Related Tags
Thanks Received: 3177
31
2012/02/17 - 12:08
Arnova 10 G2 version does not work for me (Arnova 10 G2 resistive 8 Gb model).
The boot screen shows garbage, it probably doesn't like the boot image made for smaller resolution.
then device get stuck on black screen while booting, adb logcat gives looping stack traces such as:
I/DEBUG ( 1961): #00 pc 0002a654 /system/lib/libGAL.so
I/DEBUG ( 1961): #01 pc 00001172 /system/lib/hw/copybit.rk29board.s
o
I/DEBUG ( 1961): #02 pc 00014828 /system/lib/egl/libGLES_android.so
I/DEBUG ( 1961): #03 pc 000265de /system/lib/libsurfaceflinger.so
I/DEBUG ( 1961): #04 pc 0001f292 /system/lib/libutils.so
I/DEBUG ( 1961): #05 pc 0001ee68 /system/lib/libutils.so
I/DEBUG ( 1961): #06 pc 0000cf34 /system/lib/libc.so
I/DEBUG ( 1961): #07 pc 0000ca88 /system/lib/libc.so
I/DEBUG ( 1961):
I/DEBUG ( 1961): code around pc:
I/DEBUG ( 1961): 84d2a634 e3a00008 e3a03004 e5810000 e3a00000
I/DEBUG ( 1961): 84d2a644 e5823000 e12fff1e e3e0000c e12fff1e
I/DEBUG ( 1961): 84d2a654 e5903004 e593000c eaffab65 e5900004
I/DEBUG ( 1961): 84d2a664 e590000c eaffc4a5 e5903004 e593000c
I/DEBUG ( 1961): 84d2a674 eaffbd44 e5900004 e590000c eaffc560
I/DEBUG ( 1961):
I/DEBUG ( 1961): code around lr:
I/DEBUG ( 1961): 84c01154 bf00e7be 0000173a 00001779 4604b510
I/DEBUG ( 1961): 84c01164 30a4f8d0 d0052b01 00b4f8d0 eec0f7ff
I/DEBUG ( 1961): 84c01174 bd10b110 bd102000 00b0f8d4 e8bd2101
I/DEBUG ( 1961): 84c01184 f7ff4010 0000bf09 4604b510 b0886f43
I/DEBUG ( 1961): 84c01194 b90b6dc1 d01129ff 20012202 2300b2c9
I/DEBUG ( 1961):
I/DEBUG ( 1961): stack:
I/DEBUG ( 1961): 48cd0e48 8021ede1 /system/lib/libutils.so
I/DEBUG ( 1961): 48cd0e4c 8352582b /system/lib/libsurfaceflinger.so
I/DEBUG ( 1961): 48cd0e50 00000258
I/DEBUG ( 1961): 48cd0e54 80229838 /system/lib/libutils.so
I/DEBUG ( 1961): 48cd0e58 00000000
I/DEBUG ( 1961): 48cd0e5c 8352f608 /system/lib/libsurfaceflinger.so
I/DEBUG ( 1961): 48cd0e60 00000000
I/DEBUG ( 1961): 48cd0e64 80d37a70 /system/lib/libui.so
I/DEBUG ( 1961): 48cd0e68 0012d770
I/DEBUG ( 1961): 48cd0e6c 8021ede1 /system/lib/libutils.so
I/DEBUG ( 1961): 48cd0e70 00000000
I/DEBUG ( 1961): 48cd0e74 00000000
I/DEBUG ( 1961): 48cd0e78 00000400
I/DEBUG ( 1961): 48cd0e7c 00000258
I/DEBUG ( 1961): 48cd0e80 df002777
I/DEBUG ( 1961): 48cd0e84 e3a070ad
I/DEBUG ( 1961): #01 48cd0e88 00099158
I/DEBUG ( 1961): 48cd0e8c 84b1482b /system/lib/egl/libGLES_android.so
The Arnova 10 G2 system image probably need Arnova 10 G2 specific modules/firmware files as Jekle suggested yesterday.
propprop
Forum Posts: 77
32
2012/02/17 - 12:17
thank you - I have flashed it now (I have 10G2 8gb Capacitive)
At this point the Arnova will reboot and go into recovery screen
- Nothing appears to be happening
-reboot sytem now
-Factory reset
-SYSTEM recover
update from SDCARD
confirm
I am guessing it is updating (but I can move the selection bar up and down) do I just leave it it has been nearly 5 minutes
33
2012/02/17 - 12:20
Don't expect too much to happen on your Arnova 10 G2, it seems there are small hardware issues with the Arnova 10 G2 that prevent it to boot, see my previous message #31
lohtse
Forum Posts: 157
34
2012/02/17 - 12:22
excellent work.... am curious to give it a try but would like to know how stable it is on the a8g2(8gig) as I have 320 apps on mine so reflashing and reinstalling is a pain...
regards
Lohtse
Jekle
UK
Forum Posts: 31
35
2012/02/17 - 12:23
o
I/DEBUG ( 1961):
I/DEBUG ( 1961):
I/DEBUG ( 1961):
I think your looking at the answer for the compatibly for the Resistive Model If you have a dump of the resistive firmware you will basically need to replace those files with the ones that the logcat is displaying. You will need Linux (Ubuntu)
In terminal do:
1.) sudo -i
 To enable the Root account (i.e. set a password) use:
2.) sudo passwd root
and then log out.
Then go to terminal make sure you're in the directory where the system image is: Get this the from the image folder on the 10 G2's Test Firmware.
e.g. cd /home/"your name"
then do is: mount -o loop system.img /mnt (I've only used /mnt as an example any empty folder can be used)
You might want to do this command for stock firmware first and grab the files that logcat displayed.
and copy and replace then do:
umount /mnt (or whatever directory you used)
I told you do enable root login. as even if you have sudo privileges it will not work.
Laugh
and then copy the system.img you mounted and replaced those files. and then copy back the image folder with the flash utility.
propprop
Forum Posts: 77
36
2012/02/17 - 12:27
I think once it has flashed on the PC - I believe it should continue to install the firmware on the 10G2 but this does not appear to happen it only boots to recovery and sits there - if it is this - this could be due to 10G2 having a different/older recovery
I am happy to continue to test but I am away till Sunday - leaving soon
37
2012/02/17 - 12:29
Thanks Jekle for the details, I hope some other devs will give it a shot, I am quite busy here finishing a big  update on the Arctablet kitchen
Jekle
UK
Forum Posts: 31
38
2012/02/17 - 12:32
How advanced is the kitchen? Or is it basic like changing boot animation etc.
39
2012/02/17 - 12:35
I want to make it as generic as it could be, for all RK2918 firmwares.
So far, adding su/Superuser and Android Market, adding fenice57 kernel modules.
We can discuss it in more details in the kitchen forum topic.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
40
2012/02/17 - 13:55
Thank you for your report
I did not 10G2
firmware for the 10G2
https://rapidshare.com/files/4046073303/Arnova10G2.UI.3.SDK.2.1.RK29XX.test2.zip
o
I/DEBUG ( 1961):
I/DEBUG ( 1961):
I/DEBUG ( 1961):
propprop
Forum Posts: 77
41
2012/02/17 - 14:01
is everyone getting 30KB/s on rapid5hare - its not my internet - over an hour to download and i gotta leave in an hour - damnnnn 🙁
oh and cheers for another file to test so soon
Mrcapo
42
2012/02/17 - 14:03
Anyone tested this on 7G2 with the new fix. Am too chicken to flash it yet and I am fond of my current romEmbarassed
Morka
Lille
Forum Posts: 203
Thanks Received: 75
43
2012/02/17 - 14:04
if you have a good file hoster?
propprop
Forum Posts: 77
44
2012/02/17 - 14:17
4shared.com
or
hotfile.com
rapidshare does normally work faster than this (might be due to loss of connection undersea from holland) im on 15% 🙁
Morka
Lille
Forum Posts: 203
Thanks Received: 75
45
2012/02/17 - 14:34
propprop said
4shared.com
or
hotfile.com
http://www.4shared.com/zip/yI-Y6nSn/Arnova10G2UI3SDK21RK29XXtest2.html
52 Guest(s)
Devices in use: Desktop (46), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
