[MorkaMod] Android 3 Honeycomb look on Arnova 7 G2, 8 G2, 9 G2 and 10 G2 (developers topic)
Thanks Received: 3170
2012/04/01 - 12:00
This topic is dedicated to developers who want to help improving MorkaMod.
If you have problems using MorkaMod, please use the specific MorkaMod support topic.
One area of improvement is checking if all the kernel modules work and if some eventually need to be disabled on startup if they are not necessary. They could later be loaded on demand after the system has started if needed.
We could first have a look at USB Bluetooth Dongle support and USB Ethernet.
Here is lsmod list:
scsi_wait_scan 478 0 - Live 0xbf37a000
gspca_main 19877 0 - Live 0xbf36f000
ipw 5572 0 - Live 0xbf368000
cdc_wdm 8358 0 - Live 0xbf360000
cdc_acm 15121 0 - Live 0xbf356000
navman 2337 0 - Live 0xbf350000
garmin_gps 14145 0 - Live 0xbf346000
cp210x 10753 0 - Live 0xbf33d000
mcs7830 4647 0 - Live 0xbf336000
sr9700 5491 0 - Live 0xbf32f000
hso 27995 0 - Live 0xbf317000
dm9620 9171 0 - Live 0xbf30e000
cdc_eem 2163 0 - Live 0xbf308000
cdc_ether 2803 0 - Live 0xbf302000
cdc_subset 1191 0 - Live 0xbf2fc000
usbnet 11678 6 mcs7830,sr9700,dm9620,cdc_eem,cdc_ether,cdc_subset, Live 0xbf2f3000
rtl8150 8835 0 - Live 0xbf2eb000
pegasus 17092 0 - Live 0xbf2df000
bcm203x 2830 0 - Live 0xbf2c2000
tun 10758 0 - Live 0xbf297000
slow_work 9251 0 [permanent], Live 0xbf251000 (P)
nls_utf8 986 0 - Live 0xbf24b000
nf_tproxy_core 1308 0 [permanent], Live 0xbf195000
xfrm_user 17461 0 - Live 0xbf167000
esp4 4590 0 - Live 0xbf160000
ah4 3423 0 - Live 0xbf15a000
af_key 29109 0 - Live 0xbf142000
zlib 2628 0 - Live 0xbf13c000
wp512 28842 0 - Live 0xbf12f000
twofish 6907 0 - Live 0xbf128000
lzo 1109 0 - Live 0xbf122000
lzo_decompress 2160 1 lzo, Live 0xbf11c000
lzo_compress 1729 1 lzo, Live 0xbf116000
crc32c 2554 0 - Live 0xbf110000
camellia 21551 0 - Live 0xbf105000
blowfish 7998 0 - Live 0xbf0fe000
aes_generic 30168 0 - Live 0xbf0f1000
sha1_generic 1689 0 - Live 0xbf0eb000
hmac 2507 0 - Live 0xbf0e5000
rk29xxnand_ko 865290 0 - Live 0xbf000000 (P)
2012/04/01 - 12:04
Reported so far:
by murigny64: Test usblan adapter on arnova7bg2 (c) with 1.14:
Nintendo dongle (asix AX88772): don't work
Dlink dub-e100 (asix AX88172): don't work
by me:  Arnova 10 G2, MorkaMod 1.15
Trendnet TU2ET100 USB Ethernet (should be ASIX AX88772): doesn't work
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/04/04 - 17:55
For the next version of the drivers to your hardware can be added simply
example: to add the bluetooth files .ko in the folder /system/lib/modules/bt
they will start automatically
register
Forum Posts: 84
2012/04/04 - 22:13
is the same possible for the usb-to-lan drivers?
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/04/12 - 01:27
Yes
Here is my startup file files. ko
#!/system/bin/busybox sh
baud=9600
device=ttyUSB0
#module="cdc_acm"
module="cp210x"
#module="pl2303"
binprefix="/system/bin/busybox "
modpath="/system/lib/modules"
#modpath="${ANDROID_ROOT}/lib/modules"
#prepare for openvpn
${binprefix} mkdir -p /system/xbin/bb
ln -s ${binprefix} /system/xbin/ifconfig
ln -s ${binprefix} /system/xbin/route
ln -s ${binprefix} /system/xbin/bb/ifconfig
ln -s ${binprefix} /system/xbin/bb/route
#insmod
insmod ${modpath}/crypto/authenc.ko
insmod ${modpath}/crypto/hmac.ko
insmod ${modpath}/crypto/sha1_generic.ko
insmod ${modpath}/crypto/aes_generic.ko
insmod ${modpath}/crypto/blowfish.ko
insmod ${modpath}/crypto/camellia.ko
insmod ${modpath}/crypto/crc32c.ko
insmod ${modpath}/crypto/lzo_compress.ko
insmod ${modpath}/crypto/lzo_decompress.ko
insmod ${modpath}/crypto/lzo.ko
insmod ${modpath}/crypto/twofish.ko
insmod ${modpath}/crypto/wp512.ko
insmod ${modpath}/crypto/zlib.ko
insmod ${modpath}/net/af_key.ko
insmod ${modpath}/net/af_packet.ko
insmod ${modpath}/net/ah4.ko
insmod ${modpath}/net/esp4.ko
insmod ${modpath}/net/xfrm_user.ko
insmod ${modpath}/net/xfrm4_tunnel.ko
insmod ${modpath}/net/xfrm_ipcomp.ko
insmod ${modpath}/net/ipcomp.ko
insmod ${modpath}/net/ipip.ko
insmod ${modpath}/net/ip_gre.ko
insmod ${modpath}/net/nf/nf_tproxy_core.ko
${binprefix} find ${modpath}/net/nf -name "xt*.ko" -exec insmod {} \;
${binprefix} find ${modpath}/net/nf -name "ipt_*.ko" -exec insmod {} \;
insmod ${modpath}/net/nf/iptable_mangle.ko
insmod ${modpath}/net/nf/iptable_raw.ko
insmod ${modpath}/net/nf/arpt_mangle.ko
#net cfg
echo 1 > /proc/sys/net/ipv4/ip_forward
iptables -P FORWARD ACCEPT
#insmod ${modpath}/ppp/pppox.ko
#insmod ${modpath}/ppp/pppoe.ko
#insmod ${modpath}/ppp/pppol2tp.ko
#insmod ${modpath}/ppp/pppopns.ko
#insmod ${modpath}/ppp/ppp_mppe.ko
#insmod ${modpath}/ppp/pppolac.ko
insmod ${modpath}/cifs/nls_utf8.ko
insmod ${modpath}/cifs/slow-work.ko
insmod ${modpath}/cifs/cifs.ko
insmod ${modpath}/tun.ko
insmod ${modpath}/bt/bluetooth.ko
insmod ${modpath}/bt/btusb.ko
insmod ${modpath}/bt/hidp.ko
insmod ${modpath}/bt/bnep.ko
insmod ${modpath}/bt/bfusb.ko
insmod ${modpath}/bt/bcm203x.ko
insmod ${modpath}/bt/bpa10x.ko
insmod ${modpath}/bt/btmrvl.ko
${binprefix} find ${modpath}/bt -name "*.ko" -exec insmod {} \;
insmod ${modpath}/usb-eth/rk29_vmac.ko
insmod ${modpath}/usb-eth/pegasus.ko
insmod ${modpath}/usb-eth/rtl8150.ko
insmod ${modpath}/usb-eth/usbnet.ko
insmod ${modpath}/usb-eth/cdc_subset.ko
insmod ${modpath}/usb-eth/cdc_ether.ko
insmod ${modpath}/usb-eth/cdc_eem.ko
${binprefix} find ${modpath}/usb-eth -name "*.ko" -exec insmod {} \;
${binprefix}cat /proc/modules | ${binprefix}grep -q ^${module}
if ${binprefix}test $? -ne 0; then
  ${ANDROID_ROOT}/bin/insmod ${modpath}/${module}.ko
  setprop gps.baud ${baud}
  setprop gps.device ${device}
  setprop ro.kernel.android.gps ${device}
else
  ${ANDROID_ROOT}/bin/rmmod ${module}
fi
insmod ${modpath}/usb-gps/cp210x.ko
insmod ${modpath}/usb-gps/garmin_gps.ko
insmod ${modpath}/usb-gps/navman.ko
${binprefix} find ${modpath}/usb-gps -name "*.ko" -exec insmod {} \;
insmod ${modpath}/usb-modem/cdc-acm.ko
insmod ${modpath}/usb-modem/cdc-wdm.ko
insmod ${modpath}/usb-modem/ipw.ko
${binprefix} find ${modpath}/usb-modem -name "*.ko" -exec insmod {} \;
insmod ${modpath}/misc/gspca_main.ko
insmod ${modpath}/misc/scsi_wait_scan.ko
${binprefix} find ${modpath}/misc -name "*.ko" -exec insmod {} \;
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/04/12 - 11:35
Beta for 10G2 and 10bG2 - MorkaMod v1.16Beta :
- Fast  version
- Adding drivers for the bluetooth, bluetooth GPS, GPS usb2serial and USB Ethernet
- Ext3 version add manually your drivers in the folder "/system/lib/modules" after rebooting your hardware connected
- Improvement of the theme even more beautiful
- Compatible with flash player 11.1
- Beta the first Model Arnova 10b G2
                                                        Screenshot with my 8G2
MorkaMod 1.16Beta for Arnova G2 Filesystem Cramfs
MorkaMod 1.16Beta for Arnova 10 G2  AR.10.G2.cramfs.2G.MorkaMod.v1.16Beta.zip
MorkaMod 1.16Beta for Arnova 10b G2  AR.10b.G2.cramfs.2G.MorkaMod.v1.16Beta.zip
(Flash with Rockchip flashing tool)
2012/04/12 - 12:57
Just tested the new firmware image on the Arnova 10 G2. It gets stuck on Arnova logo, does not boot any further.
No output on the logcat, it keeps "- waiting for device -"
Edit: Weird, I restarted the device, it now boots to a blackscreen after a while and I get some logcat output.
I'll attach logcat here soon.
2012/04/12 - 13:25
Ok, new test with update.AR.10.10B.G2.cramfs.2G.MorkaMod.v1.16Beta.2.img (2012-04-12 10:46:12)
Boot shows Arnova  logo for like 5 minutes, logcat gives - waiting for device -
Then comes an Android boot logo, followed by a black screen which stays like this. At this points adb starts to give logcat output
(file attached)
theGod
2012/04/16 - 18:29
I've installed the v1.15 of your mod (arnova 10 g2) and it's MUUUUCH BETTER than ARNOVAs original one. Anyway, is there a chance, that the issues mentioned (facebook, camera, back button...) will be fixed? When will the new version probably released? Don't take it as bad criticisim, it still rule upon the orignal firmware, so keep up with great work there and be motivated! 🙂
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/04/17 - 01:11
Beta for Arnova G2 - MorkaMod v1.16Beta :
- Fast version
- Adding drivers for the bluetooth, bluetooth GPS, usb2serial GPS and USB Ethernet
- Stable version Ext3 version add manually your drivers in the folder "/system/lib/modules" after rebooting your hardware connected
                                             Image Enlarger
 ___________________________________________________________________________________
MorkaMod 1.16Beta for Arnova 7 G2 Arnova.7.G2.cramfs.2G.MorkaMod.v1.16Beta
MorkaMod 1.16Beta for Arnova 7b G2 Arnova.7b.G2.cramfs.2G.MorkaMod.v1.16Beta
MorkaMod 1.16Beta for Arnova 8G2 Dual Touch                     Test
Arnova.8.G2.DT.cramfs.2G.MorkaMod.v1.16Beta
MorkaMod 1.16Beta for Arnova 9 G2                                        Test Arnova.9.G2.cramfs.2G.MorkaMod.v1.16Beta.FixBoot
MorkaMod 1.16Beta for Arnova 10 G2 Arnova.10b.G2.cramfs.2G.MorkaMod.v1.16Beta
MorkaMod 1.16Beta for Arnova 10b G2                                    Test Arnova.10.G2.cramfs.2G.MorkaMod.v1.16Beta
The problem is with the ARNOVA 9G2 files init.rc
deactived starting to file init.rc Fixe boot Arnova.9.G2.cramfs.2G.MorkaMod.v1.16Beta.Fix.Boot
Lopes67
Portugal
2012/04/17 - 20:47
Hi Morka.
My arnova 7 g2 is just the logo with firmware 1.16. thanks for your work is the best
mal_khan
2012/04/17 - 21:41
I loaded this onto my 10 G2 and it did he boot logo (a  load of lines) and then went to a black screen and no more after
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/04/19 - 13:43
- Correction of the framework-res and adding new animation ics
- Fixed issues with the battery mark questions
MorkaMod 1.16Beta for Arnova 7 G2 Arnova.7.G2.ext3.2G.MorkaMod.v1.16Beta
MorkaMod 1.16Beta for Arnova 7b G2 Arnova.7b.G2.ext3.2G.MorkaMod.v1.16Beta
Arnova.8.G2.DT.ext3.2G.MorkaMod.v1.16Beta
(Flash with Rockchip flashing tool)  Please use to errors target adb.tools.For.MorkaMod.zip
longkienho
2012/04/20 - 04:26
Hi Morka,
I have tried firmware 1.6 beta for  Arn 9G2, it basicly work well.
However, mobile network ( in setting) has problem force to close unexpectedly so can not set APN to use 3g usb dongle.
and the battery fall down more quickly than normal.
Hope that you can fix it in next generation one.
Thank you so much !
doitlikePlay
2012/04/20 - 08:39
Arnova 10G2
-ARNOVA Logo
-Then Bunch of coloured lines
-Black Screen
76 Guest(s)
Devices in use: Desktop (65), Phone (11)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
