Flashing your Arnova G2 or Rockchip 2918 tablet with Rockchip flashing tool
ikjahaa
46
2012/04/24 - 22:43
after looking for 2h on the internet i found it.
press and hold vol+, then press and hold reset too.
wait 15sec.
release reset, then release vol+.
now folow the driver instalation steps
ikjahaa
47
2012/04/24 - 22:43
drives don't work for me 🙁
ikjahaa
48
2012/04/24 - 22:43
please link to the 64bit driver
ikjahaa
49
2012/04/24 - 22:43
what about USB-debugging, must it be on or off?
can’t get my 10G2 in recovery either.
i’m pressing reset then vol up together for 20 seconds.
ps. srry for reply
ikjahaa
50
2012/04/24 - 22:43
can't get my 10G2 in recovery either.
i'm pressing reset then vol up together for 20 seconds.
Thanks Received: 264
51
2012/04/24 - 22:56
you can address the adb reboot recovery from adb, you need debugg mode on to do that.
Grinder
Murphy, NC
52
2012/05/08 - 09:45
ok... not having fun here... after I put my 10g2 tablet into recovery mode... the square does not turn green, it stays pink/red and does not ask me for a driver... I followed the procedure for setting the system correctly... I have done everything and followed all the troubleshooting guide as much as I can... any assistance would be appreciated... thank you!
_/Grinder_/
Keiser Sose
53
2012/05/18 - 21:52
What's the difference between the "upgrade" & "restore" feature in the RBT?
cazzm212
54
2012/05/27 - 21:12
DESPERATELY WANT TO INSTALL MORKAMOD BUT AM SCARED OF BREAKING MY TABLET! Any easier way to install????
Thanks Received: 3170
55
2012/06/13 - 13:03
Upgrade sends the firmware to the tablet, Restore does the same, but format part of the tablet flash memory before.
In general, using Upgrade is fine, Restore button can help with Bricked device that do not boot anymore or flashing firmwares that have a different partition layout.
agreller
56
2012/06/14 - 19:27
Trying to install the Arnova 9 G2 custom ics firmware, I'm following instructions using the Rockchip flashing tool.  When I go to put the device into flashing mode, instead of finding the device and prompting for a driver I get the following:
USB Device Not Recognized One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it.
Tried it on a few Win7 computers and on an XP computer, same result.
Changed the hardware installation settings and tried a different cable, as per the troubleshooting section.  Same result.
Unknown device shows up in Hardware Manager, but only while the reset pin is still pushed in.  I can click to upgrade driver while it's pushed in but then message says it already has the best driver.  Then when reset pin is pulled out it all disappears and tablet restarts.
Any thoughts anyone?
SarahLV
57
2012/06/15 - 09:58
YAY o/
It works on the Anova 10b G3
Did take me about 5 goes to get the tablet into recovery mode, and I had to start the "Add New Hardware Wizard" manually in Windows 7 - other than that it all works fine and Google Play is working nicely
MattiusMatt
58
2012/06/18 - 16:27
I am having exactly the same issue as agreller, I have even tried forcing the driver install manually but Windows doesn't recognise the driver!!
I have tried this on a couple of machines too, Windows seems to think its a faulty USB device could this be a Windows 7 Service pack issue? Is there no alternative for Windows and Mac?
I am on the ARNOVA 10b G3
This is really frustrating!! 😐
xxavatarxx
59
2012/06/19 - 21:26
Can someone help me please? I put my Arnova 10b g3 into recovery mode and when the thing showed up it didn't ask me about any file... what should i do now?
only1pj
60
2012/07/06 - 21:10
I am having trouble with my Arnova 9 G2. I have successfully installed the drivers but did not get a green square in the Rockchip Batch Tool. I have restarted my windows xp pc and the arnova a few times but to no avail, still no green box! The tablet does load up and connect to the PC just not to Rockchip.
Any suggestions?Confused
Never mind, this problem is sorted. Now to find a thread about the other problems.Cry
84 Guest(s)
Devices in use: Desktop (66), Phone (18)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
