Arnova 9 G3 video playback issue
arnovarara
2012/06/27 - 09:17
Hi, Just got a new 9G3 and found that streaming video from the net doesn't work properly. Video runs fast, then buffers, then runs fast, then buffers. Doesn't work with bbc iplayer or 4OD or streaming news. You tube is ok and movies saved onto device work fine.
I have uninstalled and reinstalled flash, upgraded firmware to have google play and bbc mobile and that didn't help.
I have read a review, and a couple of personal forums where people had the same issue. I really like the unit, and would rather keep it than return it, but would like to know if this is the best video it is capable of.
I see that the 10G2 has bbc working fine so this must be able to as well.
Anyone know anything.......thanks.
sengoku
2012/08/12 - 15:52
Have same isseus on my 9 3G,
have tried several browsers all seem to suffer from same issues, youtube seems to be the only stream that is reliably decoded correctly.
it seems to be an memory issue hopefully a future update will fix it but for now i'm using (auto mem killer)
which fixes most streaming issues for me, although some streams are still problematic.
good luck. and please do post if you find better fix..
mrtuk
2012/09/16 - 23:50
Same problem here ... anyone know if there is a fix? The main reason for buying the tablet was to use bbc iplayer, but so far not had any joy Cry
Thanks Received: 264
2012/09/18 - 00:06
can some of you provide an adb logcat when thei are trying to use bbc iplayer ?
Currently Online: khanmosa
74 Guest(s)
Devices in use: Desktop (61), Phone (14)
antoniors021
wemiy54158
sidor
houssmen
qarolus
dav512
