2012/01/03
Morka said
Hi all
I built this firmware from Smartpadvandinz
For the wifi connection
IP address : 192.168.1.xxx static IP from 105 to 255
Gateway: 192.168.1.1 Corresponds ip address to the connection to router for my router (192.168.1.254)
opens firefox to write the ip address if you connect to the router
I thought of a possible fix. Opening up the Firmware and getting these files/folders from stock
etc\firmware - copy the whole folder
lib\modules\wlan.ko
Not sure it that will fix it but when I got wifi working with CyanogenMod on 7 G2 it worked.
2012/01/23
Morka said
Hi all
I can't connect at all with that. Here's my settings.
IP Address : 192.168.1.105
Gateway : 192.168.0.1
Netmask : 255.255.255.0
DNS1 : 8.8.4.4
The Gateway : 192.168.0.1 is the IP I type to get to my router settings. Is this what you meant? If I type IPCONFIG into my CMD it says that the default gateway is 192.168.0.1
With your original settings I can connect to the WIFI but have no Internet, with the settings pointing to my router I can't even get a connection to WIFI.
Jekle : How do you open the firmware. I'm willing to try that and see if it works.
2012/01/23
It's weird. It says I'm connected to the WIFI but I can't get any Internet pages open. Could it be a setting in the router? I've no idea how these things work.
EDIT* I've changed the settings on my daughters phone to match the tab and even though the WIFI connected the same as the tablet did, I can't use the net on that either so it looks like it's an issue with the router. No idea what so I'll have to dig around. Sorry to mess you around. If anyone has any ideas what I might change to fix it please let me know.
2012/01/03
vandinz said
Morka said
Hi all
opens firefox to write the ip address if you connect to the routerI can't connect at all with that. Here's my settings.
DNS1 : 8.8.4.4
It's as easy as downloading root explorer. Mount R+W and place the files in the directories above. and reboot. It's just a try. I haven't tried this firmware yet.
Hi all~ like to say fantastic work on this rom. It's nice to have something other than 2.3 now. However, am I right in saying this ROM isn't fully rooted? I'm trying to run Titanium backup and a few other root dependant apps and they report that I'm not rooted. Any ideas? Thanks.
2012/01/06
Final firmware for 8G2 ,7G2 and test1 10G2
fixe It doesn’t shut down
fixe wifi connect
fixe rooted for app (exemple Titanium backup) no full rooted
add kernel.img for 10G2 (test1)
news boot animation Honeycomb
rename model for market (Arnova)
update witch RKAndroidTool
https://rapidshare.com/files/3194262657/Arnova.UI.3.SDK.2.1.RK29XX.final.zip
update witch Rockchip Batch Tool for Arnova 8G2
https://rapidshare.com/files/3864805517/update_Arnova8G2.UI.3.Final.img
Report if there have a problem please thank you all have
2011/12/01
Hi morka
Excellent work. I am particularly pleased that appear ROM is fully processed, and not just another revision of the original.
One question. In the revised version /system remained as cramfs?
Sowa
China phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
2012/01/06
Sowa said
Hi morka
Sowa
hi Sowa
yes
because this file system is a protection for the beginner ( no file system can be change )
is if you want I wanna give you a dump of the file system for you offer an alternative to this one
2012/02/09
propprop said
excellent work so impressed - I have a 10G2 😀 will - hope it plays well - I am on kastyv2 at the minute but gonna test this - those rapidshare links are abnormally slow - will take half a day???
Finding the same with rapidshare link. Hoping to give this a blast on my 7G2 but not sure if I will be able to restore my apps with Mybackup pro given the root situation??
propprop said
there was no kernel.img in this folder only in 7G2 8G2
My tablet is Arnova 10G2
There is a kernel.img file in AR10G2 folder.
Make sure you have downloaded the latest archive:
77 Guest(s)
Devices in use: Desktop (63), Phone (14)
forty42
samih
macsierra2
sachatanya
Nursat
MaXXWar
