I recently had problems with my arnova 9 g3. Touch screen not responding to touch. I tried everything you guys suggested, without success. So I gave up on it. However I put it away in a cupboard for about a week, theb decided to use it again as I could make it function with a mouse. Well now it's working perfectly again.
Does this suggest a component or circuit fault?
I did not encounter this problem under a normal usage, the only situation when the touch screen did not work, was when i used a firmware from another tablet.
But still, on the 9G3, you can connect an usb mouse, and go to settings, and recalibrate the screen.
2012/12/29
The touch screen on mine has just stopped working it starts up and runs the calibration but then i cant press the ok button so it just runs it again and again and again... anything I can try before taking it back to the shop where I bought it to get a new one, also I have custom firmware installed are they gunna be bitches about taking it back because of this?
69 Guest(s)
Devices in use: Desktop (62), Phone (7)
hans41
rickybk
soniya07
ironmangitar
