read the post of taotsing and fallow what he was writen
2012/05/17
Can anyone confirm that they have the same video issue as belowÂ
I've installed Netflix, which previously ran fine on Gingerbread, I can login and select a video, the video player window opens but the video never starts a black screen with the controls (It does not freeze the app)
I've installed BBC Iplayer which uses the mobile version as It says the desktop version is not suported, I can select a video which in very choppy in small screen but when I try to go full screen I get the same as Netflix a black screen with the controls (It does not freeze the app)
When viewing videos via youtube website It plays the video fine in small screen but If I go fullcreen I get the same as above a black screen with the controls (It does not freeze the app)
I don`t have a 9g2, i only try to help people.
The 9g3 does not have the flash player included and i suposed that in the g2 the situation is the same, i really don`t know what admin added in the custom rom.
From what i know the rockchip tablets have a read only system partition so i don`t know how you removed a system app because in theory you can`t do that.
Wait for admin or someone with the same device and you should get an answer.
register said
does this rom support usb to lan functionality? can anyone test?
Already tested with my Trendnet TU2-ET100, does not work.Â
I'm looking for that feature too, I'll make a post for sure when I find a solution for Usb Ethernet on Arnova G2 devices...
2012/05/22
Hi All,
First thank you for sharing all your posts for our g2 devices.. I've recently flashed my 9g2 (recovery mode wth just menu & power) I now have ICS runing init.
But I have a problem accessing my SD card. It says damaged or not installed. I can't install/move anything to my SD card. I've flashed my device 2x but didn't solvete problem.
I hope someone can help.
Thanks in advance. More power!
-weelite
2012/05/25
Hello, I just got a 9.7 inch G2 and tried the ICS flash with Google apps. Installed fine, but every few seconds I am getting an error message "Unfortunately, the process android.process.media has stopped". Yes it is unfortunate, cos I can't do much useful stuff with the table if it keeps throwing up this message every few seconds that I have to OK for it to come straight back again. Suggestions please?
Currently Online: patrioti
93 Guest(s)
Devices in use: Desktop (77), Phone (17)
speedyftp
georgicaa97
kkn
LatifMohammadi
arthurmax01
yung1961
