Problems with Arnova AN9G2I Firmware Update - Fixed
cap42
Forum Posts: 13
2012/08/28 - 12:58
Hi Guys,
 I've done the firmware dump 3 Times and its completed its setup running screen calibration and registering my Google account ect.
The first time none of the apps or the browser would open. I tried a couple of reboots but still the same. Firmware dump 2 went fine but kept freezing. Ok now on three and I'm getting multiple errors the process com.google.process.gapps has stopped and some of my app icons have disappeared  including the one for google play. Anyone any ideas for a solve on this or at worst a clean firmware dump for AN9 G2i.
Cheers Guys
Cap42
Thanks Received: 3169
2012/08/28 - 13:01
This isn't normal behaviour as this firmware is confirmed to work properly by many users.
I'll find the 9G2i stock firmware so you can restore it.
cap42
Forum Posts: 13
2012/08/28 - 13:31
Thanks admin. I'll give it one more try if you think the kasty-arn9g2-40-04 firmware is stable. I might just have a dodgy tab. I only bought it a week ago so if i can get the stock firmware back up ~I might return it with a fault to the retailer :)
Cheers
Cap42
Cap42
2012/08/28 - 14:38
About the firmware being stable, I'm not a daily user for this tablet and firmware, but that's what users & testers reported.
You can also try to go in Settings / Backup & reset / Factory data reset    to fully wipe the configuration.
The stock firmware came originally from here but I'll need to find some time to rebuild it, so it can be easily flashed.
cap42
Forum Posts: 13
2012/08/28 - 15:08
Already tried that..Thanks. I tried a gingerbread stock flash and it seemed to be stable enough but when i put kasty-arn9g2-40-04 back on its frozen again and won't boot after i've registered google and set up my email. I wouldn't be a daily user of this tab either  (galaxy tab ) but i would like to be able to use it for email and a browser at least. Is there a honeycomb 3.2 firmware for this tab?
Cheers
Cap42
Cap42
francky77
2012/08/28 - 15:39
bonjour ,j'ai flashe ma tablette Arnova 9 g 2 sous ice 4 et elle fonctionne bien et par moment j'ai des souci message 3parametre arretee" ,"google play arrete", horloge arrete ect que dois je faire merci de votre aide
cap42
Forum Posts: 13
2012/08/28 - 16:25
Bonjour je traduis de l'anglais ce donc méfiez-vous. Je pense que ce firmware est buggé et vraiment pas assez stable. Si vous avez votre firmware original je vous conseille de retour de flamme. J'espère que cette aide
cap42
Cap42
francky77
2012/08/28 - 16:35
je vous remercie pour votre reponse mais puis je avoir un ice 4 de bonne qualite ou repase androide gimber
merci d'avance
2012/08/28 - 17:28
Cheers
Cap42
There is no Android 3.2 Honeycomb release for the Arnova 9 G2 / 9 G2i.
Here is a firmware dump of the Arnova 9 G2i, in case you want to restore your device without Google Play.
http://www.arctablet.com/assets/firmware/Arnova9G2/Arnova9G2ICS_stock_dump.zip
This firmware was made from a firmware dump provided by the guys of the androidiani.com Italian forum.
cap42
Forum Posts: 13
2012/08/29 - 13:36
Hi Admin,
Think I might have found a fix. I used RK29update.exe to connect to my tab and used EraseIDB to partially format the tablet. I then used RKBatchTool.exe to restore Arnova9G2ICS_stock_dump.zip above and presto every ran ok except i noticed that the AppsLib didn't load with the above dump. So I ran  RK29update.exe, again formatting and then Arnova AN9G2I Firmware Update kasty-arn9g2-40-04 and guess what ? It been running stable for the last hour. I rebooted it a good few times and it seem to be running ok. Email and a couple of games apps on and I'll keep you updated. Thanks for all your help. If it wasn't for the forum I have chucked it in.
Many Thanks
Cap42
Cap42
cap42
Forum Posts: 13
2012/08/31 - 23:49
Hi Admin,
 Just to let you know , the Arnova is running like a dream. Wife delighted with it . (keeps her away from my Galaxy Tab) . Have had no glitches with it. Apps running smoothly. Email working as well. Think the trick was using RK29update tool to partially format it done the trick. Once again BIG thank you to your good self for all your support.
Kiss
Cheers
Cap42
Cap42
100 Guest(s)
Devices in use: Desktop (87), Phone (9), Tablet (4)
Walldos
MOUNIR 1923
cynthiavd
rafi462
PillowMan
Gosha63rus
Topics: 6010
Members: 260638
