Related Tags
Iglo
Forum Posts: 45
166
2012/02/24 - 20:06
I can install any apk (with or without apk installer) but all of them force close at launch !
alex
Forum Posts: 252
167
2012/02/24 - 20:19
morka if flashed it onto my 9 g2.. working so faw will keep posted
carlososk8
Forum Posts: 27
168
2012/02/24 - 20:24
ok i flash again look the status batery dont work... plz help!
Morka
Lille
Forum Posts: 203
Thanks Received: 75
169
2012/02/24 - 21:03
test by pressing the hour if it works
Image Enlarger
Morka
Lille
Forum Posts: 203
Thanks Received: 75
170
2012/02/24 - 21:14
For AR10G2
I look for the source code to modify the lib of the screen
The problem of application or to force the closure of this lib as of screens
carlososk8
Forum Posts: 27
171
2012/02/24 - 21:31
ok i do it....show a % but dont change only if i restart the tablet. and dont show if i plug a charger o dont.
Reisen Inaba
Forum Posts: 22
172
2012/02/24 - 21:40
Battery issue on AN7G2 is still the same.
propprop
Forum Posts: 77
173
2012/02/24 - 23:05
For 10 G2 "Bugs with non latest SDK"
Angry birds loads up to black screen, before and after update of flash
Force Close on Gallery Open
Force Close on Camera Open
Force Close on Google Maps Open
Is it better - For Arnova 10 G2 - not to worry about fixes? but to make the SDK compatible then this will solve the issue? - but I know nothing - so imagine it is not easy - please take your time if you have time 🙂
Morka
Lille
Forum Posts: 203
Thanks Received: 75
174
2012/02/24 - 23:06
@carlososk8  and @Reisen Inaba
I may be wrong because the changes of themes ics for 7G2
@propprop
For this to work I use the libGAL.so the original firmware
The only source that exists for rk29xx
http://hg.tommorris.org/jordonwu/android_kernel_andypad/src/4c6b4f4c48d1/drivers/video/display/screen/lcd_byd1024x600.c
A8G2
175
2012/02/24 - 23:29
on the 8G2, the camera works fine for taking photos, but for recording it goes all funny, green and back etc, you hit record, I let it record for a second or two, stopped it, attempted to play back the file, and it threw up a cannot be played error.
Flawless so far, apart from the camera.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
176
2012/02/24 - 23:39
camera in video mode (but not recording problem of encoding library)
For its function selects low resolution but not record
finless
Stanton, Ca
Forum Posts: 604
177
2012/02/25 - 01:01
My report.
Loaded all the versions by Morka that actually boot.
ROM is slower by a good margin even over stock ROM.  But the features, SystemUI.apk, Settings, Networklocation, etc works and other things or features are very nice.  It is still very unstable on the Arnova 10 G2 even when not using hardware like the camera.  But this is a pretty nice piece of work!  It would not be my "use" ROM but it is fun to play with for sure.  A taste of something better over stock Gingerbread!
Market rejects you from using specific Gingerbread made apps.  Market recognizes this ROM as Honeycomb and thus the refusal to install Gingerbread apps.  I think I have a fix for this but I am not going to spend time on it right now.
In the end this is a fun ROM to play with if you have the time.  On the other hand it's at least worth flashing so you know what good stuff Gingerbread should have in it!!!!!
Morka, "props" for your work on this!
My .0000002 cents 🙂
Bob
carlososk8
Forum Posts: 27
178
2012/02/25 - 02:09
i discover the diferens is 2 aplications (batery status and spareparts) may be this is why dont work the batery status?
Iglo
Forum Posts: 45
179
2012/02/25 - 09:00
I have the same issues as propprop, any game get stuck at black screen (e.g. : Angry Birds, They need to be fed, World of Goo...).
propprop
Forum Posts: 77
180
2012/02/25 - 10:14
I believe Morko and Finless should combine their work
70 Guest(s)
2 Guest(s)
Devices in use: Desktop (60), Phone (10)
swan12
heftpflaster
