Related Tags
Sowa
Russia, Novorossiysk
Forum Posts: 47
Thanks Received: 5
646
2012/04/15 - 20:13
Hi, Morka.
In the last image (AR8G2.ext3.2G.MorkaMod.v1.16.zip) is not kernel.img
If add, ROM works fine.
Made a version for ARNOVA 8G2 8Gb capactive with the /systems in a format ext4 filesystem.
Has updated some Google applications.
You can select the size of userdata (select parameterX file when flashing) 1, 2, 4 Gb
Download: AN8G2_MorkaMod_1.16.ext4.7z
China phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
kairi223
647
2012/04/16 - 19:18
Any chance of getting loop device support? Or are you working with the stock kernel?
Morka
Lille
Forum Posts: 203
Thanks Received: 75
648
2012/04/17 - 01:37
@Sowa
Beautiful realized I tested the model arnova 8G2 4Gb Works very well
Thanks Sowa
News Beta for all Arnova G2 – MorkaMod v1.16Beta
Mattl
649
2012/04/17 - 02:53
Morka said
@Sowa
Thanks Sowa
Hey Morka,
Does the link above have a new version of MorkaMod for the Arnova 10 g2 with fixed boot loop
Thanks Received: 3171
650
2012/04/17 - 10:08
Just tested 9G2.10G2.10bG2MorkaMod.v1.16Beta.cramfs.2G.zip (built yesterday) on 10G2, it gives lines garbage on boot, then get stuck on black screen. Logcat is attached.
theGod
651
2012/04/17 - 17:45
wanted to test it today, thx for the info
Morka
Lille
Forum Posts: 203
Thanks Received: 75
652
2012/04/17 - 18:47
The problem is with the ARNOVA 9G2 files init.rc
deactived starting to file init.rc Fixe boot Arnova.9.G2.cramfs.2G.MorkaMod.v1.16Beta.Fix.Boot
Mattl
653
2012/04/17 - 22:49
Does this update work on the 10 G2 also or is it specific to the Arnova 9 G2?
lohtse
Forum Posts: 157
654
2012/04/17 - 22:59
Hi firstly EXCELLENT job just flashed on my A8G2 and this is so far a great rom and is privilege to use...Fast, seems very stable,tilt control(which never did properly),network location(again never did) working well and list goes on...
BUT sorry there's a but some apps that I had installed on sowas v5 rom nolonger work, Temble run, dog fight(ww1 flight sim),CS Portable,Car Armageddon and quite a few others nolonger started up or start but returns straight to the desktop... Is there a reason why and if so is there a fix?? also what was the fix for bbc Iplayer?? Or is it going to be simpler to return to sowas 5sRC rom???  Seems a shame to leave this rom yet again....
regards Lohtse
PS
Forgot to ask but when will gps setup get added to settings menu??
lohtse
Forum Posts: 157
655
2012/04/18 - 07:24
Apologies but further to my last post the following has now come too light!!!
Firstly some apps will not see the physical sd card(google earth,soviet mil maps) yet others do and write etc too it..
Secondly Osmos HD will not start and gives the following error message" your screen size is too small for HD please install handset version"  WTF it ran on Sowa's rom!!!(http://www.freaktab.com/showthread.php?364-ROM-ARNOVA-8G2-8Gb-ROOT-Market-Google-apps-ext4-fs-1Gb-user-space-by-Sowa)
Finally battery Drain!!!!! Well this is horrendous!!! In 6 hours of just sitting(well I was a sleep) doing nothing it totally drained the battery and I do mean TOTALLY drained the battery.. On previous rom with same apps and setup it would drain 4-8% in that same time!!!And could go all day of general to heavy usage (12hrs) with full brightness and least 2 hours on wifi and would still have 30-40% battery left. Very much doubt will get even close to 4 hours of use and standby time after it drained completely over night with no activity!
Due to all issues mentioned had reflashed Sowa's v5sRC…Shame as loved having tilt controls working properly in games(the ones that actually worked on this rom!),The status bar disappearing when apps went full screen and location awareness!!!Is there away to copy the drivers/required files to other roms?????If so could you provide a zip/rar file with the files required and instructions where they go?
regards
Lohtse
PS Tablet is AN8 G2 8gig also the rom flashed was the Sowa mod version of morkas rom...
nutuma
656
2012/04/18 - 17:25
Hi Morka,
(Arnova 9G2)  I tried to flash the 1.16 Beta (Fix Boot) but what I got was a black screen, nothing else; after that couldn't power on the tablet; tried to flash the previous version, which, BTW, I had installed and I got the same thing, a black screen with the MOD 1.15.2; so now I installed the stock version to be able to use the tablet again, because I cannot get your MOD installed.
Do you have any idea why I cannot now install even the 1.15.2???
The installation went well; I got a  success notification, but the tablet never restart after.
lohtse
Forum Posts: 157
657
2012/04/18 - 17:25
reflashed with previous rom(in link above) battery is fine again, 7 Hours, most of which tablet was in use and not plugged in to mains at anytime during that time(7hrs) and at least two hours on wifi, screen at full brightness and still 23% battery,Apps install and run with no issues too....
For me this rom is too buggy...
Hope to see an update or the ability to add files etc as I have stated in previous post..
Viestarts
658
2012/04/19 - 19:52
wyvern
659
2012/04/22 - 11:58
I can't get the cifs.ko module to load using v1.15 downloaded today on a 9G2.
I've tried loading slow_work first, and messing with the order, but dmesg gives variosu unknown symbol messages.
Anything special that needs to be done with MorkaMod to get cifs mounting working?
Great work otherwise though 🙂
Cheers
Wyv
chrislharper23
660
2012/04/22 - 22:45
Hello
I've managed to update my gf's Arnova 9 G2 with this firmware. It's excellent! 🙂
Can anyone help me with the following....
The tablet only powers up/boots up when the USB is attached. If I plug the power cable in instead, it gets stuck in the boot up loop (Arnova logo comes on, stays on a few seconds then goes off. Then it does this repeatedly. I'm not sure whether it's something I did before rooting it using the ArcTools app??
Any help will will be appreciated. Thanks.
Chris
67 Guest(s)
2 Guest(s)
Devices in use: Desktop (57), Phone (10)
swan12
heftpflaster
