2013/03/08
I have recently purchased an Arnova 8c g3, first thing I did was installed ArcTools and installed the custom firmware.
My question is, is there a way to disable or hide the fact that the tablet is rooted, the main reason I ask is that the tablet is for my wife and son to use, they want to be able to use Flixster and stream our Ultraviolet movies. Â But the Flixster app what allow this as it knows the tablet is root.
Thanks in advance for any help.
Jon
You can remove the root, we did not found yet a method that hides the root.
It may worth checking also on xda.
jonkong
try this
https://play.google.com/store/apps/details?id=com.zachspong.temprootremover&hl=ro
Or you can use a file explorer that has mounting capabilities, therefore you will mount the system partition as rw, delete the superuser, and su files, restart the tablet, and check if flixter works then
88 Guest(s)
Devices in use: Desktop (81), Phone (7)
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
