You can probably fix it using ADB, but it's not the easiest option. Better flash your firmware, check our Arnova 8 G3 custom firmware article second method, alternative install procedure.
All drivers for Windows systems are included in Rockchip flasher tool package.
have you used this guide ?
http://www.arctablet.com/blog/featured/arnova-8-g3-custom-firmware-google-play-root/
did you use the upgrade option ?
2012/09/27
I used Rockchip method yes i used upgrade method.
Loading firmware...
Loading firmware Finished.
Loading firmware...
**********Upgrade Action**********
**********Upgrade Start Total<1>**********
<Layer 2-2> Test Device Start
<Layer 2-2> Test Device Success
<Layer 2-2> Check Chip Start
<Layer 2-2> Check Chip Success
<Layer 2-2> Get FlashInfo Start
<Layer 2-2> Get FlashInfo Success
<Layer 2-2> Prepare IDB Start
<Layer 2-2> Prepare IDB Success
<Layer 2-2> Download IDB Start
<Layer 2-2> Download IDB Success
<Layer 2-2> Reset Device Start
<Layer 2-2> Reset Device Success
<Layer 2-2> Wait For Loader Start
<Layer 2-2> Wait For Loader Success
<Layer 2-2> Download Firmware Start
<Layer 2-2> Download Firmware Success
**********Upgrade Done Success<1> Fail<0>**********
If i turn on is booting ARNOVA logo then is turning off, if i charge the tablet is turning on an off automaticaly. please help me.
try the restore option
did you had battery full when you tried the chainfire app ?
2012/11/22
I too am having the same problem, flashing arnova then reboot. susspect dead battery, and tried to hold down reset button while plugging in charger, but it still just goes into reboot loop. I also can get a green android picture with a red exclamation point when i hold down reset button and push power on button when not attached to charger. help please, as galaxy tab2's are on sale.
Just flash again a firmware such as this Arnova 8 G3 official one or our custom firmware with Rockchip Batch Tool.
51 Guest(s)
Devices in use: Desktop (44), Phone (6), Tablet (1)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
