Lost password?
The forums are currently locked and only available for read only access
not working at all... any help appreciated
This topic is locked
john60470
2012/07/23 - 21:07
hi all, i dont really have much of a clue so you might need to excuse my poor descriptions but here goes; a while ago i tried to put new firmware on my arnova 9 g2, all worked well, i managed to put into recovery mode and connect to rockchip tool etc and all seemed fine and ran with new firmware, yet when i turned it off and tried to turn back on nothing will work, when connected to the computer through the usb i just get the 3d green android symbol with a safe in the middle and written across the middle is 'Arnova 9G2 - Full Root' in the bottom corner has 'A Finless Bob Root - Version 1.0 Arctools Support'
sorry ive blabbered on abit but i am completely stumped and cant get anything other than this. hopefully someone understands my description and can give me any advice in sorting it out.
cheers in advance, John.
Thanks Received: 3177
2012/07/23 - 21:12
john60470
2012/07/23 - 21:35
hi there thanks for the prompt reply, do you have any suggestion to get the tablet into the correct state to install the advised firmware? whatever i try i cannot get anything other than the screen described above. cheers again
86 Guest(s)
Devices in use: Desktop (83), Phone (3)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
