Flashing your Arnova G2 or Rockchip 2918 tablet with Rockchip flashing tool
GekkeVos
61
2012/07/07 - 21:19
Great Help, but the Procedure for entering Flashing/download mode on the Arnova 9 G2 is not correct.. U must Press and Hold both 'Menu' & 'Pwr' buttons, then press reset button for several seconds. Screen remains blank and the host PC will indicate New hardware found. Then install your drivers.#
Hope this helps.
ezlee
62
2012/07/11 - 22:11
Hi all, I need your help.
I have an Arnova 7bg2 and I installed the correct firmware for this model using the rockchip flasher tool. The update was successful however I've noticed that you cant exit certain apps. For instance, if you go into the gallery or access the camera, theres absolutely no way to suspend the app. As a result I've been forced to turn off my arnova each time 🙁
Does anyone else have this problem? Am I doing something wrong?
Thanks Received: 3169
63
2012/07/11 - 22:11
Which firmware have you flashed ?
ezlee
64
2012/07/11 - 22:20
I flashed my arnova with this firmware (file size is approx 172mb) update.AR7bG2.cramfs.2G.MorkaMod.v1.15
The version is 2.3.1 (model number A70HT3). This is what it states when I look at the details under the device settings. Also I've noticed its not possible to bring the notification bar up by dragging from the top of the screen.
65
2012/07/11 - 22:31
Unfortunately, this firmware (Morkamod) is not maintained anymore by it's author.
If you want Google Play support on your tablet you can try our firmware, which is based on default Arnova firmware. http://www.arctablet.com/assets/firmware/Arnova7G2/kasty-ez_arn7bg2cap-23-112.zip
This firmware is for Arnova 7b G2 capacitive model only, it won't work on the resistive Dual Touch (DT model)
Flash with Rockchip flasher tool: http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
ezlee
66
2012/07/11 - 22:41
Thanks very much for your input. I'm flashing my arnova 7bg2 with the firmware you suggested as we speak. I'll see what happens with this one 🙂
ezlee
67
2012/07/11 - 22:51
Thanks, its done the job.
One further question, do you know if its possible to enable password protection on the lock screen for this firmware? I can't find a setting for this and I'm not sure if this issue has been dealt with elsewhere.
Cheers
grayzee_18
68
2012/07/12 - 12:10
help pls…
i upgrade my arnova 9g2
2.3 to ics
i followed the instruction and read it carefully
but after i upgrade it say
succesfull 1 fail 0
and after my tablet reboot it went installing and few seconds it says it fail and rebot again
but all i see now is the logo of arnova only…what should i do…
pls help me…
pls……
tnx in advance,,,,
69
2012/07/12 - 12:10
Try to flash again the firmware using Restore rather than Upgrade button in Rockchip tool.
grayzee_18
70
2012/07/12 - 12:33
i cannot connect everytime i plug the usb it always comes the logo
always no connecting device
and the number 1 doesnt highlight
grayzee_18
71
2012/07/12 - 14:01
i manage to restore it but doesn't work..
and i try again to upgrade it it finish and when i saw installing it on my tab i saw that
"it cannot mount"
something like that
and reboot again and it appears the set up wizard on ics after i finish set a few minutes it appears a android word and i wait for almost 30min. i think it hang
an i reset it again and im back at arnova logo again until now almost an hour waiting for someting to happen... help me guys pls.. dont know what to do
tnx
grayzee_18
72
2012/07/12 - 14:59
tnx for helping..
after several times of upgrading and restore finally im done..
im on 4.0.3 ics...
all i can say is...WOW...
amazing the ics...
now im thingking of upgrading again to nexus....
but im wondering whats on nexus....
tnx admin.....
ezlee
73
2012/07/12 - 22:27
Hi again all. Does anyone know if its possible to enable password protection on the lock screen for the Arnova 7BG Gingerbread..
Cheers
jamieedgley212
74
2012/07/13 - 09:08
do you require root access to do this and if so how do you root
thanks
all help appreciated
75
2012/07/13 - 09:09
Root access isn't needed, Rockchip flasher is a low level tool that works before the OS starts.
79 Guest(s)
Devices in use: Desktop (70), Phone (6), Tablet (3)
teomanfbm
pawel255
elpacox
Kolokolov Pavel
Ikeman
martn28
