Lost password?
The forums are currently locked and only available for read only access
Help Black Screen
This topic is locked
maawii
2012/10/10 - 10:11
I tried flashing the NEOCM9 Rom, coming from Finless' ICS. After the flash proceedur my Arnova firstly didnt reboot. It remained a black screen. Plus now my Win8 doesnt recognize ist anymore. I cant get past the black screen. I tried to direct the unrecognized USB to the right driver, it doesnt work anymore. I hope you can help me.
Maawii
Thanks Received: 268
2012/10/10 - 13:45
when you connect the tablet to the pc and turn it on, do you get any reaction ?
maawii
2012/10/10 - 13:50
Yes, my PC registers a usb device, but can't tell what it is. Then I try to install the RK driver, and it says that its not compliant. This is on Win8, i havent jet tested the reaction on win7 or ubuntu. I will do that this afternoon. I can't try to flash another Rom, because RKFlasher says Found no Device.
On a side note, is there something like a hard reset?
2012/10/10 - 16:25
try on windows 7, windows 8 is not yet a mainstream operating system and could raise some problems in the drivers side.
84 Guest(s)
Devices in use: Desktop (81), Phone (3)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
