original firmware familypad
kjano
2013/10/26 - 13:31
Hello, I'm searching original firmware of arnova familypad for recovery. I rooted it and it pretends to be ok, but after first restart is entered in loop. I would restore original firmware but on arnova site there isn't . Thanks.
Thanks Received: 264
2013/10/29 - 01:02
To my knowledge there is no firmware available for the familypad.
An option would be this:
http://www.arctablet.com/blog/forum/firmware-development/dumping-firmware-on-arnova-g2-arnova-g3-and-other-rockchip-based-tablets/
kjano
2013/10/30 - 08:31
Thank you for the reply, I'll try this option.
woetoo
2015/01/18 - 18:58
I just had a Arnova FamilyPad in a similar state. I don't think it had been root'd - but it was definitely in a loop when starting up - just showing the Arnova logo over and over without end.
I tried the various solutions linked to from here, even going so far as to install the JavaSE, Android Developer Studio and various Rockchip utilities. All without success. My main problem seemed to be finding drivers that would be accepted. I'm running Windows 7-64bit and none of the drivers I found would replace the inbuilt ones. As such, none of the tools would recognise the ADB functionality (I'm new to Android, so pardon my ignorance).
In the end, I found a Youtube video for an entirely different Android Tablet (tbh, I found lots, but most weren't much use) and found a solution that worked for me.
  • Unplug the power and USB cables, ensuring the tablet has a suitably high %power level.
  • Hold the power button for about 10 seconds to power off the tablet.
  • Press the power button to switch it back on again.
  • Repeatedly press the power button and the volume + buttons semi randomly while the Arnova logo was on screen.
  • Keep repeating until the Android Robot logo appeared, then press the power button again.
  • A menu appeared. One of the options was a "reset to factory defaults". Navigation was using the volume - / + and power.
Resetting this way worked for me and the tablet is operational again. Clearly the "press volume + and power semi randomly" isn't the right way to do this. There's undoubtedly a "right way" with a correct order and correct timings. However since I tried a couple of times and the way that eventually worked was the semi random button mashing - I can't offer any more insights.
Posted in the hope that the next person that comes finds this post via google search doesn't waste as much time as I did.
seann500
2015/03/28 - 08:34
hi woetoo
i have messed about with this tablet a few months now and found that it has to be flashed via livesuit as its not a rockchip system
its an A10 system holding the power button and tapping the vol+ button puts it in flash mode or recovery mode
you want to find out how to do a firmware dump
this will help you in the future as i have been trying to find a firmware for this for about 4-5mths
(i have mine up and running but is not 100% as i have miss matched scripts and firmwares)
if you do get a firmware dump i would as if you could message me about it
one of these would  help me get it back to 100% working
thanks sean
Cusco
Russia
Forum Posts: 22
2017/01/22 - 17:23
Here's the solution for devices stucked in bootloop: http://www.phonandroid.com/forum/arnova-familypad-an13fp-t98292-20.html#p1976760
checked by myself
The following users say thank you to Cusco for this useful post:
Oma7144, seann500
seann500
2017/01/22 - 23:04
checked by myself
thanks for that cusco
i will try this later this week
as for familypad i did manage to get to work
i used img Arnova 10CG3 img
then plugged into hdmi to get onto tv
then unlocked usb mode and put in develope mode
this allow to talk to computer through usb
i then used script bin pull software,pull Arnova 10CG3 script file converted
from this site http://www.androidsoldier.com/2014/03/fix-screen-shift-fix-inverted-axes-on.html
only used 1.2.4.5.6 not 5.
then modified script bin lcd settings from sani n10-jb-411
copied back to script.bin
injected it back to familypad
lcd lights up touchscreen works wifi works etc
not camera
after period of time crashes again due to backup script internally back to faulty familypad
its now in the cupboard again till later this week
thanks again
paillassou
2017/09/21 - 13:27
Hello everybody 😉
[FIRMWARE] ARNOVA FAMILYPAD AN13FP / rom firmware image
ARNOVA.FAMILYPAD.AN13FP+tool.zip (original & rooted)
original firmware dumped and repack in *.IMG firmware 😉
or
PMP5197DULTRA.[FW-IMG].mod.for.FAMILYPAD-AN13FP+tool.zip (based on PMP5197DULTRA)
Only G-SENSOR doesn't work... :/  if someone could help ... 😉
the right chip gsensor is "mc32x0"
i've search & tried too put insmod
insmod /system/vendor/modules/bma250.ko
insmod /system/vendor/modules/mma8452.ko
insmod /system/vendor/modules/mc32x0.ko   (add 0x4c address in script.bin....)
and check if modules/drivers are present...   ...no success... :/
DOWNLOAD HERE
http://www.phonandroid.com/forum/arnova-familypad-an13fp-rom-firmware-image-t178776.html
Bye 😉
58 Guest(s)
Devices in use: Desktop (47), Phone (11)
cutierogue
