Network Options
dazzer
2012/01/31 - 16:25
Hi, i know this model hasn't got 3g, but there is serveral option (which i don't understand) on the device.
Please can someone explain how i can use this out and about other than my home, ihas anyone had any luck, or is there any way to upgrade to 3g?
Any help is very much appreciated.
Dazzer
alex
Forum Posts: 252
2012/02/02 - 22:37
hi i personally have not tried using a 3g stick in this device so i am not sure if any work someone else may have more information on this one,
i do however use my smartphone, most have the option, go into setting on you phone and enable internet sharing or wifi hotspot or somthing similar this then creates a wifi network through you 3g (or not in some cases) enabled phone
i know androds, blackberrys and wp7 (what i have) aswell as some LGs and nokias which use their own OS all have the option
let me no how you get on
alex
dazzer
2012/02/03 - 19:23
Thanks for your reply. I will have a look and see what options my phone has.
Not holding my breath though as my phone isn't that great. Might need to upgrade.
alex
Forum Posts: 252
2012/02/03 - 22:21
Ok what phone have you got?
Currently Online: boris_kolomiets
104 Guest(s)
Devices in use: Desktop (92), Phone (12), Tablet (1)
allanchu
konstantin0ss
nikoscc77
hacktes
Walldos
MOUNIR 1923
Topics: 6010
Members: 260642
