2012/12/19
Hello everyone,Â
i recently thought about attempting to get ICS on my arnova 9 g2 tablet.
downloaded rockchip batch tool and the firmware update ( http://www.arctablet.com/blog/featured/arnova-9g2-custom-firmware-upgrade-ics-google-play-root-face-unlock/ )Â
but my issue right no is with the 'flashing' of my tablet. i connect it up to the pc, turn it off. then put a pin in the reset and press the menu button which does something but not what it should, this is the on screen message on the pc i get, shortly after this my tablet turns on just like normal. any help as im a bit lost..Â
these images will show you what stage im currently at.Â
any help will be amazing
Try like this.
Connect the tablet to the pc.
Reset it using the clip, and shotly after press the menu button, keep them like this till you see a reaction from your pc.
Then install the drivers.
install java sdk, android sdk, without the api`s
enable usb debugging and issue this in adb
adb reboot bootloader
and see if you get a green light in rockchip tools, if you get one, you are good to go with the flashing.
you need java sdk for the instalation of the android sdk
http://www.oracle.com/opinions-on-teclast-p90hdchnetwork/java/javase/downloads/index.html
http://developer.android.com/sdk/index.html#download
http://developer.android.com/tools/index.html
If you do not understand all the stuff, check my signature and contact me via pm.
140 Guest(s)
Devices in use: Desktop (134), Phone (6)
spiik
nikitamaan
VMILCINOV
