Related Tags
propprop
Forum Posts: 77
136
2012/02/23 - 12:41
Fixed : You tube application (Doesn't work when flash is updated - loads app - plays audio - blank video)
bug: When I press the home button whilst browsing the net it will not return to the homescreen
bug: still cannot exit picture of apps viewed in google market (restart needed)
my applications are still there after reboot must have been an erroneous issue, so ignore previous bug regarding this
Reisen Inaba
Forum Posts: 22
137
2012/02/23 - 18:13
Ok I've been using this ROM alot now and have found another bug ..on the AN7G2 it seems the battery icon on the stays bar has a ? Symbol in it, but when opening the status bar there is a battery percentage. I tried a battery widget and that seemed to cause problems as the tablet could no longer tell if it was on charge or not. I don't know if any other AN7G2 users have the same problem.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
138
2012/02/23 - 18:53
Bug of the battery and the home button is the ace for my mistake I did wrong the theme ics
camera, gallery, youtube and flash player 11
everything will be resolved in the final vesion for all G2
alex
Forum Posts: 252
139
2012/02/23 - 19:23
Morka said
alex said
Morka i know you have alot on you plate but would you be kindenough to make a 9g mod for the pretty people according to finless when he created a rom for this device the process is exactly the same
here is the test for a 9G2
If you can give me a report if possible
and as the 7G2 and 10G2 problem with the status bar in full screens
Arnova.9G2.UI.3.SDK.2.1.3.RK29XX.test1.img
morka can you please upload again as the link is broken sorry for long reply just been abit busy latey
propprop
Forum Posts: 77
140
2012/02/23 - 19:42
alex
Forum Posts: 252
141
2012/02/23 - 19:50
thanks propprop, i think morka might have fixed it 😉 will let you know morka how it goes
propprop
Forum Posts: 77
142
2012/02/24 - 01:13
Just a quick question, why did you change the browser from test 3, back to this one we are using? Test 3 was the dark/black browser.
also I am unsure if this is a bug, but I can not reply in this forum using the latest ROM. The keyboard does not open this is probably because a cursor is not available in the reply box.
Looking forward to your final versions 🙂
Morka
Lille
Forum Posts: 203
Thanks Received: 75
143
2012/02/24 - 01:26
What's new 2012.02.24 for Arnova MorkaMod
Fixed themes ics
Fixed home button
Fixed youtube with flash player 11
Fix all the problem
Adding Root Explorer HD (in Chinese translation that I would do later)
Adding PointerLoction to screen test, The SDK because it automates the calibration
Arnova 10G2 in final version
Arnova 9G2 in final version
For the 7G2, 9G2 and 10G2 not yet resolved the status bar for full screen
Button Savior install to fix this issue Thanx Pulster for the tip.
MorkaMod for Arnova 7 G2 SDK 2.1.3
SDK.2.1.3.Arnova.7G2.UI.3.Final.img
MorkaMod for Arnova 8 G2 SDK 2.1.3
SDK.2.1.3.Arnova.8G2.UI.3.Final.img
MorkaMod for Arnova 9 G2 SDK 2.1.3 SDK.2.1.3.Arnova.9G2.UI.3.Final.img
MorkaMod for Arnova 10 G2 SDK 2.1.3 SDK.2.1.3.Arnova.10G2.UI.3.Final.img
Morka
Lille
Forum Posts: 203
Thanks Received: 75
144
2012/02/24 - 01:38
This is a theme download but not compatible with this sdk you in this paramettre a browser user agent switcher
propprop
Forum Posts: 77
145
2012/02/24 - 01:55
installed SDK.2.1.3.Arnova.10G2.UI.3.Final.img
flashed fine, booted into recovery
pressed "confirm" to reboot
passed "ARNOVA" screen
passed "android boot" screen
however it remained on a blank/black screen after the android boot screen for 15 minutes - please advise (btw cant wait to enjoy your good work 🙂
Morka
Lille
Forum Posts: 203
Thanks Received: 75
146
2012/02/24 - 02:31
propprop
Forum Posts: 77
147
2012/02/24 - 02:44
The same occurs with new fix
flash ->reboot ->recovery-> confirm reboot->pass ARNOVA->pass "android boot"->freezes at black screen
now nearly 20min on black screen.. I will turn it off
Morka
Lille
Forum Posts: 203
Thanks Received: 75
148
2012/02/24 - 03:18
The only fix that will have
Fixed themes ics
Fixed home button
Fixed youtube with flash player 11 Not because of the lib 10g2 have a problem with the sdk
http://www.4shared.com/file/SGZmNZ0O/Arnova10G22UI3SDK213.html
Sorry to offer a version not yet resolved
propprop
Forum Posts: 77
149
2012/02/24 - 03:32
All your work is appreciated
This time it boots into the ROM fine 🙂
I will test more tomorrow it is very very late. Need Zzzzzz
Force close on camera open
Force close on gallery open
Morka
Lille
Forum Posts: 203
Thanks Received: 75
150
2012/02/24 - 04:10
Tests the old application
http://www.4shared.com/android/4xsKoIQs/Gallery3D.html
http://www.4shared.com/file/Bxi_UpHQ/Camera.html
106 Guest(s)
Devices in use: Desktop (92), Phone (14)
swan12
heftpflaster
