Related Tags
Thanks Received: 3171
676
2012/04/25 - 17:28
ikjahaa said
Providing a logcat (from adb) would probably give more information on the origin of the problem.
Everybody is welcome to help with that.
please clearafy how to do this
thx
If adb isn't installed you need to install it.
There are some info here: http://www.arctablet.com/blog/devices/arnova/adb-and-fastboot-tutorial/
and updated adb driver: http://www.arctablet.com/blog/featured/adb-driver-update-for-archos-arnova-devices/
From the adb tutorial, you won't use fastboot. When adb is installed, you'll just need to run
adb logcat
from your computer where you installed adb. Logcat will display debug information from your tablet to your computer, it should help spotting the reason these games are failing.
supergrovy
677
2012/04/25 - 17:40
ikjahaa said
supergrovy said
supergrovy said
I have MorkaMod installed in Arnova 9 G2, it works great (no bugs, no errors), but I have only one problem... What can I do to make Temple Run work? When I open it, it immediately closes. Any help?
Please help me!
same bug as me i think
I hope they can solve our problem! (please tell me what can I do to make Temple Run work! Please!)
However, when will be there Arnova 9 G2 MorkaMod 1.16?
poseidon9000
Forum Posts: 36
678
2012/04/25 - 18:28
Only a question; works fine the bluetooth drivers in 8G2??
seblelionnais
679
2012/04/27 - 20:45
Hey people 🙂
I have some problems with my arnova 8G2 8BG capacitive.. I install MorkaModV1.16 with Rockship Batch Tool. Great job, it's beautiful. But i have 2 bugs : I don't have audio and i have a bug with pixels line.
i think the problems were resolved with the official rom. Actually, i have the official rom 2.3.1 flash with a rom found on internet. And i do Factory data reset. But i don't found audio, and when my screen is in landscape mode, he "jumps" (google says screen pops)
Can you help me, or the tablet go to SAV?
PS : Sorry for my english, i'm french...
680
2012/04/27 - 20:49
Hello seblelionnais,
MorkaMod for 8G2 8GB capacitive is specific to that model only.
Can you check that you really have one, and not an Arnova 8b G2 capacitive ?
seblelionnais
681
2012/04/27 - 21:04
You understand me, it's a good step 🙂
On the face of the tablet i read ARNOVA | 8 G2. It's good isn't it?
682
2012/04/27 - 21:13
That's weird you can't get back your tablet to work normally with the stock firmware.
You said when flashing back the original firmware you still have some problems ? Where did you get that firmware ? Can you write all the links of firmwares you have tested ?
Can you try Sowa firmware ?  and this custom firmware (made from our Kitchen) ?
seblelionnais
683
2012/04/27 - 21:30
I try sowa firmware, no audio. I try to cook my firmware no audio and bug with the screen.
and the "official firmware" i found this
http://www.arctablet.com/assets/firmware/Arnova8G2/AN8G2_stock_update.zip
 but i don't know, if it's good.
I test with your kitchen and it's not better...
This tablet can fly?
i have an idea... Is it possible when i install morkamod for the first time, i dell a file about screen and audio. And this file isn't create before?
lystor
684
2012/04/29 - 10:20
Hi, Morka
Please release MorkaMod 1.16 for Arnova 7 G2 capacitive
Thank you
supergrovy
685
2012/04/29 - 13:51
Please tell me when I can have Arnova 9 G2 MorkaMod 1.16!
Marco
Forum Posts: 13
686
2012/05/07 - 22:00
help me!!!
i tried to flash morkamod 1.15.2 on my arnova 9 g2, but after the verify of fw, the tablet didn’t response.
i think it’s bricked…:(
Marco
Forum Posts: 13
687
2012/05/08 - 10:27
i was able to flash my arnova 9 g2 with original firmware, but the morkamod roms don't work, you know?!
theGod
688
2012/05/08 - 10:53
@Morka: just wanted to ask, if your init scripts are overwriting the build.props? if so, i just cannot find which one. can you help me? thx
vvb
Forum Posts: 17
689
2012/05/09 - 08:28
Please,
Have a arnova 9 g2. Can anyone write how to install morka mod? Step by step! What shall I do with old firmvare originaly installed?? Do I have to download it and just install it or ...?
Please write it step by step for unproffesionals like myself...
Thanks a lot!!!!
erikthekippa
690
2012/05/13 - 11:13
Hi Morka!
10g2 1.16 not working 1.15 cramfs version working but no root. Please help me rooting it.
Thank you very very much.
56 Guest(s)
2 Guest(s)
Devices in use: Desktop (53), Phone (3)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
