First 9 G2 Fully Rooted ROM - TEST - By FInless
heedlessmunkey
Forum Posts: 14
2012/01/07 - 13:57
Server not found??
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 14:02
Sorry made a typo in the URL
http://www.helifreakswag.com/arn9g2_23_1_01_arctools.zip
Bob
heedlessmunkey
Forum Posts: 14
2012/01/07 - 14:26
Hangs on boot Frown
alex
Forum Posts: 252
2012/01/07 - 16:54
i dont have the option in arctools for 3.4.4 just 3.3.4
hung on the droid bootscreen
Surprised
alex
Forum Posts: 252
2012/01/07 - 17:19
hmm strange i just tried to install market the way i mentioned in the other thread and its done the same however i have not rebooted and was wondering weather it was reboot issue it ill re flash then restart the tablet and give you the outcome
EDIT
yep it wont reboot its not the market which it causing itYell
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 19:47
So you are saying... After the flash it boots.  The do nothing and and just reboot and thats it?  It hangs on the boot screen?
Bob
alex
Forum Posts: 252
2012/01/07 - 19:50
after you have flashed it the tablet boots - all fine you can do what you want however, if you want to restart your tablet for any reason even if you have made no changes after the flashing it just hangs on the android man bootscreen you made
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 19:52
Very odd.... I am going to cook up a STOCK ROM made from Admins dump.
Hang tight.  Please flash this and let me know if it does the same thing.
Be right back
Bob
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 20:09
OK I think I might know what is causing it.  In my package I upgraded to the 2.08 bootloader.  Stock ROM has 2.06.
So here is the stock ROM made from Admins dump using bootloader 2.06.
PLEASE FLASH the bootloader as well when you flash!  e.g. check the top box for bootloader in RKAndroid tool.
http://www.helifreakswag.com/arn9g2_23_stock_rom.zip
BTW, can I ask if you guys flashed the boot loader to begin with?  e.g. you check the bootloader box in RK Android tool?  If not maybe it's the reverse problem.  You need to flash 2.08?  Please let me know what you did.
Bob
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 20:29
Also make sure you eraseIDB every time just to make sure nothing is left behind!!!!!
Bob
alex
Forum Posts: 252
2012/01/07 - 20:35
starting dl
i did flash the boot loads and erased IDB
ill let you what happens when it flashes
heedlessmunkey
Forum Posts: 14
2012/01/07 - 20:37
I deliberately didn't flash the boot loader as didn't want to add any more change
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 20:51
Well it sound like one of you guys (Alex) did flash the bootloader and one of you guys did not.  So thats probably not it then.  It maybe because I made system too big for the 9 G2.
Let me know if the stock ROM works and if so I will start fresh from it.  If stock ROM does not work then I have just made a update.img I would like you guys to flash using RKBatch tool (not RKAndroid tool).  If that still doesnt work, then Admins dump must have a problem 🙁  Lets hope not!
Bob
alex
Forum Posts: 252
2012/01/07 - 21:23
2 things i dont now if its supposed to but the folder says its version 1.0.1 custom rom and there is no loader file to update (bootloader file is not existed)
shall i still flash it
finless
Stanton, Ca
Forum Posts: 604
2012/01/07 - 21:27
Ah OK forgot to do something.
In the zip is a file called settings.ini
Open that file in notepad (not word or something).
Under the section[Flash] change this:
[FLASH]
Loader_Path=image\RK29xxLoader(L)_V2.08.bin
And edit it to this
[FLASH]
Loader_Path=image\RK29xxLoader(L)_V2.06.bin
Save the file and then it will work.
Bob
Currently Online: masbass
112 Guest(s)
Devices in use: Desktop (90), Phone (20), Tablet (3)
Georges Planche
setupprinter
IvanSeter
chiguy229
Donh
elgransergy
