Related Tags
propprop
Forum Posts: 77
151
2012/02/24 - 09:32
Morka said
Tests the old application
http://www.4shared.com/android/4xsKoIQs/Gallery3D.html
http://www.4shared.com/file/Bxi_UpHQ/Camera.html
I don't know how to install these apks sorry .does not instal over system, and placing in system/app does not allow. do you think it will be possible to have a future final version with fixes, you have done so much good work loo
Angry birds loads up to black screen, before and after update of flash
Force Close on Google maps open.
carlososk8
Forum Posts: 27
152
2012/02/24 - 16:34
i gona test the final version of the arnova 7g2 in my last test every works fine!! but the batery status dont work is ok in the last version?? tnks for all your work!!!! its very nice!
carlososk8
Forum Posts: 27
153
2012/02/24 - 17:18
hi.  I tested the version 24-02-2012 arnova 7g2 and when I turn it on.... the tablet is white screen...is a problem with the kernel?
Reisen Inaba
Forum Posts: 22
154
2012/02/24 - 17:43
Also getting a white screen on AN7G2, will flash back to previous ROM until fixed.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
155
2012/02/24 - 17:44
thank you
I make a patch
sorry
My folder name file for fix : Arnova.7G2.1.UI.3.SDK.2.1.3.img in progress sending
http://www.4shared.com/folder/w1sPQuAi/_online.html
@propprop
errors corresponds to the lib of the screens and I find no source for this resolution 1024x600
is not compatible with new sdk will I seek a solution
Copy the file to the sd card and with ApkInstaller replace install
lohtse
Forum Posts: 157
156
2012/02/24 - 18:01
am a little confused...
is this android 3.2 or is it 2.3.1(same as stock) just themed to look like honeycomb(3.2)????
Morka
Lille
Forum Posts: 203
Thanks Received: 75
157
2012/02/24 - 18:30
This is a Rockchip SDK android 2.3.1 with a GUI android 3
carlososk8
Forum Posts: 27
158
2012/02/24 - 18:30
Tnks im dowloading----------------- the new
propprop
Forum Posts: 77
159
2012/02/24 - 19:08
application not installed
When I try with apk installer.
carlososk8
Forum Posts: 27
160
2012/02/24 - 19:14
ok its run..... the batery status dont work....
Morka
Lille
Forum Posts: 203
Thanks Received: 75
161
2012/02/24 - 19:35
parameter in the application
checkmarks source unknown
@carlososk8
See me it works
What you use tablet?
Image Enlarger
carlososk8
Forum Posts: 27
162
2012/02/24 - 19:46
@carlososk8
See me it works
i use a arnova 7g2. 🙁 but don't work still in (?) im gon to re flash everithing to test again..
Morka
Lille
Forum Posts: 203
Thanks Received: 75
163
2012/02/24 - 19:51
carlososk8 said
@carlososk8
See me it works
Link to the corrected version
http://www.4shared.com/file/bpsFMTwi/Arnova7G21UI3SDK213.html
propprop
Forum Posts: 77
164
2012/02/24 - 19:59
in my settings I always allow unknown sources
It is the first thing I do, I also double checked to make sure it was set already
carlososk8
Forum Posts: 27
165
2012/02/24 - 20:04
yes this i was tested and dont show me the batery status.
65 Guest(s)
Devices in use: Desktop (58), Phone (7)
swan12
heftpflaster
