Arnova 8c G3 review (1Ghz Cortex A8, 1GB RAM, 8" 800x600 screen, Android 4.0)
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/07/07 - 19:09
Arnova 8c G3 is one of the new 8" tablets from the Arnova G3 line-up. Arnova 8c G3, which is manufactured by Yifang, with slightly different design can also be found in the shops selling as Nextbook Premium 8SE and one beloved Russian company added HDMI-output and OTG and Prestigio Multipad 5080CPRO was born. Many things in this review should also apply to these two models, though design, battery and firmware stuff can be a little bit different. We tried running an 5080CPRO firmware on it and though it worked, we recommend using official firmware from Arnova or custom firmwares developed for Arnova 8c G3.
Image Enlarger
Arnova 8c G3 video unboxing&preview
Arnova 8c G3 specifications
Operating System Android 4.0.3 (Ice Cream Sandwich)
Linux Kernel Version: 3.0.8+
Build number: 20120406
CPU single core Rockchip 2918 CPU running at 1 Ghz
Integrated GPU: Vivante Corporation GC800
Flash Storage Memory Capacity 8 GB
Speed: Class 6 range (tested Read 15134 kB/s, Write 6964 kB/s)
System Memory 1024 Mb
Additional storage Micro SD slot (SDHC compatible)
Display 800×600 TFT LCD 8 inches (4/3 ratio)
capacitive 5 points screen
125 DPI (medium)
Bluetooth No
Wifi 802.11 b/g/n
Gravity Sensor Yes
Camera 0.3Mp (front facing)
GPS No
HDMI No
Interfaces micro USB Slave Mass Storage Class (MSC)
MicroSD slot
Battery life Video playing test: 5 hours 46 minutes
check our Archos and Arnova battery…
Currently Online: ri9000, hamishduke
73 Guest(s)
Devices in use: Desktop (66), Phone (9)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
