2012/12/12
PaulErb said
I tried to make some screenshots for you but was not able. Looks not easy on that device. The typical key shortcuts are not working.
Hi PaulErb
Push the switch and volume control (-) simultaneously for a few seconds. The screen picture is created and stored in the Gallery.
The following users say thank you to meandmyphone for this useful post:
PaulErb, GUSA79, 1Bun
2012/12/25
Thank you a lot.
Could create the screenshots now. But than see that somehow I gain the write access and could install the firmware.
The Google Play works now on my tablet as well. But for some apps in the store I just see that the app is not supported for my hardware. Same apps can be installed on my smartphone running Android 4.0.3.
Best regards and great community support.
2012/12/18
bryan140789 said
aid and installed the custom firmware that worked perfect till now restart and again turn on the flash and still the same if someone can help me since I bought it 4 days thank you very much and sorry for my bad English
If you could explain your problem it would help.
In any case you don't need to re-flash every time, just make a soft reset.
You could do it by going into Settings and then StartWizard.
The following users say thank you to killerkraft for this useful post:
bryan140789I'll soon rework the 8b G3 rooted custom, it will provide 2 GB of storage space for apps.
1Bun, Geylord, hanshansen, berik6, Dino1981 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/12/20
hi
I have also purchased a Arnova 8bG3 and have downloaded the update firmware for Google Play but when i try to drag it on to the root it show a no entry sign i have placed it onto the SD card and that seems to have had no affect , what am i doing wrong. would really like to have access to Google play rather than the very antiquated applibbs.
regards
enable the usb storage and to the operation from the computer
move the update from the directory where you download it to the root of the storage.
you can also flash with rockchip tools in the end
2012/12/20
What do you think ... how long will it take. The app storage space is the biggest problem of the Arnova 8b G3. It would be great to have 2 GB for apps.
Does anyone have WLAN-disconnection-problems with this firmware too? My WLAN disconnects every 5 minutes.
THX
58 Guest(s)
Devices in use: Desktop (53), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
