[ ROM ] Arnova 9 G3 custom firmware Android 4.1 JB, root, more space for apps and PIP video player
Marx
2013/09/12 - 21:31
I have a problem, I do not come in the recovery mode.
On the display their is the android man with an exclamation mark
What can i do
TrueBlue1981
Northampton, England
2013/09/22 - 14:25
Limitations:  - the battery indicator doesn’t work properly, it gives a correct reading (battery life % and charging or not) only once at boot time. After boot, the battery indicator is stuck and does not show any change of value from the boot. - the video is mirrored horizontally in the camera application
Hm, as amarayoub83 said, I do hope these limitations can get fixed for the 97 Carbon. I installed the firmware in my Carbon, and I liked it so much more than the stock Android 4.0.3, as well as the custom firmware found on this site. It felt a lot smoother, and as a bonus, it had the ability to disable HDCP on the HDMI, which I needed.
But due to the battery problem, whereby it would discharge in 5 minutes, and stop charging after 5 minutes, it was unusable. So please, please fix these issues to make it more reliable on the 97 Carbon. It's a good custom ROM, which I would like to use as a permanent ROM Smile
ian
United Kingdom
Forum Posts: 30
2014/03/27 - 14:50
ian said
Does anyone know how to unroot this?  I am trying to play Ultaviolet movies via Flixster and it won't play because my device is rooted.  I have tried "Hide My Root" and "OTA Rootkeeper" but neither appear to hide the root from Flixster.  Anyone who has got UV movies playing on their Arnova 9 G3 please let me know your method of getting them playing.  Thanks.
The fix is to install the Xposed framework and then Rootcloak module, added flixter to the cloaked apps. You then have Flixster/Ultraviolet movies on Arnova 9 G3
moarchos
2014/11/30 - 17:09
I copied the update.img file to the Arnova9G3 and it installed without any problem.
space for applications has not changed.
can someone please explain at what point he data partition is increased.
can I expand the data partition manually?
any help would be appreciated.
OptimusGREEN
2015/08/23 - 18:06
I've tried to download this several times and it keeps failing at different percentages. is there another link anywhere?
201 Guest(s)
Devices in use: Desktop (187), Phone (14)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
