How to install Android Market on Arnova 8G2
shanebelton
2012/01/03 - 12:34
Hi there,
I am a recent purchaser of the Arnova 8 G2 (8GB) (yesterday).  But am a bit deflated as it won't do a lot of what i expected it to do... i am not the most technologically advanced!! so don't really understand a lot of what is talked about above (flashed, bricked etc).
I would like to be able to access Google Market place so i can use Youtube, Skype etc  Is this going to be possible on the Arnova 8 G2?  Will this firmware download allow me to do that?  And if so what do i need to do to install it?
Sorry if these are really simplae questions, but as i said most of what everyone else has said has shot straight over my head! 🙂
thanks in advance for any help!
shanebelton
2012/01/03 - 22:27
amy help would be appreciated!
thanks!
Shane
shanebelton
2012/01/04 - 17:52
Sorry to be a pain in the you know what....
Has anyone any advice they can offer on this?
thanks,
Shane
Thanks Received: 3169
2012/01/04 - 21:28
Please have a look at this page where you can download and install Sowa's custom firmware, it will let you run Android Market.
http://www.arctablet.com/blog/featured/arnova-8-g2-first-custom-firmware-android-market-root/
Installing a custom firmware is easy but there are always risks, I'd recommend not to do it if you are not sure you or someone can help you to repair your device (using Rockchip Flashing tool) in case it gets bricked (major system failure that prevent it to start).
If you have any question, just ask here.
alex
Forum Posts: 252
2012/01/05 - 02:19
Would my guide not work on this device admin? its a hell of alot less risky than installing custom fw?
2012/01/05 - 08:29
Right, I usually don't recommend this method, because of not having experienced it a lot myself.
I agree this is definitely safer than using a custom firmware and way easier to reverse.
Shane, here is Alex tutorial: /blog/forum/arnova-9-g2-firmware-version-and-password-protection/how-to-install-android-market-apps/
shanebelton
2012/01/05 - 10:36
thanks a million!
i will have a go at this later and let you both know, really appreicate the help!
ShaneSmile
poseidon9000
Forum Posts: 36
2012/02/21 - 14:21
Hey, in arnova 8 G2 with8 gigas works very fine the market version 1.8.2 but when the market updated to version 3.4.4 dont work!!! is not possible to install any app from the market and i have to unistall it.
But,is this a problem?? you can go to android market web page with the navigator and install the apps you desire from there.or not?
thefatdude
2012/03/19 - 23:07
I cant extract the zip get oops not allowed error
alex
Forum Posts: 252
2012/03/20 - 18:16
can you be more specific, which zip exactly?
thefatdude
2012/03/20 - 20:15
sorry i was trying to reply to the step by step guide re installing the market but i cant unzip anything to be honest 🙁 is there an app thats best or authrotise u have to change
125 Guest(s)
Devices in use: Desktop (111), Phone (13), Tablet (1)
konstantin0ss
nikoscc77
hacktes
Walldos
MOUNIR 1923
cynthiavd
Topics: 6010
Members: 260641
