Officiel ARNOVA 7 G2 MODIFFIED System for ARNOVA 8 G2
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/01/24 - 20:14
Firmware changes
Version 2011.12.13 - December 13rd, 2011
    Support for ARCHOS G9 3G Stick (via USB host cable)
    Flash™ 11.1 compatible
    Minor bugs fixed
    Market by sowa's
    root and all app google
    start games that does not work with the old firmware 8G2
    inclu long press search for kill status bar for Full Screen game and force rotate
Link
https://rapidshare.com/files/986837782/update.img
or
http://www.digzip.com/files/0T2FY0BU/update.img
Sowa
Russia, Novorossiysk
Forum Posts: 47
Thanks Received: 5
2012/01/25 - 17:54
Hi morka
I checked out your ROM. After flashing with Rk29batchtool tablet will not boot. Restarted again in the flash-mode.
When you upgrade the standard method of getting the message:
E: Can't find kernel in [PACKAGE: kernel]
E: Failure at line 7:
write_image PACKAGE: kernel KERNEL:
Update failed, please reboot and update again!
China phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/01/25 - 18:41
Hi sowa
here I have built with sdk RK29xx
https://rapidshare.com/files/768600263/RK29xx.for.AN8G2.zip
chris
2012/01/26 - 16:24
hi morka.
i would love to try your modified rom.
just one question. should it now install without problems using the standard  method.
tks a lot in adv.
chris
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/01/26 - 18:11
chris said
hi morka.
tks a lot in adv.
chris
Hi chris
I can not certified it would work there as an error in the update.img
you can use the Rockchip SDK to build update.img
click mkupdate.bat to build
for the correction of the file update-script is in the zip opens with notepad
and replace all with:
#!enable_script
# ÔÚÉý¼¶Ê±ÏÔʾÌáʾÐÅÏ¢
print "\nPlease KEEP your USB cable or DC-in connected\n"
print "Do NOT remove SD card form the device\n\n"
# Éý¼¶kernel
#write_image PACKAGE:kernel KERNEL:
#check_image PACKAGE:kernel KERNEL:
# Éý¼¶boot
#write_image PACKAGE:boot BOOT:
#check_image PACKAGE:boot BOOT:
# Éý¼¶recovery
#write_image PACKAGE:recovery RECOVERY:
#check_image PACKAGE:recovery RECOVERY:
# Éý¼¶system
delete_recursive SYSTEM:/
write_image PACKAGE:system SYSTEM:
check_image PACKAGE:system SYSTEM:
# Éý¼¶backup
#write_image PACKAGE:backup BACKUP:
#check_image PACKAGE:backup BACKUP:
# Éý¼¶parameter
write_image PACKAGE:parameter PARAMETER:
check_image PACKAGE:parameter PARAMETER:
# ¸ñʽ»¯Êý¾Ý·ÖÇø
#format DATA:
format CACHE:
delete_recursive DATA:dalvik-cache
# дÈëÃüÁÔÚbootloaderÆô¶¯Ê±Éý¼¶bootloader
write_blcmd update-bootloader
# ½«bootloader´æ·Åµ½MISC·ÖÇø
write_loader PACKAGE:bootloader MISC: 0xC000
# ɾ³ýÉý¼¶°ü
delete PACKAGE:
lohtse
Forum Posts: 157
2012/02/07 - 13:37
want to give this a try BUT is it working and whats the advantages?????? over latest sowa's build 4.1???
85 Guest(s)
Devices in use: Desktop (82), Phone (3)
dcatalan
dshepp
kaironit
qweku1
himeji
robotx
Topics: 6028
Members: 261291
