2011/12/10
I checked the Arnovatech.com web site and they are not listing a update.img for this model. However if someone has one please post it. If it does not exist then if someone is willing to dump all the IMGs using ADB I will have a go at seeing if I can root this rom. If it's like the 10 G2 I should be able to do it quickly!
Bob
2011/12/30
I have a 9 G2 as of yesterday and would be willing to do this if you can point me at some instructions etc, this is my first Android device and I have never used ADB but I understand what it does. Have Linux and Windows available, fluent in both. Are we talking about just dumping a dd image?
Already installed market as per the instructions in thiis forum. Don't have a terminal or SSH etc tho.
dan
2011/12/10
You have some details on the firmware dumping procedure here:
http://wiki.archosfans.com/index.php?title=Dump_your_Home_Tablet_rom_and_create_a_custom_rom
How do you start adb on your computer, do you get an error ?
Is adb enabled on the tablet ?
2011/12/27
ok i have found out how to use it now i didnt relise it was cmd based, but the only problem now is that it cant find my device i have usb debug on and its giving me 123456789ABCDEF but i highly doubt that it is my device, is it?
--EDIT--
im into this device whether its the correct one or not it seems to dissapear when i unplug mine, but permissions are restricting me it says permision denied
abd -s 0123456789ABCDEF pull /System /C:UsersAlexDocumentsARNOVA 9 G2 SYSTEM
abd: permission denied
Most details are on the tutorial link I gave you:
Get rkdump binary then use adb push to send rkdump to the tablet.
then from adb shell, chmod 777 rkdump
then run rkdump on the proper partitions according to /proc/mtd output
2011/12/10
2011/12/10
You need to push rkdump to a writable place when you can then execute the binary.
If I remember right, /data/local should do.
You will need to be root (temp. root is OK) to execute rkdump.
2011/12/27
I managed to pusk rkdump to /data however i could not get it rooted i tried z4 superoneclick (worked oncebut crashed then reset) and i tried manually rooting it but i culdnt do it i dk why i hope coltracer has better luck i will try again in the morning
125 Guest(s)
Devices in use: Desktop (90), Phone (35)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
