2013/07/15
Hi
Im searching the driver for ARNOVA Familypad AN13FP for flashing (recovery ROM).
From where do you have a recovery rom?
Do you need the ADB, or rockchip drivers ?
2013/07/15
Thanks very much fro reply.
I want the drivers for rockchip after entry on reboot mode me pc dont recognize me ARNOVA.Try for flashing ROM and entry with root user but without this driver dont work.Im try open with RK29update.exe but have the error: no found rkandroid rock usb.
Many thanks.
Answers Post
In the zip file you will find also the rockchip drivers
http://www.arctablet.com/blog/featured/flashing-your-rockchip-rk3188-based-tablet-with-rockchip-batch-tool-v1-6/
2013/07/15
Salut globula_neagra,
Vad ca esti Roman, am citit si portalul tau de ciclism....sincer eu nu am gasit firmeware-ul original.....am tableta fara android pe ea, doar imi apare logo-ul alb ARNOVA si ramane asa, se reseteaza singura....Intre timp se stie ceva de firmware ? sau ceva alternativ...
Multumesc mult
2019/07/01
Zip file not working :/
217 Guest(s)
Devices in use: Desktop (209), Phone (8)
