 5.1.1
Asus Memopad10 ME102A 4.4.2
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
erikthekippa
702
2012/05/23 - 17:07
Hi!
I have 10 g2 1.14 is not working for me but 1.15 ext3 is ok. But when i install chainfire its crash.
Boot loop.  Can u help me what need i do?  Thanxx
Cortal
Forum Posts: 18
703
2012/05/23 - 17:13
So Morka hasnt visited the forum in almost a month... Any idea whats going on?
fxubmc
Forum Posts: 20
704
2012/05/24 - 12:19
No, MorkaMod disappear! I'm waiting for make tests with MorkaMod 1.16 on my Arnova 10 g2 (the actual firmware 1.16 in test freeze at bootstrap) but.... nothing. Morkamod don't responding! Don't replay, don't write... nothing. What's happens? Where is Morkamod? Someone knows he in person? Have problem with his health or family? ... Someone have some news?
Morka Mod 1.16 project is deleted (What a pitty... Morka mod 1.15 is the best firmware for Arnova 10 G2)?
Jean-Luke
Cortal
Forum Posts: 18
705
2012/05/25 - 15:12
Unless you have an Arnova model that had 1.15 ext3 released (I think only the Arnova 8 G2?) 1.14 is better, just because it is in ext3. That makes it so you have full access to everything, and can fully enjoy root access 🙂
74 Guest(s)
Devices in use: Desktop (67), Phone (6), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
