To Brick or not to Brick! (problem with Nexus firmware flash)
chrissyboy74
2012/10/06 - 15:04
Hi Lads just tried to root my 9g2 with the nexus download from here. One guy told me to just put the image into root and let it do the rest from there. All seemed well it started the update but then went to Arnova screen and its stuck on it, whats happened?
I need some advice on how to recover it?
Cheers
Thanks Received: 3169
2012/10/06 - 15:16
I don't know in details how the 9G2 "Nexus" firmware is made, but it's very likely that it has some different system settings (partition layout among other things) than the stock partition, so that way of updating the firmware just copying update.img to the root directory on the tablet doesn't work.
You should use Rockchip flasher to flash this "Nexus" firmware or recover the stock firmware or another one on your Arnova 9G2.
chrissyboy74
2012/10/06 - 15:34
Problem is rockchip when I use it says it sees my tablet but when I try to put it in safemode its says there is a usb malfunction and it does not recognise the usb device that is being used.
And of course the tablet then displays the frozen arnova screen again.
chrissyboy74
2012/10/06 - 17:18
i have now reinstalled finless old 2.3.1 version so the tablet works again but unfortunately I do not get any reading from the rockchip, none of the boxes are highlighted at all. is this a clash between my rkandroid tool and my rockchip.
Can I flash my tablet with rkandriod to put the nexus firmware on?
Thanks Received: 264
chrissyboy74
2012/10/07 - 00:29
Thanks for the time and effort but unfortunately my computer continues to say that the usb port does not recognise the hardware and does not prompt me for drivers to be installed. I have been trying all afternoon and evening. The walkthrough does not give a solution to this problem so Im at my wits end with it.
Any other solutions or explanations for my laptop not helping me though?
2012/10/07 - 00:36
I posted some links earlier today about issues with Rockchip flasher:
http://www.arctablet.com/blog/forum/arnova-9-g2/arnova-9-g2/#p13473
Currently Online: -wall-, nikoscc77
139 Guest(s)
Devices in use: Desktop (125), Phone (16)
nikoscc77
hacktes
Walldos
MOUNIR 1923
cynthiavd
rafi462
Topics: 6010
Members: 260640
