2012/09/24
Case said
This works fine.
I do have one issue.
The calendar sync for my accounts do all not work.
All sync calender entries show 'sync com.android.calendar'.
Looks a bit strange to me. Is this a firmware issue?
I'm having the exact same issue . Believe the fix should be the same as the fix for the 7 G3 detailed here:
http://www.arctablet.com/blog/forum/arnova-7-g3/fixing-the-google-calendar-sync-problem/
there's a stopgap method detailed there
own both Arnova 8c G3 & Arnova 7 G2 tablets plus a Samsung Galaxy S2
2012/09/24
Everything is fine except the calendar doesn't synch. Believe may be related to the fixed calendar sync issue for the 7 G3:
2012/09/11
Thought also about that this may be related to the fixed calendar sync issue for the 7 G3.
Had just time to install it, ...., it works!
Just rename the old ones (extension), so you do have a copy.
Download the new ones somewhere and run the apk's, reboot: works fine.
I 'm happy now
2012/09/26
hello guys, i have an issue after installing google play on my tablet... so i'm trying to use Chrome instead of the default browser but it isn't working well. when i open a red frame flashes around the window andthen when I select a website like neowin.net it just sends me back to the homescreen. I noticed google.com sometimes works and ebay too but they are very choppy and in ebay i can't zoom in. I tried uninstalling and reinstalling, restoring the tablet, but it still doing it. I tried Opera as well and it somewhat works but has its own isses too. So far i'm stuck with the default browser because it is the only usable one.
Did your tablets work fine after installing google play, is chrome working ok for you? or is there something else i have to adjust to make my tablet work the way it should? I did the easy install procedure.
2012/12/29
Hi!
I recently buy a arnova 8c g3 and i want the google play store on my tablet. as i’m from Portugal, is the portuguese language still there once i install this custom firmware or this is only for english language?
And, is there a way to restore to the original firmware version?
Sorry for my english!
65 Guest(s)
Devices in use: Desktop (60), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
