Arnova 9 G2 Android 4.0 ICS custom firmware with Google Play
alex
Forum Posts: 252
46
2012/05/27 - 19:59
Noproblemo glad i could help 🙂 what was the problem? if i may ask
Giorgio97
Italy
47
2012/05/27 - 20:01
The problem was the recovery mode, my recovery mode was wrong!!! Thankss!!
alex
Forum Posts: 252
48
2012/05/27 - 20:59
yes it took me a while to figure it out at first too 😛
AndroidFUN_MD
Forum Posts: 11
49
2012/05/28 - 11:12
please make a ICS firmware for arnova 7 g2, too. because we are waiting for that:|
Xose M
Galiza
50
2012/05/29 - 06:53
I've just registered to say big "thanks"
I bought an Arnova 9 G2i that already had ICS but without g.play (market) and g.apps. So far it works fine with your firm and had no issues instaling apps from google.play (so far).
Arnova 9G2i is somehow limited (performance wise) but perfect for my purposes at given price.
thanks again and regardsWink
imstuckatboot
51
2012/05/29 - 21:31
i have a big problem, iv installed the ics and thats fine so far but unfortunalty i didnt selects removeidb and i cant do anything everytime i try to reset the arnova 9g2 it just gets stuck at the boot screen         please help
i have just contacted arnova but i wasnt sure if i should say about putting ics on it so i didnt but im waiting on a reply.
thanks,
           lewis                                       YellYellYellYellYellYellYellYellYellYellYell
alex
Forum Posts: 252
52
2012/05/30 - 00:20
thanks,
no problem just stickit back into recovery and reflash properly 😛
imstuckatboot
53
2012/05/30 - 09:14
Omg if that works ( ill try in a bit ) u r the best person in the world atm. SmileLaugh
imstuckatboot
54
2012/05/30 - 09:37
u r the best person in the world it has worked
alex
Forum Posts: 252
55
2012/05/30 - 11:02
haha ofc it worked 😉
glad i could help
and thats going in my signature:P
az
56
2012/05/31 - 22:29
Hello!! After thinking a lot about flashing or not - I tried...but: now while writing data to flash, after about 10% of the data:
ERROR: Download file failed
ERROR: Run failed occurs
I´m quite stressed at the moment, as I cannot get on with flashing...and my Arnova 9 G2 also does not work any more...it looked so easy, reading all your postings. I hope, I do not have a broken device, where the flash memory has a fault. Any HELP very welcome! Thank you!
alex
Forum Posts: 252
57
2012/06/01 - 01:18
hey this may sound sill but some time the obvoius answers are overlooked, are you sure your device is charged, pluged in correctly and have u checked erase ibd or whatever its called?
az
58
2012/06/01 - 06:50
Thank you! The device is charged, plugged in correctly, and I checked eraseIDB several times. Instead of 565 376 KB only 56296 KB are written. I tried several times now, always with the same result.
Finally I was succesful now - wow - absolutely great!!! I do not know what happened - I changed to fixed LAN, and changed the USB hub at my computer...then it worked!!! Seems, the WLAN at home was to slow to download everything adequately. thx to alex, who pointed to something obvious, keeping me going on flashing!Smile
alex
Forum Posts: 252
59
2012/06/01 - 12:25
im not sure i directley helped you there 😛 but im glad u figured it out 🙂
falanw
60
2012/06/01 - 22:06
Just installed ICS Flash, took 2 attempts but now working great although Play Store says You Tube app is not compatible with my device - any ideas why?
61 Guest(s)
Devices in use: Desktop (59), Phone (2)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
