2012/01/06
MorkaMod with Jelly Bean v1.1
Fixed:
Fix all problems v 1.0
system faster
mode Mass Storage
fix dpi 120 faster using the original firmware for arnova ,edit bluid.prop search line (ro.sf.lcd_density=160) replace 120
News original Flash Player 11.1.for Android 4.0 (11.1.115.27) run browser for install flash player
News airplane mode to save power but also to optimize the battery life of your Android device - tested my 8G2 +1h
no fixed :
At startup/reboot does not run the tablet ,run with usb or ac (I am looking for a correction)
For 8G2 ,8G2i 4Go and 8Go copy kernel.img file ,folder /rockdev/Image
http://www.arctablet.com/users/forum/8G2_8G2I_4Go_8Go_kernel.zip
http://www.arctablet.com/users/forum/MorkaModJBv1.1_all_arnova_fix.zip
For others model to copy kernel.img file from your backup folder /rockdev/Image
INSTALL
- decompress with zip
- boot tab into flash mode
- run RK-Flashtool as admin: EraseIDB, tick Loader, Run
- with ClockworkMod Recovery - wipe data/factory reset (for which we install the version 1 skip this step keeps your backup wifi, application etc)
- reboot
____________________________________________________________________________
 __________________________________________________________________________________
online video in HD
http://www.arctablet.com/users/forum/MorkaMod.zip
http://www.arctablet.com/users/forum/MorkaModJBv1.00allarnova.zip
Flash Player 11.1.for Android 4.0 (11.1.115.20)
Video player 1.82 with PIP video player
New build no probleme battery status
and improvement full...
Oma for boot.img ,recovery.img
darodi79 for kernel.img
***This firmware is not intended for Dual Touch device***Â
Fix for that WifiService appears always on (even though it isn't obviously always on, and I have "never" in android setting where it asks whether it should turn it off when the tablet is asleep)
Try adding these to build.prop:
pm.sleep_mode=1
ro.ril.disable.power.collapse=1
Some optimization file build.prop for Jelly Bean
# end build properties
# system.prop for rk29XX
##ro.kernel.android.ril=yes
#Density using 160 slowed tablets equipped with 512mb memory
ro.sf.lcd_density=120
keyguard.no_require_sim=1
#set keyguard.enable=false to disable keyguard
keyguard.enable=true#wifi.interface=ra0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
#wifi.supplicant_scan_interval = 60
#alsa.mixer.playback.master=DAC2 Analog
#alsa.mixer.capture.master=Analog
#configure the Dalvik heap for a standard tablet device.
#frameworks/base/build/tablet-dalvik-heap.mk
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=256m# Disable un-supported Android feature
hw.nopm=false
hw.nobattery=false
hw.nophone=false
hw.novibrate=false
hw.cameras=1
hw.nobluetooth=false
hw.hasethernet=true
hw.nodatausage=false
hw.hasdata=true
ro.platform.has.touch=true# Wi-Fi sleep policy
ro.platform.has.sleeppolicy=false#set to 0 temporarily so touch works without other changes
ro.sf.hwrotation=270#0~7 You are required to get the correct install direction according the sensor placement on target board
ro.sf.gsensorposition=4
ro.sf.ecompassposition=4
allow_all_orientations=1# Use OSD2 mouse patch
ro.ui.cursor=osd2# Enable 32-bit OSD
sys.fb.bits=32# Enable GPS
gps.enable=false
ro.kernel.android.gps=ttyGPS
gps.serial.speed=4800# Enable player buildin
media.amsuperplayer.enable=true
media.amplayer.enable-acodecs=asf,wav,aac,mp3,m4a,ape,flac,alac
media.amplayer.enable=true
media.amplayer.support-exname="divx,h264,avi,ts,m2ts,mkv,mp4,mpg,mpeg,rm, rmvb,wmv,ts,dat,vob,vcl"
media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
media.amsuperplayer.defplayer=PV_PLAYER
media.amplayer.thumbnail=true# Status bar customization
ro.statusbar.widget.power=true
ro.statusbar.yearmonthdayweek=true
ro.statusbar.ampm.nodisplay=false# HDMI
ro.hdmi480p.enable=false
rw.fb.need2xscale=ok#camera DCIM dir. 0:sd only; 1:nand only; 2,sd first
ro.camera.dcim=1#default time zone
persist.sys.timezone=America/New_York
persist.sys.language=en
persist.sys.country=US# ???
#gadget.nand.force_sync=true#
# ADDITIONAL_BUILD_PROPERTIES
ro.opengles.version=131072
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
No tested fix battery status
For who installed this version Oma JB v1.2.X or Arnova 10b G3 custom firmware Android 4.1 JB, root, more space for apps and PIP video player
Here is my fixed battery status add Flash Player 11.1.for Android 4.0 (11.1.115.20),Appslib 2,VideoEditor
http://www.arctablet.com/users/forum/morkatestomafix_battery_statusflash_11.1videoeditorappslib2.zip
rednaxxela42, Oma7144, admin, bukaneri, Sowa
Morka saidÂ
No tested fix battery statusFor who installed this version Oma JB v1.2.X or Arnova 10b G3 custom firmware Android 4.1 JB, root, more space for apps and PIP video player
Thanks Morka for sharing. This is best practive within the community!
It works as a generic fix for all those tabs showing no akku information. So a lot of user will be happy
admin, MorkaPer aspera ad astra, we rock the Tablets !
2012/10/27
Hello, I have a problem with 8 g2. I have updated the version MorkaMod and the tablet only starts when is connected by usb to the PC.
When I try to restore with Rockchip Batch Tool v1.5 (reset+power) the tablet does not recognize, and there appears a black screen that says:
CWMR Touch v5.5.0.4 beta 15
...with a few options that I do not know.
Please, How can I reset the tablet to install ICS?
I am slightly worried, excuse for my english.
edit: I did it!... when I connected the tablet to PC, I only need to push reset button and then, it's recognized by "Rockchip Batch Tool."
I've installed ICS and I will try JB when I'll be completly sure that I'm doing.
2011/12/01
Hi Morka!
Great job! Real support ext4 and ntfs file system.
Deficiencies that are indicated above. Besides the installation does not format the internal SD in vfat.
I slightly modified the ROM,
- Fixed root (replacement SuperSU)
- Added RootExplprer
- In the /boot fixed frequency of the processor and the default mode
  set - ondemand (dynamic frequency depending on the load)
- Â /system is mounted rw mode
Known weaknesses:
1. ext-SD is not mounted in a connected mode "Mass Storage"
2. At startup/reboot does not run the tablet, treated USB-cabele/charger connection (or not disconnect it)
Maybe you fix these issues.
Download this mod: s_MorkaMod_JB_1.0.7z (218 MB, included instruction)
The following users say thank you to Sowa for this useful post:
bukaneri, Morka, adminChina phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
2012/01/06
Agation.52 said
Hi, Morka!ÂBother you to see whether the news Fix battery level.
On my device, the normal level of battery is only displayed on the official firmware.
If possible, it is ready to help all I can.
Hi, Agation.52
What device you have?
What firmware you using?
For version 1.2
Really fast and stable
during startup without correcting the power and USB cables to connect
2012/11/13
My device : 3Q RC0710B
Install different firmware. But only on the official firmware no problem with the battery charge level.
installed your fix - not included without power supply. But the charge shows!
My device is charging only a charger. Via usb cable no charge. Because of this discomfort to wait working fix ....
What can I do to help solve problems with the batteries Fix?
Can you give me the source code Fix? Not sure decompiler get what need.
102 Guest(s)
Devices in use: Desktop (88), Phone (13), Tablet (1)
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
pablovs
