Related Tags
davis15
181
2012/02/25 - 11:33
Sorry, how i can install in my arnova 9 g2?
Now i use custom firmware finless 1.3
Please help me
propprop
Forum Posts: 77
182
2012/02/25 - 11:45
infact Finless that not so pretty finless boot image that cannot be changed on your rom - just for this reason i will not use it - no offence i think your work is probably the best but I am picky in what I will allow also
Morko - take your time on this rom or maybe you will look into doing something with ICS once it is release for rock2918 g9 🙂 either way I hope you will continue to try to improve this for 10 G2
carlososk8
Forum Posts: 27
183
2012/02/25 - 15:24
Plz fix the batery.... and if you can active the ad-hoc mode....... the games run excelent arnova7g2
Iglo
Forum Posts: 45
184
2012/02/25 - 16:00
@Morka, are your sources available somewhere ? It could be nice to share them. 🙂
lohtse
Forum Posts: 157
185
2012/02/25 - 17:45
hi all
What's the advantages of this rom compared to Sowa's v5 rom over on freaktab?
alex
Forum Posts: 252
186
2012/02/25 - 20:25
morka the 9g2 orientation is messsed up its always 90 degrees clockwise from how your actually holding it
Iglo
Forum Posts: 45
187
2012/02/26 - 12:01
Morka, did you build the kernel from the ODYS sources ?
Here is the logcat when I launch the game "They need to be fed" :
D/ApplicationAdapter( 360): setChildDrawingCache enable true
D/opinions-on-teclast-p90hdstcompa( 102): win title: Starting com.yoyogames.droidtntbf ;support: true ;targetVersion: 8
I/ActivityManager( 102): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.yoyogames.droidtntbf/.RunnerActivity } from pid 360
I/ActivityManager( 102): Start proc com.yoyogames.droidtntbf for activity com.yoyogames.droidtntbf/.RunnerActivity: pid=1265 uid=10051 gids={}
W/dalvikvm( 1265): DexOpt: Spurious dep data? 615 vs 706
D/dalvikvm( 1265): Trying to load lib /data/data/com.yoyogames.droidtntbf/lib/libopenal.so 0x40513570
D/dalvikvm( 1265): Added shared lib /data/data/com.yoyogames.droidtntbf/lib/libopenal.so 0x40513570
D/dalvikvm( 1265): Trying to load lib /data/data/com.yoyogames.droidtntbf/lib/libyoyo.so 0x40513570
D/dalvikvm( 1265): Added shared lib /data/data/com.yoyogames.droidtntbf/lib/libyoyo.so 0x40513570
D/dalvikvm( 1265): No JNI_OnLoad found in /data/data/com.yoyogames.droidtntbf/lib/libyoyo.so 0x40513570, skipping init
I/yoyo ( 1265): @@@@@@@ Build.Display = MorkaMod BRAND=rockchip DEVICE=rk29sdk MANUFACTURER=unknown MODEL=Arnova PRODUCT=rk29sdk
I/yoyo ( 1265): @@@@@@@ XPeriaPlay=false manufacturer=false model=false
I/yoyo ( 1265): deviceId=2b3f090b951ab2c2
I/LicenseChecker( 1265): Using cached license response
I/yoyo ( 1265): !!!!##### Successful license check #####!!!!!!
I/yoyo ( 1265): onResume
D/opinions-on-teclast-p90hdstcompa( 1265): win title: com.yoyogames.droidtntbf/com.yoyogames.droidtntbf.RunnerActivity ;support: true ;targetVersion: 8
D/libEGL ( 1265): loaded /system/lib/egl/libEGL_VIVANTE.so
E/libEGL ( 1265): load_driver(/system/lib/egl/libGLESv1_CM_VIVANTE.so): Cannot load library: reloc_library[1311]: 63 cannot locate 'gco3D_SetWPlaneLimitF'...
D/libEGL ( 1265): loaded /system/lib/egl/libGLESv2_VIVANTE.so
I/ActivityManager( 102): Displayed com.yoyogames.droidtntbf/.RunnerActivity: +832ms
W/dalvikvm( 1265): threadid=10: thread exiting with uncaught exception (group=0x40015560)
E/AndroidRuntime( 1265): FATAL EXCEPTION: GLThread 11
E/AndroidRuntime( 1265): java.lang.RuntimeException: createContext failed: 0x0
E/AndroidRuntime( 1265): at android.opengl.GLSurfaceView$EglHelper.throwEglException(GLSurfaceView.java:1080)
E/AndroidRuntime( 1265): at android.opengl.GLSurfaceView$EglHelper.throwEglException(GLSurfaceView.java:1072)
E/AndroidRuntime( 1265): at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:928)
E/AndroidRuntime( 1265): at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1264)
E/AndroidRuntime( 1265): at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1118)
I/yoyo ( 1265): onPause
W/ActivityManager( 102): Force finishing activity com.yoyogames.droidtntbf/.RunnerActivity
D/opinions-on-teclast-p90hdstcompa( 102): win title: Désolé ! ;support: true ;targetVersion: 9
carlososk8
Forum Posts: 27
188
2012/02/27 - 17:33
the only thing I have to say is that with this rom emulators for ps1n64oid and work great .. are all gameloft games and flash 11 works fast and well sper ... the launcher is perfect my onlycomplaint is the volume control on the bar and the status of the battery that appears (?) but I hope that it can Morka arrelar: Deverything else this great rom much better than the other 2 thereroms .. Morka is so! ARNOVA 7g2!
carlososk8
Forum Posts: 27
189
2012/02/27 - 18:52
Hi, I have another option to the problem of blocking the options bar at the ARNOVA without butoms hardware, I use the buttonsavior but has no volume buttons, however I found in the virtualmarket buttom and configured with 8 buttons set which nesesitabaand disable the last option to cancel after precionar and perfect ...recommend as the best option button savior ... Try it you can change color and size all excellent!
carlososk8
Forum Posts: 27
190
2012/02/28 - 04:57
the x and y are wrong with the accelerometer arnova 7g2
Thanks Received: 3171
191
2012/02/28 - 14:28
I have moved all Finless boot image "discussions" in this topic.
Let's try to keep this current topic focused on Morka's firmware, thank you.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
192
2012/02/28 - 19:47
@Iglo
The only sources I could find for Rockchip
there as a tutorial
http://www.androidiani.com/forum/mediacom-smartpad-810c/82542-guida-compilare-il-kernel-rk2918.html
What's new 2012.02.28 Test SDK original for AR10G2
Simple test to find compatibility with arnova10G2
addition to test flash player 11 in pre-installation
adding the volume button on the status bar
adding Button_Savior
To be installed before any update for in logcat ex: Iglo
http://dl.dropbox.com/u/21567851/adb_platform-tools.zip
http://dl.dropbox.com/u/21567851/Arnova.10.UI.3.SDK.2.1.zip
Mirror
http://www.4shared.com/zip/4Q1XqlPI/Arnova10UI3SDK21.html
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
193
2012/02/28 - 20:27
Morko, can't download the SDK.  Even have an account on 4Shared and it just doesn't download the file.  If you have another way, I can host it on my Dropbox account.  I don't think the traffic here will kill me.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
194
2012/02/28 - 20:41
mirror Dropbox
I said that a test for a comeback with adb logcat
My adb with usb drives include
propprop
Forum Posts: 77
195
2012/02/29 - 01:17
Won't have time to test till tomorrow  - but good work ?
86 Guest(s)
2 Guest(s)
Devices in use: Desktop (77), Phone (9)
swan12
heftpflaster
