2013/02/28
Problem with Arnova 9 G2!android 2.3.1 karnel 2.6.32.27
I try to flush a several custom roms!The only way to put the device in recovery is by holding reset,power and menu,not like is shown hereÂ
for this divise!And its recovery,not flash mode!
In the recovery I cant move the line up or down and there is a massage:
Recovery system v1.3.37
E:Cant open /cache/recovery/command
I connect the device in this condition to Rockchip_Batch_Tool. The program recognize devise bud the color is pink,not green!After hitting the upgrade button I get massage:This operation didn't do because of not supporting!
The mean reason to install a new version of android is:the sound of microphone when using skype is with big bad noise/try many,many different versions,even skype47_rearonly /.
Then try to get the device in flashing mode either using the key combination posted here
http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/#comment-39503
Connect the tablet to the pc after you press the keys
Or you can use adb reboot bootloader (use google to find out what is this)
78 Guest(s)
Devices in use: Desktop (73), Phone (5)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
