Related Tags
vvb
Forum Posts: 17
661
2012/04/23 - 09:02
chrislharper23 said
Hello
I've managed to update my gf's Arnova 9 G2 with this firmware. It's excellent! ūüôā
Can anyone help me with the following....
The tablet only powers up/boots up when the USB is attached. If I plug the power cable in instead, it gets stuck in the boot up loop (Arnova logo comes on, stays on a few seconds then goes off. Then it does this repeatedly. I'm not sure whether it's something I did before rooting it using the ArcTools app??
Any help will will be appreciated. Thanks.
Chris
Chris, please explane me how did u do that. Correct me if I m wrong, you remove original firmware and install morka formware. And you are more than satisfied. Can u please write the procedure how did u do that, it would be very nice?  Thanks a lot...
lohtse
Forum Posts: 157
662
2012/04/23 - 14:24
Due to all issues mentioned had reflashed Sowa's v5sRC…
Shame as loved having tilt controls working properly in games(the ones that actually worked on this rom!),The status bar disappearing when apps went full screen and location awareness!!!
Is there away to copy the drivers/required files to other roms?????
If so could you provide a zip/rar file with the files required and instructions where they go?
regards
Lohtse
(Arnova 8 G2 8G)
Tiago Pereira
663
2012/04/24 - 14:21
When will be released MorkaMod 1.16 for Arnova 7 G2?
I have Morkamod 1.15 installed and it works fantastic. Great job.
I only have some problems, like:
- the battery icon won't update, unless i restart the device
- i can't use Button Savior full features because it cant't access Superuser permissions.
supergrovy
664
2012/04/24 - 17:52
I have MorkaMod installed in Arnova 9 G2, it works great (no bugs, no errors), but I have only one problem... What can I do to make Temple Run work? When I open it, it immediately closes. Any help?
jordi.aguade
Forum Posts: 13
665
2012/04/24 - 18:53
Sorry for the question ... I'm just a rookie.
I have a tablet "ARNOVA 8G2 4Gb" SCREEN capacitive.
I tried to upgrade to Android 2.3 with Arctools, and now my tablet has no sound and the screen flashes.
This that is firmware works fine with my tablet?
Where I can find instructions for installing it?
How do I put the tablet in recovery mode?
P.D.: sorry for my bad English.
thanks
snakekiller
Forum Posts: 25
666
2012/04/25 - 04:44
@morka
when will be there a 1.16 release for the arnova 10g2 ?
Thanks Received: 3171
667
2012/04/25 - 08:27
thanks
Unfortunately, the Arnova 8 G2 capacitive 4 Gb is incompatible with the custom firmwares currently available.
By chance, the original firmware for your tablet was made available yesterday, please check here:
http://www.arctablet.com/blog/forum/arnova-8-g2/original-firmware-for-arnova-8-g2-4gb-capacitive/
You can flash this firmware and get your tablet working again using Rockchip flashing tool
On the Arnova 8 G2, press reset and power button to enable flash/recovery mode.
If you have any difficulties, please open a new topic in the Arnova 8 G2 forum.
jordi.aguade
Forum Posts: 13
668
2012/04/25 - 10:14
Thanks very much
Thanks very much
Thanks very much
Thanks very much
ikjahaa
669
2012/04/25 - 12:49
i have installed the 1.15v on my 10G2, it looks vert good but i have 1 major problem.
i can't use most of the apps i've downloaded form the market.
like:
  • Angry birds space premium,
  • carcassonne
  • uno
  • magic defenders
  • zenonia4
  • fruit ninja free
they all give a blank screen when i start them up. (black screen with the backlights on.)
also the menu bar to go back to hom etc dissapears in these apps.
supergrovy
670
2012/04/25 - 15:58
Please help me!
ikjahaa
671
2012/04/25 - 16:21
supergrovy said
Please help me!
same bug as me i think
lohtse
Forum Posts: 157
672
2012/04/25 - 16:27
like:
  • carcassonne
  • uno
  • magic defenders
  • zenonia4
  • fruit ninja free
Already posted same issues on my arnova 8 g2... still no response
673
2012/04/25 - 16:34
Providing a logcat (from adb) would probably give more information on the origin of the problem.
Everybody is welcome to help with that.
ikjahaa
674
2012/04/25 - 17:20
please clearafy how to do this
thx
Thanks Received: 264
675
2012/04/25 - 17:26
Install usb drivers for your device
activate usb debugg mode from your device
instal android sdk
instal java sdk
Check this post to find more stuff
http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/what-is-adb-and-fastboot-how-to-install-and-use/
check the blog to find more things about adb (there is an article about that)
52 Guest(s)
2 Guest(s)
Devices in use: Desktop (50), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
