Arnova FamilyPad 13.3" Android tablet review | Part 2: Tablet design
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/11/20 - 19:11
Arnova FamilyPad packs a nice design with a glossy finish. The pieces are now adjusted pretty well, the whole device seems quite solid and the materials feel quite good. The front surface, which also acts as a mirror, catches fingerprints like a magnet, but it is quite easy to get them off.
Image Enlarger
The back of the device is covered with rubber on the sides with aluminium finish in the center. Compared to the rather cheap finish on most Arnova models, the FamilyPad feels like being from a different world. Thanks to the rubber on the sides, the tablet won't slip out of your hands easily.
Image Enlarger
Connectors
The right tablet side holds the connectors, from top to bottom:
  • a tiny hole for the microphone
  • micro USB connector (slave)
  • micro USB connector (host)
  • the HDMI connector (mini HDMI format, aka HDMI type c connector)
  • micro SD card connector (SDHC compatible)
  • DC connector
  • headphone connector, usual 3.5 mm mini-jack format
  • reset pinhole
Image Enlarger
2.0 Mpx back camera and the volume buttons are located on the right upper side of the tablet.
Image Enlarger
The tablet double speakers are located on the left back side. The sound is slightly attenuated, when the tablet rests on its back,…
71 Guest(s)
Devices in use: Desktop (66), Phone (4), Tablet (1)
AMINE TPS
ah1977
boutbouqalt
anhi
taipanjon13
ANYTAHI
