Arnova 9 G2 Android 4.0 ICS custom firmware with Google Play
alex
Forum Posts: 252
61
2012/06/02 - 00:49
it will be the flash player either not installed or the version which is installed is incompatable. try downloading another version of flash it may help
Thanks Received: 3170
62
2012/06/02 - 00:54
Or more probably, Google Play does not like the device signature and refuses to install Youtube app.
I'll have a look later to see if changing the signature (ro.build.fingerprint and ro.build.description values in /system/build.prop) helps.
alex
Forum Posts: 252
63
2012/06/02 - 00:56
oh yes sorry i misread the post i read it as wont play videos for some reason Yell
falanw
64
2012/06/02 - 01:00
Hi, thanks for your help. If I go into Youtube via the browser I can play videos that way unless I try to make them full screen in which case I just get a blank screen
65
2012/06/02 - 01:05
Until the problem is fixed, you can download and install the Youtube application from there:
http://www.arctablet.com/assets/apps/GoogleYouTube_2.4.4.apk
Download, copy to your device and execute it thru the File/Explorer application.
alex
Forum Posts: 252
66
2012/06/02 - 01:06
often if you have a video player on yourdevice you can play fullscreen via them so as a shortterm fix i reccomend saving youtube website on home screen and download a video player app through google play and it should work
edit
or that^
falanw
67
2012/06/02 - 01:27
Thank you for your help, I've downloaded the Arctablet Youtube app and it worked straight away so I can get back to watching my phone and tech reviews. And also, if anyone else is wondering whether or not to flash their Arnova 9G2 I can fully recommend it as it was relatively easy to do and it makes the Tablet run very smoothly - Thanks guys!
pletorcoe
68
2012/06/02 - 12:25
Good morning! i need help please. last night I flashed my regular Arnova 9G 2 but something was wrong. After flashing the tablet doesn't work. When I turn on the tablet it only shows the Arnova logo and it do not anything else. Help, please!!!!!!Frown
philipcullen
69
2012/06/02 - 14:52
Installed this in this last week and it's transformed the Arnova. Absolutely brilliant as it's made a good tablet brilliant. Why, oh why oh why does it take so long for all of the manufacturers to provide these updates to us.
The install all went very well. I then installed all of the Google Play apps that I needed. Then set up the email accounts on the default email package.
Incidentally, I've got an HTC Desire S which has Gingerbread. I can't wait for ICE on that.
pletorcoe
70
2012/06/02 - 15:16
Nobody whith problems flhasing?? I have a beautifull "brick" now.
Help, please!! CryCryCryCryCryCryCryCryCryCryCryCryCryCry
alex
Forum Posts: 252
71
2012/06/02 - 20:12
did you remember to check remove idb?
reflash and try it Confused
let me know how it goes
kmike
72
2012/06/03 - 18:52
First of all, thanks for this tutorial. Despite the low memory of the Arnova G9, it makes the tablet work much better.
Now, I have a couple of questions:
1.- Can you play avi movies? I've imported a bunch of avi videos that i made with a Nikon camera and no player can read them (except Mobo Player, but colors are lost or mismatched).
2.- Why are there two galleries (com.google.android.gallery3d and com.android.gallery3d)?
73
2012/06/03 - 23:38
AVI movies can contain an exotic video or audio format that the Arnova Video Player does not recognize.
Have a look at MX Player, which is a powerful Video Player for the 9 G2.
About the 2 galleries, it's a small glitch in the custom firmware, it will be fixed soon. You case use either app.
smillen
74
2012/06/04 - 13:08
ADMIN
why do some of the video streaming type apps not work in full screen
Netflix just a blank screen as it always runs in full screen(was ok on Gingerbread)
BBC iplayer
Youtube
IMDB is ok
heedlessmunkey
Forum Posts: 14
75
2012/06/04 - 16:12
smillen said
ADMIN
BBC iplayer
Youtube
IMDB is ok
Mine is the same although even bbc iplayer doesn't work properly the video plays way to quick and then it stalls. It must be to do with the adobe flash and ICS. I'm assuming the working apps don't use flash to play the video. I've tried various versions of flash and none work.
85 Guest(s)
Devices in use: Desktop (80), Phone (5)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
