Looking for Arnova 9 G3 USB ADB driver
ian
United Kingdom
Forum Posts: 30
2012/05/23 - 08:49
Has anyone been able to get the adb usb driver to work for Arnova 9G3?  It doesn't seem to recognise the driver.
Thanks Received: 3171
2012/05/23 - 09:15
Ian,
Here is the procedure to add support for your device in ADB.
First make sure you enabled ADB, go to Settings / Developer options and verify that USB debugging is enabled.
Then go to the Device Manager or your computer and see under Other devices, you should see a device with a question mark.
Enter in it, go to Details tab, Hardware Ids then get the VID and PID.
Get our ADB driver package from here:
http://www.arctablet.com/blog/featured/adb-driver-update-for-archos-arnova-devices/
Edit the  [Google.NTamd64] and [Google.NTx86] sections of android_winusb.inf file to add your new device, use the VID and PID you got in Windows System Manger.
Save your INF file.
Go back to the system manager, right click on the device with the question mark, choose Update Driver Software... then Browse my computer for driver software... point to where you have your adb package and INF file updated.
Just ask here if anything isn't clear... and let us know your VID & PID so we can add it to the INF file.
retsil
2012/06/02 - 13:45
Is this what you wanted?
;;; Arnova 9 G3
%SingleAdbInterface% = USB_Install, USBVID_2207&PID_0006
%CompositeAdbInterface% = USB_Install, USBVID_2207&PID_0006&REV_0222
retsil
2012/06/02 - 18:31
Although that installs, adb doesn't list the device in command prompt 🙁
2012/06/03 - 00:19
I have similar a similar issue on the Arnova 10b G3 where ADB installed (after I modified the .inf file with proper VID&PID) but the device isn't listed.
Still, I got ADB working once during my custom firmware tests but I haven't recorded what made it work. It's probably fixable, I'll let you know if/when I find something.
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/06/03 - 11:43
Everything seems to work on Arnova 7DG3ST-CP (better known as the ChildPad). Here is what I get:
Image Enlarger
I added the following:
;;; Arnova ChildPad Resistive
%SingleAdbInterface% = USB_Install, USB\VID_0E79&PID_1459
%CompositeAdbInterface% = USB_Install, USB\VID_0E79&PID_1459&MI_01
Maybe for 9G3 it would be:
%CompositeAdbInterface% = USB_Install, USBVID_2207&PID_0006&MI_01
With the CHildPad, I also have pid_1459_revxxx; but I just skipped it. 🙂
lohtse
Forum Posts: 157
2012/06/03 - 12:22
whats required to be added for the 7 G3?
retsil
2012/06/03 - 16:46
Image Enlarger
That doesn't seem to work either, should I have it set to USB debug and MTP or USB debug and mass storage?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/06/03 - 21:30
retsil said
Image Enlarger
USB debug and MTP is what I use...
retsil
2012/06/03 - 22:01
exelletor said
retsil said
Image Enlarger
That's what I had it set to.
Should it be in device manager as Android Phone? And then should it be adb, bootloader or composite device?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/06/03 - 23:33
Android Phone and then Android ADB Interface. No idea why it is not working, I am not too technical when it comes to this... 🙁
lohtse
Forum Posts: 157
2012/06/04 - 11:23
added theses for 7 g3
;;; Arnova 7 G3
%SingleAdbInterface% = USB_Install, USB\VID_18D1&PID_0003&REV_0230&MI_01
%CompositeAdbInterface% = USB_Install, USB\VID_18D1&PID_0003&MI_01
;;; Arnova 7 G3
%SingleAdbInterface% = USB_Install, USB\VID_18D1&PID_0003&MI_01
%CompositeAdbInterface% = USB_Install, USB\VID_18D1&PID_0003&REV_0230&MI_01
not sure which ones right but it worked lol
rugbyjock
2012/06/10 - 13:58
I added these for the Arnova 10b G3
%SingleAdbInterface% = USB_Install, USB\VID_2207&PID_0006
%CompositeAdbInterface% = USB_Install, USB\VID_2207&PID_0006&MI_01
But ADB still shows no devices. I have the tablet attached with USB Debugging and MTP on. Has anyone had any luck with this model at all?
xirurg10
2012/09/02 - 17:36
You need to do everything correctly step by step like on this link  http://blog.fh-kaernten.at/wehr/?p=1182
After that when you add usb ids to that file you may need to do
adb kill-server
adb start-server.
This helped me with Arnova 9 G3.
98 Guest(s)
Devices in use: Desktop (85), Phone (12), Tablet (1)
swan12
heftpflaster
