I tried Google Currents with the Stock firmware, it does not install because of the following error:
D/PackageManager( 79): Scanning package com.google.android.apps.currents
E/PackageManager( 79): Package com.google.android.apps.currents requires unavailable shared library com.google.android.maps; faili
ng!
W/PackageManager( 79): Package couldn't be installed in /data/app/com.google.android.apps.currents-1.apk
The issue seems related to that one:
So the fix should be similar.
Which firmware are you using ?
2012/02/02
2012/02/02
It should be already included in arctablet custom firmwares from our kitchen.
Can you make a request and mention this topic on Morka support forum so it can be added to next updates.
Thank you.
drew said
I'm using fenice57's custom firmware. is there a way google currents can be installed? wha'ts the exact procedure? thank you
It's all explained here:
87 Guest(s)
Devices in use: Desktop (82), Phone (5)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
