MorkaModJB v1.00 all model G2 and G3
Thanks Received: 268
2012/11/16 - 16:27
the
3Q RC0710B is a russian version of the arnova 7g2
Here is a link for the firmware Morka, maybe it helps you :)
They have almost the same devices as arnova/archos but they release far more updates :)
http://www.3-q.ru/files/fw/3Q_RC0710B_24082012_V1.0.5_fix.rar
Darragh Cooney
2012/11/16 - 17:05
globula_neagra said
the
How do I properly flash this on Arnova 7G2?
2012/11/16 - 17:10
The included 3Q_RC0710B_24082012_V1.0.5_fix.img file seems to be a regular firmware image, so just flash the .img file with Rockchip Batch tool that is included in the archive or from our Rockchip flasher page.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/11/16 - 21:25
@Agation.52
Here is the code BatteryService in service.jar for JellyBean
package com.android.server;
import android.app.ActivityManagerNative;
import android.content.ContentResolver;
import android.content.Context;
import android.content.Intent;
import android.content.res.Resources;
import android.os.Binder;
import android.os.RemoteException;
import android.os.SystemClock;
import android.os.UEventObserver;
import android.os.UEventObserver.UEvent;
import android.provider.Settings.Secure;
import android.util.EventLog;
import android.util.Slog;
import com.android.internal.app.IBatteryStats;
import com.android.server.am.BatteryStatsService;
import java.io.File;
import java.io.FileDescriptor;
import java.io.FileWriter;
import java.io.IOException;
import java.io.PrintWriter;
class BatteryService extends Binder
private static final int BATTERY_PLUGGED_NONE = 0;
static final int BATTERY_SCALE = 100;
private static final String BATTERY_STATS_SERVICE_NAME = "batteryinfo";
private static final String[] DUMPSYS_ARGS = { "--checkin", "-u" };
private static final String DUMPSYS_DATA_PATH = "/data/system/";
private static final int DUMP_MAX_LENGTH = 24576;
private static final boolean LOCAL_LOGV;
private static final String TAG = BatteryService.class.getSimpleName();
private static long mCount = 0L;
private boolean mAcOnline;
private int mBatteryHealth;
private int mBatteryLevel;
private boolean mBatteryLevelCritical;
private boolean mBatteryPresent;
private final IBatteryStats mBatteryStats;
private int mBatteryStatus;
private String mBatteryTechnology;
private int mBatteryTemperature;
private int mBatteryVoltage;
private final Context mContext;
private int mCriticalBatteryLevel;
private int mDischargeStartLevel;
private long mDischargeStartTime;
private int mInvalidCharger;
private UEventObserver mInvalidChargerObserver = new UEventObserver()
public void onUEvent(UEventObserver.UEvent paramAnonymousUEvent)
if ("1".equals(paramAnonymousUEvent.get("SWITCH_STATE")));
for (int i = 1; ; i = 0)
if (BatteryService.this.mInvalidCharger != i)
BatteryService.access$102(BatteryService.this, i);
BatteryService.this.update();
return;
private int mLastBatteryHealth;
private int mLastBatteryLevel;
private boolean mLastBatteryLevelCritical;
private boolean mLastBatteryPresent;
private int mLastBatteryStatus;
private int mLastBatteryTemperature;
private int mLastBatteryVoltage;
private int mLastInvalidCharger;
private int mLastPlugType = -1;
private Led mLed;
private int mLowBatteryCloseWarningLevel;
private int mLowBatteryWarningLevel;
private int mPlugType;
private UEventObserver mPowerSupplyObserver = new UEventObserver()
private boolean mSentLowBatteryBroadcast = false;
private boolean mUsbOnline;
public BatteryService(Context paramContext, LightsService paramLightsService)
this.mContext = paramContext;
this.mLed = new Led(paramContext, paramLightsService);
this.mBatteryStats = BatteryStatsService.getService();
this.mCriticalBatteryLevel = this.mContext.getResources().getInteger(17694739);
this.mLowBatteryWarningLevel = this.mContext.getResources().getInteger(17694740);
this.mLowBatteryCloseWarningLevel = this.mContext.getResources().getInteger(17694741);
this.mPowerSupplyObserver.startObserving("SUBSYSTEM=power_supply");
if (new File("/sys/devices/virtual/switch/invalid_charger/state").exists())
this.mInvalidChargerObserver.startObserving("DEVPATH=/devices/virtual/switch/invalid_charger");
update();
private final int getIcon(int paramInt)
int i = 17302791;
if (this.mBatteryStatus == 2);
while (true)
return i;
if (this.mBatteryStatus == 3)
i = 17302777;
else if ((this.mBatteryStatus == 4) || (this.mBatteryStatus == 5))
if ((!isPowered()) || (this.mBatteryLevel < 100))
i = 17302777;
else
i = 17302805;
// ERROR //
private final void logBatteryStats()
// Byte code:
// 0: ldc 13
// 2: invokestatic 195 android/os/ServiceManager:getService (Ljava/lang/String;)Landroid/os/IBinder;
// 5: astore_1
// 6: aload_1
// 7: ifnonnull +4 -> 11
// 10: return
// 11: aload_0
// 12: getfield 103 com/android/server/BatteryService:mContext Landroid/content/Context;
// 15: ldc 197
// 17: invokevirtual 201 android/content/Context:getSystemService (Ljava/lang/String;)Ljava/lang/Object;
// 20: checkcast 203 android/os/DropBoxManager
// 23: astore_2
// 24: aload_2
// 25: ifnull -15 -> 10
// 28: aload_2
// 29: ldc 205
// 31: invokevirtual 209 android/os/DropBoxManager:isTagEnabled (Ljava/lang/String;)Z
// 34: ifeq -24 -> 10
// 37: aconst_null
// 38: astore_3
// 39: aconst_null
// 40: astore 4
// 42: new 149 java/io/File
// 45: dup
// 46: ldc 211
// 48: invokespecial 153 java/io/File:<init> (Ljava/lang/String;)V
// 51: astore 5
// 53: new 213 java/io/FileOutputStream
// 56: dup
// 57: aload 5
// 59: invokespecial 216 java/io/FileOutputStream:<init> (Ljava/io/File;)V
// 62: astore 6
// 64: aload_1
// 65: aload 6
// 67: invokevirtual 220 java/io/FileOutputStream:getFD ()Ljava/io/FileDescriptor;
// 70: getstatic 79 com/android/server/BatteryService:DUMPSYS_ARGS [Ljava/lang/String;
// 73: invokeinterface 226 3 0
// 78: aload 6
// 80: invokestatic 232 android/os/FileUtils:sync (Ljava/io/FileOutputStream;)Z
// 83: pop
// 84: aload_2
// 85: ldc 205
// 87: aload 5
// 89: iconst_2
// 90: invokevirtual 236 android/os/DropBoxManager:addFile (Ljava/lang/String;Ljava/io/File;I)V
// 93: aload 6
// 95: ifnull +8 -> 103
// 98: aload 6
// 100: invokevirtual 239 java/io/FileOutputStream:close ()V
// 103: aload 5
// 105: ifnull +353 -> 458
// 108: aload 5
// 110: invokevirtual 242 java/io/File:delete ()Z
// 113: ifne +345 -> 458
// 116: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 119: new 244 java/lang/StringBuilder
// 122: dup
// 123: invokespecial 245 java/lang/StringBuilder:<init> ()V
// 126: ldc 247
// 128: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 131: aload 5
// 133: invokevirtual 254 java/io/File:getAbsolutePath ()Ljava/lang/String;
// 136: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 139: invokevirtual 257 java/lang/StringBuilder:toString ()Ljava/lang/String;
// 142: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 145: pop
// 146: goto -136 -> 10
// 149: astore 23
// 151: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 154: ldc_w 265
// 157: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 160: pop
// 161: goto -58 -> 103
// 164: astore 7
// 166: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 169: ldc_w 267
// 172: aload 7
// 174: invokestatic 270 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;Ljava/lang/Throwable;)I
// 177: pop
// 178: aload 4
// 180: ifnull +8 -> 188
// 183: aload 4
// 185: invokevirtual 239 java/io/FileOutputStream:close ()V
// 188: aload_3
// 189: ifnull -179 -> 10
// 192: aload_3
// 193: invokevirtual 242 java/io/File:delete ()Z
// 196: ifne -186 -> 10
// 199: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 202: new 244 java/lang/StringBuilder
// 205: dup
// 206: invokespecial 245 java/lang/StringBuilder:<init> ()V
// 209: ldc 247
// 211: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 214: aload_3
// 215: invokevirtual 254 java/io/File:getAbsolutePath ()Ljava/lang/String;
// 218: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 221: invokevirtual 257 java/lang/StringBuilder:toString ()Ljava/lang/String;
// 224: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 227: pop
// 228: goto -218 -> 10
// 231: astore 14
// 233: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 236: ldc_w 265
// 239: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 242: pop
// 243: goto -55 -> 188
// 246: astore 16
// 248: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 251: ldc_w 272
// 254: aload 16
// 256: invokestatic 270 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;Ljava/lang/Throwable;)I
// 259: pop
// 260: aload 4
// 262: ifnull +8 -> 270
// 265: aload 4
// 267: invokevirtual 239 java/io/FileOutputStream:close ()V
// 270: aload_3
// 271: ifnull -261 -> 10
// 274: aload_3
// 275: invokevirtual 242 java/io/File:delete ()Z
// 278: ifne -268 -> 10
// 281: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 284: new 244 java/lang/StringBuilder
// 287: dup
// 288: invokespecial 245 java/lang/StringBuilder:<init> ()V
// 291: ldc 247
// 293: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 296: aload_3
// 297: invokevirtual 254 java/io/File:getAbsolutePath ()Ljava/lang/String;
// 300: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 303: invokevirtual 257 java/lang/StringBuilder:toString ()Ljava/lang/String;
// 306: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 309: pop
// 310: goto -300 -> 10
// 313: astore 19
// 315: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 318: ldc_w 265
// 321: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 324: pop
// 325: goto -55 -> 270
// 328: astore 8
// 330: aload 4
// 332: ifnull +8 -> 340
// 335: aload 4
// 337: invokevirtual 239 java/io/FileOutputStream:close ()V
// 340: aload_3
// 341: ifnull +39 -> 380
// 344: aload_3
// 345: invokevirtual 242 java/io/File:delete ()Z
// 348: ifne +32 -> 380
// 351: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 354: new 244 java/lang/StringBuilder
// 357: dup
// 358: invokespecial 245 java/lang/StringBuilder:<init> ()V
// 361: ldc 247
// 363: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 366: aload_3
// 367: invokevirtual 254 java/io/File:getAbsolutePath ()Ljava/lang/String;
// 370: invokevirtual 251 java/lang/StringBuilder:append (Ljava/lang/String;)Ljava/lang/StringBuilder;
// 373: invokevirtual 257 java/lang/StringBuilder:toString ()Ljava/lang/String;
// 376: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 379: pop
// 380: aload 8
// 382: athrow
// 383: astore 10
// 385: getstatic 71 com/android/server/BatteryService:TAG Ljava/lang/String;
// 388: ldc_w 265
// 391: invokestatic 263 android/util/Slog:e (Ljava/lang/String;Ljava/lang/String;)I
// 394: pop
// 395: goto -55 -> 340
// 398: astore 8
// 400: aload 5
// 402: astore_3
// 403: goto -73 -> 330
// 406: astore 8
// 408: aload 6
// 410: astore 4
// 412: aload 5
// 414: astore_3
// 415: goto -85 -> 330
// 418: astore 16
// 420: aload 5
// 422: astore_3
// 423: goto -175 -> 248
// 426: astore 16
// 428: aload 6
// 430: astore 4
// 432: aload 5
// 434: astore_3
// 435: goto -187 -> 248
// 438: astore 7
// 440: aload 5
// 442: astore_3
// 443: goto -277 -> 166
// 446: astore 7
// 448: aload 6
// 450: astore 4
// 452: aload 5
// 454: astore_3
// 455: goto -289 -> 166
// 458: goto -448 -> 10
// Exception table:
// from to target type
// 98 103 149 java/io/IOException
// 42 53 164 android/os/RemoteException
// 183 188 231 java/io/IOException
// 42 53 246 java/io/IOException
// 265 270 313 java/io/IOException
// 42 53 328 finally
// 166 178 328 finally
// 248 260 328 finally
// 335 340 383 java/io/IOException
// 53 64 398 finally
// 64 93 406 finally
// 53 64 418 java/io/IOException
// 64 93 426 java/io/IOException
// 53 64 438 android/os/RemoteException
// 64 93 446 android/os/RemoteException
private final void logOutlier(long paramLong)
ContentResolver localContentResolver = this.mContext.getContentResolver();
String str1 = Settings.Secure.getString(localContentResolver, "battery_discharge_threshold");
String str2 = Settings.Secure.getString(localContentResolver, "battery_discharge_duration_threshold");
if ((str1 != null) && (str2 != null));
try
long l = Long.parseLong(str2);
int i = Integer.parseInt(str1);
if ((paramLong <= l) && (this.mDischargeStartLevel - this.mBatteryLevel >= i))
logBatteryStats();
return;
catch (NumberFormatException localNumberFormatException)
while (true)
Slog.e(TAG, "Invalid DischargeThresholds GService string: " + str2 + " or " + str1);
private native void native_update();
private void processValues()
int i = 0;
long l = 0L;
boolean bool1;
if (this.mBatteryLevel <= this.mCriticalBatteryLevel)
bool1 = true;
while (true)
this.mBatteryLevelCritical = bool1;
if (this.mAcOnline)
this.mPlugType = 1;
try
label36: writeBatteryCapacity(this.mBatteryLevel);
mCount = 1L;
catch (IOException localIOException)
try
label47: this.mBatteryStats.setBatteryState(this.mBatteryStatus, this.mBatteryHealth, this.mPlugType, this.mBatteryLevel, this.mBatteryTemperature, this.mBatteryVoltage);
label80: shutdownIfNoPower();
shutdownIfOverTemp();
label275: int j;
label357: boolean bool2;
label517: boolean bool3;
label527: boolean bool4;
label570: Intent localIntent;
if ((this.mBatteryStatus != this.mLastBatteryStatus) || (this.mBatteryHealth != this.mLastBatteryHealth) || (this.mBatteryPresent != this.mLastBatteryPresent) || (this.mBatteryLevel != this.mLastBatteryLevel) || (this.mPlugType != this.mLastPlugType) || (this.mBatteryVoltage != this.mLastBatteryVoltage) || (this.mBatteryTemperature != this.mLastBatteryTemperature) || (this.mInvalidCharger != this.mLastInvalidCharger))
if (this.mPlugType != this.mLastPlugType)
if (this.mLastPlugType != 0)
break label888;
if ((this.mDischargeStartTime != 0L) && (this.mDischargeStartLevel != this.mBatteryLevel))
l = SystemClock.elapsedRealtime() - this.mDischargeStartTime;
i = 1;
Object[] arrayOfObject3 = new Object[3];
arrayOfObject3[0] = Long.valueOf(l);
arrayOfObject3[1] = Integer.valueOf(this.mDischargeStartLevel);
arrayOfObject3[2] = Integer.valueOf(this.mBatteryLevel);
EventLog.writeEvent(2730, arrayOfObject3);
this.mDischargeStartTime = 0L;
if ((this.mBatteryStatus != this.mLastBatteryStatus) || (this.mBatteryHealth != this.mLastBatteryHealth) || (this.mBatteryPresent != this.mLastBatteryPresent) || (this.mPlugType != this.mLastPlugType))
Object[] arrayOfObject1 = new Object[5];
arrayOfObject1[0] = Integer.valueOf(this.mBatteryStatus);
arrayOfObject1[1] = Integer.valueOf(this.mBatteryHealth);
if (!this.mBatteryPresent)
break label913;
j = 1;
arrayOfObject1[2] = Integer.valueOf(j);
arrayOfObject1[3] = Integer.valueOf(this.mPlugType);
arrayOfObject1[4] = this.mBatteryTechnology;
EventLog.writeEvent(2723, arrayOfObject1);
if ((this.mBatteryLevel != this.mLastBatteryLevel) || (this.mBatteryVoltage != this.mLastBatteryVoltage) || (this.mBatteryTemperature != this.mLastBatteryTemperature))
Object[] arrayOfObject2 = new Object[3];
arrayOfObject2[0] = Integer.valueOf(this.mBatteryLevel);
arrayOfObject2[1] = Integer.valueOf(this.mBatteryVoltage);
arrayOfObject2[2] = Integer.valueOf(this.mBatteryTemperature);
EventLog.writeEvent(2722, arrayOfObject2);
if ((this.mBatteryLevelCritical) && (!this.mLastBatteryLevelCritical) && (this.mPlugType == 0))
i = 1;
if (this.mPlugType == 0)
break label919;
bool2 = true;
if (this.mLastPlugType == 0)
break label925;
bool3 = true;
if ((bool2) || (this.mBatteryStatus == 1) || (this.mBatteryLevel > this.mLowBatteryWarningLevel) || ((!bool3) && (this.mLastBatteryLevel <= this.mLowBatteryWarningLevel)))
break label931;
bool4 = true;
Slog.d(TAG, "sendBatteryLow:" + bool4 + " plugged:" + bool2 + " status:" + this.mBatteryStatus + " mBatteryLevel:" + this.mBatteryLevel + " mLowBatteryWarningLevel:" + this.mLowBatteryWarningLevel + " oldPlugged: " + bool3 + " mLastBatteryLevel: " + this.mLastBatteryLevel);
sendIntent();
localIntent = new Intent();
localIntent.setFlags(268435456);
if ((this.mPlugType == 0) || (this.mLastPlugType != 0))
break label937;
localIntent.setAction("android.intent.action.ACTION_POWER_CONNECTED");
this.mContext.sendBroadcast(localIntent);
label726: if (!bool4)
break label972;
this.mSentLowBatteryBroadcast = true;
localIntent.setAction("android.intent.action.BATTERY_LOW");
while (true)
this.mLed.updateLightsLocked();
if ((i != 0) && (l != 0L))
logOutlier(l);
this.mLastBatteryStatus = this.mBatteryStatus;
this.mLastBatteryHealth = this.mBatteryHealth;
this.mLastBatteryPresent = this.mBatteryPresent;
this.mLastBatteryLevel = this.mBatteryLevel;
this.mLastPlugType = this.mPlugType;
this.mLastBatteryVoltage = this.mBatteryVoltage;
this.mLastBatteryTemperature = this.mBatteryTemperature;
this.mLastBatteryLevelCritical = this.mBatteryLevelCritical;
this.mLastInvalidCharger = this.mInvalidCharger;
return;
bool1 = false;
break;
if (this.mUsbOnline)
this.mPlugType = 2;
break label36;
this.mPlugType = 0;
break label36;
localIOException = localIOException;
localIOException.printStackTrace();
break label47;
label888: if (this.mPlugType != 0)
break label275;
this.mDischargeStartTime = SystemClock.elapsedRealtime();
this.mDischargeStartLevel = this.mBatteryLevel;
break label275;
label913: j = 0;
break label357;
label919: bool2 = false;
break label517;
label925: bool3 = false;
break label527;
label931: bool4 = false;
break label570;
label937: if ((this.mPlugType != 0) || (this.mLastPlugType == 0))
break label726;
localIntent.setAction("android.intent.action.ACTION_POWER_DISCONNECTED");
break label726;
label972: if ((this.mSentLowBatteryBroadcast) && (this.mLastBatteryLevel >= this.mLowBatteryCloseWarningLevel))
this.mSentLowBatteryBroadcast = false;
localIntent.setAction("android.intent.action.BATTERY_OKAY");
catch (RemoteException localRemoteException)
break label80;
private final void sendIntent()
Intent localIntent = new Intent("android.intent.action.BATTERY_CHANGED");
localIntent.addFlags(1610612736);
int i = getIcon(this.mBatteryLevel);
localIntent.putExtra("status", this.mBatteryStatus);
localIntent.putExtra("health", this.mBatteryHealth);
localIntent.putExtra("present", this.mBatteryPresent);
localIntent.putExtra("level", this.mBatteryLevel);
localIntent.putExtra("scale", 100);
localIntent.putExtra("icon-small", i);
localIntent.putExtra("plugged", this.mPlugType);
localIntent.putExtra("voltage", this.mBatteryVoltage);
localIntent.putExtra("temperature", this.mBatteryTemperature);
localIntent.putExtra("technology", this.mBatteryTechnology);
localIntent.putExtra("invalid_charger", this.mInvalidCharger);
Slog.d(TAG, "level:" + this.mBatteryLevel + " scale:" + 100 + " status:" + this.mBatteryStatus + " health:" + this.mBatteryHealth + " present:" + this.mBatteryPresent + " voltage: " + this.mBatteryVoltage + " temperature: " + this.mBatteryTemperature + " technology: " + this.mBatteryTechnology + " AC powered:" + this.mAcOnline + " USB powered:" + this.mUsbOnline + " icon:" + i + " invalid charger:" + this.mInvalidCharger);
ActivityManagerNative.broadcastStickyIntent(localIntent, null);
private final void shutdownIfNoPower()
if ((this.mBatteryLevel == 0) && (!isPowered()) && (ActivityManagerNative.isSystemReady()))
Intent localIntent = new Intent("android.intent.action.ACTION_REQUEST_SHUTDOWN");
localIntent.putExtra("android.intent.extra.KEY_CONFIRM", false);
this.mContext.startActivity(localIntent);
private final void shutdownIfOverTemp()
if ((this.mBatteryTemperature > 680) && (ActivityManagerNative.isSystemReady()))
private final void update()
try
native_update();
processValues();
return;
finally
localObject = finally;
throw localObject;
private static void writeBatteryCapacity(int paramInt)
throws IOException
if (mCount == 0L)
FileWriter localFileWriter = new FileWriter("/sys/devices/platform/rk2918-battery/startget");
Slog.d("bryan------------------------------>", " /sys/devices/platform/rk2918-battery/startget ");
localFileWriter.write("A", 0, "A".length());
localFileWriter.close();
protected void dump(FileDescriptor paramFileDescriptor, PrintWriter paramPrintWriter, String[] paramArrayOfString)
if (this.mContext.checkCallingOrSelfPermission("android.permission.DUMP") != 0)
paramPrintWriter.println("Permission Denial: can't dump Battery service from from pid=" + Binder.getCallingPid() + ", uid=" + Binder.getCallingUid());
while (true)
return;
if ((paramArrayOfString != null) && (paramArrayOfString.length != 0) && (!"-a".equals(paramArrayOfString[0])))
continue;
try
paramPrintWriter.println("Current Battery Service state:");
paramPrintWriter.println(" AC powered: " + this.mAcOnline);
paramPrintWriter.println(" USB powered: " + this.mUsbOnline);
paramPrintWriter.println(" status: " + this.mBatteryStatus);
paramPrintWriter.println(" health: " + this.mBatteryHealth);
paramPrintWriter.println(" present: " + this.mBatteryPresent);
paramPrintWriter.println(" level: " + this.mBatteryLevel);
paramPrintWriter.println(" scale: 100");
paramPrintWriter.println(" voltage:" + this.mBatteryVoltage);
paramPrintWriter.println(" temperature: " + this.mBatteryTemperature);
paramPrintWriter.println(" technology: " + this.mBatteryTechnology);
finally
throw localObject;
final int getBatteryLevel()
return this.mBatteryLevel;
final int getPlugType()
return this.mPlugType;
final boolean isPowered()
int i = 1;
if ((this.mAcOnline) || (this.mUsbOnline) || (this.mBatteryStatus == i));
while (true)
return i;
int j = 0;
final boolean isPowered(int paramInt)
int i = 1;
if (this.mBatteryStatus == i);
while (true)
return i;
int j;
if (paramInt == 0)
j = 0;
else
int k = 0;
if (this.mAcOnline)
k = 0x0 | 0x1;
k |= 2;
if ((paramInt & k) == 0)
j = 0;
void systemReady()
class Led
private boolean mBatteryCharging;
private boolean mBatteryFull;
private int mBatteryFullARGB;
private int mBatteryLedOff;
private int mBatteryLedOn;
private LightsService.Light mBatteryLight;
private boolean mBatteryLow;
private int mBatteryLowARGB;
private int mBatteryMediumARGB;
private LightsService mLightsService;
Led(Context paramLightsService, LightsService arg3)
Object localObject;
this.mLightsService = localObject;
this.mBatteryLight = localObject.getLight(3);
this.mBatteryLowARGB = BatteryService.this.mContext.getResources().getInteger(17694748);
this.mBatteryMediumARGB = BatteryService.this.mContext.getResources().getInteger(17694749);
this.mBatteryFullARGB = BatteryService.this.mContext.getResources().getInteger(17694750);
this.mBatteryLedOn = BatteryService.this.mContext.getResources().getInteger(17694751);
this.mBatteryLedOff = BatteryService.this.mContext.getResources().getInteger(17694752);
void updateLightsLocked()
int i = BatteryService.this.mBatteryLevel;
int j = BatteryService.this.mBatteryStatus;
if (i < BatteryService.this.mLowBatteryWarningLevel)
if (j == 2)
this.mBatteryLight.setColor(this.mBatteryLowARGB);
while (true)
return;
this.mBatteryLight.setFlashing(this.mBatteryLowARGB, 1, this.mBatteryLedOn, this.mBatteryLedOff);
continue;
if ((j == 2) || (j == 5))
if ((j == 5) || (i >= 90))
this.mBatteryLight.setColor(this.mBatteryFullARGB);
else
this.mBatteryLight.setColor(this.mBatteryMediumARGB);
else
this.mBatteryLight.turnOff();
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/11/16 - 21:58
globula_neagra said
the
android version is 4.0.3 (RK2918_ANDROID4.0.3-SDK_V2.10_20120205)
I look at the smali code, the battery indicator works
Darragh Cooney
2012/11/19 - 21:36
Can someone give me the correct steps to flash this firmware, It doesn't work if I just copy kernel, I have Arnova 7G2.
Will their be a specific version designed for Arnova 7G2?
2012/11/19 - 23:30
have you read the first post of morka ?
there is a tutorial on how to flash the rom.
Morka
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/11/25 - 09:45
Fixe : At startup/reboot does not run the tablet, treated USB/charger connection (or not disconnect it)
Fixe : Battery indicator shows the real  level
For all Roms based RK2918 Android 4.1.1 Jelly Bean Oma's rom ,kasty-arn and MorkaMod JB
http://www.arctablet.com/users/forum/battery_fix_update_beta.zip
MorkaMod JB V1.2 Final
http://www.arctablet.com/blog/forum/arnova-g2-general-discussions/morkamod-jb-android-4-1-1-jelly-beanall-g2-and-g3
Oma7144, poseidon9000, bukaneri, Agation.52, Sowa, blinkydamo
stojsins
2012/11/27 - 06:51
I try this fix on my Prestigio 5097 Android 4.1.1 Jelly Bean Oma's rom from Recovery, and I get error. I think status 6 is was...
stojsins
2012/11/27 - 07:08
But now I extract services.jar form zip archive, and replace original in system/framework with this one, and batery status works just fine, and I can also start tablet without charger.
Thanks a lot!
The following users say thank you to stojsins for this useful post:
Morka
57 Guest(s)
Devices in use: Desktop (52), Phone (5)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
