[MorkaMod] Android 3 Honeycomb look on Arnova 7 G2, 8 G2, 9 G2 and 10 G2 (releases topic)
Related Tags This topic is locked
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/03/31 - 12:01
This topic is dedicated in announcing new Morkamod releases, posting here is allowed only to Morka, for any problem or question on Morkamod firmware, please use Morkamod support topic.
If you like this firmware and want to support the developer feel free to donate using the Paypal button
What's new 2012.04.11 :
- MorkaMod v1.16
- Fast and stable version
- Adding drivers for the bluetooth, bluetooth GPS, GPS usb2serial and USB Ethernet
- Ext3 version add manually your drivers in the folder "/system/lib/modules" after rebooting your hardware connected
- Improvement of the theme even more beautiful
News test benchmark  2652
Image Enlarger
MorkaMod 1.16 for Arnova G2 Filesystem Ext3
MorkaMod 1.16 for Arnova 7 G2               in creating
MorkaMod 1.16 for Arnova 7b G2 capactive
              in creating
MorkaMod 1.16 for Arnova 8G2 Dual Touch
              in creating
MorkaMod 1.16 for Arnova 8 G2 AR8G2.ext3.2G.MorkaMod.v1.16.zip
MorkaMod 1.16 for Arnova 9 G2               in creating
MorkaMod 1.16 for Arnova 10 G2               in creating
(Flash with Rockchip flashing tool)
MorkaMod 1.16 for Arnova G2 Filesystem Ext4
Compatible ARNOVA 8G2 4Gb (not to use size of userdata 4 Gb)
    By Sowa
Made a version for ARNOVA 8G2 8Gb capactive with the /systems in a format ext4 filesystem.
Has updated some Google applications.
You can select the size of userdata (select parameterX file when flashing) 1, 2, 4 Gb
AR8G2.ext4.MorkaMod.v1.16.zip
What's new 2012.04.03 :
- Adding RK29xxLoader(L)_V2.14.bin
- Changing recovery v4 add formatting to ext4
- Adding the battery charging ics
– Added 7bG2 capacitive model in version 1.15
– Added 8G2 Dual Touch in version 1.15
- Fixed startup 9g2
- Remove google play Movies, download the google play (com.google.android.videos)
MorkaMod 1.15 for Arnova G2 Filesystem Cramfs
MorkaMod 1.15 for Arnova 7 G2 update.AR7G2.cramfs.2G.MorkaMod.v1.15.img
MorkaMod 1.15 for Arnova 7b G2 capactive
update.AR7bG2.cramfs.2G.MorkaMod.v1.15.img
MorkaMod 1.15 for Arnova 8G2 Dual Touch
update.AN8G2DT.cramfs.2G.MorkaMod.v1.15.img
(download removed for the moment, by admin)
MorkaMod 1.15 for Arnova 8 G2 update.AR8G2.cramfs.2G.MorkaMod.v1.15.img
MorkaMod 1.15 for Arnova 9 G2 update.AR9G2.cramfs.2G.MorkaMod.v1.15.2.img
MorkaMod 1.15 for Arnova 10 G2
Stable but not compatible flash player 11
update.AR10G2.cramfs.2G.MorkaMod.v1.15.img
What's new 2012.03.30 :
– Correction of errors found in version 1.14
– The original values ​​ro.product.model Should Be: AN7G2, AN8G2, AN9G2, AN10G2
– Adding a cache for the SD card increase the speed of transferred
– Best management functions similar to CPU scaling
– Increasing the size system.ext3.img for instalation examples Chainfire3d
– Instalation faster
– Installation is done using Rockchip_Batch_Tool
– update Google Map 6.5.0
– Adding Google Play Movies 1.4.11
http://www.arctablet.com/users/forum/AR8G2.ext3MorkaModv1.15.zip
http://www.arctablet.com/users/forum/AR9G2.ext3MorkaModv1.15.zip  (not working)
remove the flash 11 is not compatible with 10G2
http://www.arctablet.com/users/forum/AR10G2.ext3MorkaModv1.15.zip
The 7G2 model I'm working to correct the problem of batery
Beta testing of the fix all problem for the model 7G2
http://www.arctablet.com/users/forum/AN7G2MorkaModv1.15cramfsbeta.img
(flash with Rockchip flashing tool)
ohne_worte
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/03/31 - 12:13
Previous releases history.
Final firmware for  7G2,7bG2,8G2,9G2 and 10G2
big thanks all got what we participate in this creation
in particular Propprop , Iglo and Admin for their tests on AR10G2
What's new 2012.03.24 :
– Fix Camera with green line and correction of the video mode
– Fix Some of you Bluetooth connection error
– Fix Battery happens as 10% icons disappear
– Fix is the rotation corrected gallery
– Fix sensor sensitivity more accurate
– Fix boot logo fix for AR9G2
– Adding a virtual memory to free memory ram (seen on a fast loading games)
– Adding a new framework-res
– Adding GooglePlayStore-3.5.15
– Adding adb tool and the correct drivers for windows 32/64bit(for backup and logcat)
– Improvement status bar transparency (100% transparency on different window)
– Removal of any applications not authorized to download
– Adding a module (openvpn, iptables ect ..)
– Adding a function similar to CPU scaling for v1.14 ext3 here is the result of a benchmark (2601 record on a 1Ghz RK2918)
a score reaches with applications like Cpu Master Free
http://www.arctablet.com/users/forum/AR7G2MorkaModv1.14.zip
http://www.arctablet.com/users/forum/AR8G2MorkaModv1.14.zip
http://www.arctablet.com/users/forum/AR9G2MorkaModv1.14.zip
Versions ext3
http://www.arctablet.com/users/forum/AR7G2.ext3MorkaModv1.14.zip
News Models http://www.arctablet.com/users/forum/AN7BG2.A70HT3.ext3MorkaModv1.14.zip beta test
http://www.arctablet.com/users/forum/AR8G2.ext3MorkaModv1.14.zip
http://www.arctablet.com/users/forum/AR9G2.ext3MorkaModv1.14.zip
Compatible flash player 11
http://www.arctablet.com/users/forum/AR10G2.ext3MorkaModv1.14.zip
system.img for 10g2 stable but not compatible flash player 11 (download AR10G2.ext3MorkaModv1.14.zip)
http://www.arctablet.com/users/forum/system.img.AR10G2.ext3.stable.zip
Version ext4
Mod by Sowa for ARNOVA 8G2 8Gb capacitive
What's new for Morka Mod v1.13 2012.03.12 :
Deleting icons 3g and Ethernet side of the hour (will be active connection of equipment)
Ics adding icons for applications
Update of all applications google (google play 3.4.7 etc .. )
Each model will be rename tablets for compatibility with the application google play
Increased performance 10 (compared to previous versions)
Changing the keyboard (a request of members)
Rotation correction on 9G2
I also post built system.img which wishes to delete the apk or add the apk own
to edit the file build.prop ect ..
Fonctionne for windows
 Updated with Arctabletool.exe
Image EnlargerImage Enlarger
What's new 2012.03.07 for MorkaMod 1.0:
Flash player 11 installed (start the browser to complete the intalation)
Stabilization system
Improvement of the theme ics
New wallpaper
Addition of simultaneous connections for up to 10 USB (have the equipment)
Adding connection usb-bluetooth, usb-3g, usb-eth, usb-gps, usb-modem (no tests done, I do not have the hardware)
Adding RKVideoplayer android 4 ics
Possibiliter to choose the size of memory for application in 1G, 1.5G, 2G (default selection) and 3G, select Parameter
Addition of any application
For update added Arctabletool.exe
Mode the camera does not record videos
For what have already installed MorkaMod uncheck Kernel and other select the right kernel for your tablet
AR10G2 to get there two version of a stable and the other for the tests to compile in the SDK 2.1.3_rk29_gingerbread_v2.10.03 ( Select a system in Arctabletool.exe system_test.img )
For sowa, finless or other developer
you could change, improve or add ect ..
installation for all g2 lasts 20 minutes and a startup takes 20 seconds after instalation
sorry but I had a lot of work behind
I would answer all your questions later
I would call MorkaMod 1.0
Fixed launcher3.0 for MorkaMod 1.0 :
Correction of the launcher (download a theme from a T760+SDK2.1+UI.4.0.rar) icon the market send to a Chinese site
Fixed display of Application
Launcher3.0.apk
What's new 2012.02.24 for Arnova MorkaMod
Fixed themes ics
Fixed home button
Fixed youtube with flash player 11
Fix all the problem
Arnova 10G2 in final version
Arnova 9G2 in final version
For the 7G2, 9G2 and 10G2 not yet resolved the status bar for full screen
Button Savior install to fix this issue Thanx Pulster for the tip.
What's new 2012.02.21 for Arnova MorkaMod:
Updated in SDK 2.1.3 ( rk29_gingerbread_v2.10.03 )
Fixed camera in video mode (but not recording problem of encoding library)
Addition of hardware acceleration 1024p
Zipalign all files
Restoration of the theme of this style ics for sdk 2.1.3
All application are installed google update
Better stability than the old version
News beta test for Arnova9G2
For the 7G2 and 10g2 not yet resolved the status bar for full screen
What's new test 4 for Anova10G2:
I make small precision tests because I did not AN10G2 and AN7G2
restoration was the original sdk Rockchip and modification of all the appliction system
for a resolution: 1024 x 600
addition of hardware acceleration 1024p
performance improvement (AntutuBenhmark score : 2594 on my arnova8G2)
What's new 12.02.15:
Market 3.4.4
Flash Player 11 (update with market)
1.3 GB of free memory for applications
Video Hardware acceleration (720p)
fixe It doesn’t shut down
fixe wifi connect
fixe rooted for app (exemple Titanium backup) no full rooted
add kernel.img for 10G2 (test1)
news boot animation Honeycomb
rename model for market (Arnova)
Screenshot Arnova.UI.3.SDK.2.1.RK29XX.final
Image Enlarger
Testing of multiple tache
Screenshot MorkaMod 1.0
Report if there have a problem please thank you all have
Indicate which tablet use and problem
Update witch Rockchip Batch Tool
MorkaMod latest info
MorkaMod 1.14 SDK 2.1.3 for Arnova 7 G2 MorkaMod-v1.14
MorkaMod-ext3-v1.14
MorkaMod 1.14 SDK 2.1.3 for Arnova 8 G2 MorkaMod-v1.14
MorkaMod-ext3-v1.14
MorkaMod 1.14 SDK 2.1.3 for Arnova 9 G2 MorkaMod-v1.14
MorkaMod-ext3-v1.14
MorkaMod 1.14 SDK 2.1.3 for Arnova 10 G2   Still some bug
MorkaMod-ext3-v1.14
system.img
MorkaMod Forum discussionBlog article
Exemple update firmware witch selection kernel.img
Image Enlarger
known error :
Youtube application (version 2.3.4) for AR10G2
Camera in video mode
tell me if you find any other error
I expected to report
to finalize a version v1
Thank you for giving good or bad report
____________________________________________________________________________________
Next update
Fixed addition of hardware acceleration 1024p more than 1GB (works on the final version and test3 but small on size 200mb and more)
Fixed performance improvement +10
Fixed zipalign files for faster startup of aplication system
7G2 for blocking the status bar for full screen mode without tablet function buttons idea of Reisen Inaba
Give your idea or improvement for the next update
I not change the file format (ext3 or ext4) for the beginner who modiffi of file system blocks and their tablet
Sorry for my translation
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/03/31 - 12:13
Reserved for Morka use
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/03/31 - 12:21
2012/04/04 - 12:30
New release by Morka, see first post.
2012/04/05 - 09:04
Fixed Arnova 9G2 release, see first post.
2012/04/11 - 18:25
MorkaMod being updated to 1.16, see first post
180 Guest(s)
2 Guest(s)
Devices in use: Desktop (173), Phone (7)
